Wondering if anyone can help point me at how to reduce the CPU load with MPD please.
My Pi is running latest raspbian, headless through wired ethernet with a USB hard drive containing my music library. The files are shared with samba and also I have MPD running an icecast stream. The icecast stream is the only audio output. No matter what I try MPD uses between 50% and 60% which seems ridiculously high. Every so often I get a pause in the MPD stream of several seconds - not sure if this is a result of the CPU load or not.
Would appreciate any pointers, thanks.
