dadosebo
How to control camera module from C++
Tue Jun 18, 2013 9:18 am
Hello all,
may somebody advise me, how to control CSI camera module through C++/C ?
Basically, I would like to take a picture or video when GPIO pin is changing status (foe ex. : from 1 to 0).
thanks a lot
david
Re: How to control camera module from C++
Tue Jun 18, 2013 10:05 am
All the camera apps are available as source code, which is all in C. It's in the Raspberry Pi userland github repo.
Please direct all questions to the forum, I do not do support via PM.
dadosebo
Wed Jun 19, 2013 2:29 pm
So, I must call os commands.
There is no library for camera control under C++, I'm right?
thanks
Wed Jun 19, 2013 3:13 pm
dadosebo wrote:So, I must call os commands.
thanks
Not really OS commands - there are a set of C functions available to run the camera - the code supplied shows how to do that. There is currently no specific library for the camera.
dadosebo
Thu Jun 20, 2013 9:56 am
thanks
Dear James,
first, thanks for support.
I found many objects to set-up camera, but any object to save video or picture to a file. Would you be so kind and put here some simple example how to make video under C++. Sorry for bothering you with begginers questions.
david
Thu Jun 20, 2013 10:08 am
thanks
Dear James,
david
The examples are the demo programs. They are about as simple as it gets. You can download them from github https://github.com/raspberrypi/userland.
The show how to run the camera and save the output.
wibble82
Sun Oct 27, 2013 8:22 am
Just added this to my blog:
http://robotblogging.blogspot.co.uk/201 ... i-for.html
It's a much simpler system for reading the camera in c++. Enjoy!
wibble82
Sun Oct 27, 2013 6:50 pm
Might I also recommend this incredibly simple bit of code for saving images: http://lodev.org/lodepng/
Once you've got your raw data from the camera, lodepng provides just 1 function call to save it as a png. Not fast, but simple!
rmsalinas
Fri Nov 01, 2013 8:19 pm
I have created a C++ library for controlling the camera. I think you might be insterested. Take a look at
http://www.uco.es/investiga/grupos/ava/node/40
Cheers
Fri Nov 01, 2013 8:24 pm
wibble82 wrote:Might I also recommend this incredibly simple bit of code for saving images: http://lodev.org/lodepng/
The standard raspistill can output PNG....(and BMP and GIF)
Return to “C/C++”
Who is online
Users browsing this forum: No registered users and 2 guests
