mikerr
Pi Biped Robot walking
Mon Jun 17, 2013 10:00 am
Not another quadcoptor, a proper biped robot!
I had this previously running - walking! - in arduino, but the pi makes more things cheaply possible (like vision, wifi etc)
He's currently still learning to walk under Pi control .
The legs have 6 servos being controlled by servoblaster.
AFAIK servoblaster can only do a maximum of 8 servos, so when arms and head are added I might have to offload servo control to an arduino.
Ravenous
Re: Pi Biped Robot
Mon Jun 17, 2013 11:30 am
So many wires, so little time!
Six servos - can you spell out what they do? I can see the ankle sideways tilt, and maybe a knee/ankle above that. I can't see if the hip has something to twist the leg, or to swing it fore/aft.
The batteries on the head is a good idea - probably helps reduce the sway frequency (if that's the right word).
mikerr
Re: Pi Biped Robot
Mon Jun 17, 2013 12:10 pm
Ankle is tilt left/right
Knee is forward/backward
Hip is forward/backward
simplesi
Re: Pi Biped Robot
Mon Jun 17, 2013 12:27 pm
What's the basic walk sequence?
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
mikerr
Re: Pi Biped Robot
Fri Jul 26, 2013 11:56 am
He just took his first steps without falling over:
http://www.youtube.com/watch?v=lgWbgvLjzlY
Ravenous
Re: Pi Biped Robot
Fri Jul 26, 2013 12:21 pm
Awww, that looks so cute :mrgreen:
That reminds me, almost time for my next AA meeting . (Only kidding.)
mikerr
Re: Pi Biped Robot
Fri Jul 26, 2013 12:39 pm
Hehe, he's already broken part of the top from a drunken fall...
Need to use the knee joints more - then he can walk with less lean, or longer strides.
Ravenous
Re: Pi Biped Robot
Fri Jul 26, 2013 12:47 pm
Yeah a bit of knee lift will help, but might also require simultaneous balance from the other leg... Not dared trying any of this myself but planning and programming robot gaits looks very complicated to me...
Still, at least even now he walks better than I dance.
mikerr
Re: Pi Biped Robot
Fri Aug 02, 2013 2:48 pm
My nephew Jake (age 8) decided the robot needed dressing and also added cardboard arms and head
Here's the results of his handiwork:
https://www.youtube.com/watch?v=5OQgIfOEktk
As you can see pi-bed also now goes left/right by varying the individual leg's stride length
mikerr
Re: Pi Biped Robot
Tue Aug 06, 2013 7:52 am
Kicking a ball:
https://www.youtube.com/watch?v=noObFbk ... ata_player
This runs the knee/hip servos at full speed, instead of slow smoothly interpolated sweeps like used in walking/ leaning
E.g.
Servo.hip = 90
Servo.hip= 140
vs
For sweep in range (90, 140):
          Servo.hip = sweep
          time.sleep (0.1)
(Not actual code)
Next step is to give it some autonomous behaviour (HC-SR04 ultrasonic sensor and/or camera :) )
raygeeknyc
Re: Pi Biped Robot walking
Sat Sep 28, 2013 11:13 pm
This looks great! :D kudos!
I was thinking about how to best spend 2 more servos. I think that an arm with one DOF - up-and-down and a gripper would yield a good ROI. In theory, you can position the bot side to side already and you could mount a small camera on the arm. The only problem remains one of balancing when you actually pick up anything substantial, can your robot "lean back" and still walk?
mikerr
Wed Oct 02, 2013 4:21 pm
Servoblaster is no longer limited to 8 servos - it's just been upgraded to support up to 21 servos now (17 on a Rev1 Pi)
http://www.raspberrypi.org/phpBB3/viewt ... 77#p420177
So using a couple more servos on arms / head /torso isn't a problem - though the weight (distribution) might be.
I've moved the weighty batteries down directly onto the hip now, so there's more torso movement possible without falling over:
and he can now sit down / lie down after a long day ;)
http://www.youtube.com/watch?v=PEIbgrYKP0I
Inventor_Tommy
Tue Jul 29, 2014 12:44 am
Hi
I am keen to get started on a similar project. Do you have an instructables or have your code available on github or another opensource location? It would be really great if your code was shared :-) It would make robotics 101 available for the novice and robotics learner (myself :-)).
Regards
Inventor_Tommy
mikerr
Tue Jul 29, 2014 7:40 am
Yes all my code is shared on github
http://github.com/mikerr/biped
Inventor_Tommy
Tue Jul 29, 2014 8:12 am
Thank you :-)
LinuxCircle
Wed Jan 07, 2015 4:30 am
What batteries did you use to power the 6 servos? How many Amps are required in total? Is 3A sufficient for 6 servos?
Wiring scheme would be appriciated
www.linuxcircle.com
[avi]
Sat Apr 04, 2015 2:30 pm
I was searching for something and landed up on this 2 year old thread.
So...you got any noob level instructions?
LinuxCircle
Thu May 14, 2015 4:05 am
[avi] wrote:I was searching for something and landed up on this 2 year old thread.
We built a biped robot and posted Noob Level instruction here: http://www.linuxcircle.com/2015/04/06/l ... -pi-robot/
Let us know or comment on the page if you need further assistance
www.linuxcircle.com
