Hi guys,
I'm working to get the firefox sync server running called FSyncMS (https://github.com/balu-/FSyncMS).
I downloaded the file, opened the setup.php and chose sqlite. settings.php and weave_db were created successfully. I adapted the path to the index.php file in the settings.php and saved it. After chosing sqlite as database program it did not ask me any name or credentials for the database. I don't know if this was ok?!
The tutorials say after the setup.php was finished you can try to connect to the sync server but it tells me every time that I need to insert a valid URL?! I used the following: http://<IP>/fsync/index.php/
They say you need to end it with a '/', but still it says i should enter a valid URL... Working on it since two days, even though this is an easy tool to install i struggle hard..
Hope someone did this before and can help me to solve this. Ask me if you need any further information.
Cheers,
dai
