Powerphil
deleting files, but storage space not changing
Sat Jun 15, 2013 6:31 pm
Hi all,
I have been moving files into the trash can on the raspberry pi, and when i empty the trash, the storage space on the SD card doesn't change. I have emptied the trash as both a root user and pi user. I've also tried sudo apt-get clean, but nothing changes. At the moment, i'm trying to "release" approx 3gig, so a significant amount.
Can anyone advise what I've done wrong?
sprinkmeier
Re: deleting files, but storage space not changing
Sat Jun 15, 2013 10:21 pm
You can use the following commands to see where the space is being used:
$ alias DU='du --block-size=1M --max-depth=2 --one-file-system'
$ alias s0rt='sort --numeric'
$ cd /some/directory/where/you/thing/the/junk/is
$ DU | s0rt | tail
good candidates are /tmp and /home/pi
If you prefer a GUI try baobab (I haven't used it on the Pi but it's in the repo so it should work)
It's possible the filesystem is in a bit of pain, especially if the Pi has been shut down abruptly.
You can force a file-system check with
$ sudo touch /forcefsck
$ sudo reboot
(usual disclaimer/warning about commands with sudo in them ...)
Powerphil
Mon Jun 17, 2013 6:29 pm
I've used teh GUI, but I still can't see where the space is being taken up. All the files have been deleted, the trash can empties, but the space not released.
Any other ideas??
sprinkmeier
Mon Jun 17, 2013 7:43 pm
Did you try the forcefsck thing?
Post the output of sudo du --block-size=1M --max-depth=2 --one-file-system / | sort -n | tail and sudo fdisk -l
Powerphil
Mon Jun 17, 2013 8:30 pm
Output is:
50 /lib
68 /var/lib
98 /usr/bin
213 /var
454 /usr/lib
670 /usr/share
1248 /usr
3131 /root/.local
3132 /root
4696 /
Powerphil
Mon Jun 17, 2013 8:31 pm
Output from fdisk:
Warning: ignoring extra data in partition table 5
Disk /dev/mmcblk0: 7888 MB, 7888437248 bytes
4 heads, 16 sectors/track, 240736 cylinders, total 15407104 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000bc8f9
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 2048 2332031 1164992 e W95 FAT16 (LBA)
/dev/mmcblk0p2 2334720 15407103 6536192 85 Linux extended
/dev/mmcblk0p5 2342912 2457599 57344 c W95 FAT32 (LBA)
Disk /dev/sda: 32.0 GB, 32015679488 bytes
255 heads, 63 sectors/track, 3892 cylinders, total 62530624 sectors
Disk identifier: 0x00000000
/dev/sda1 2 62530623 31265311 b W95 FAT32
sprinkmeier
Mon Jun 17, 2013 8:41 pm
3131 /root/.local
3G in that directory...
... that's close to half your SD card.
Powerphil
Mon Jun 17, 2013 8:43 pm
The SD card is a 8Gb card
Powerphil
Mon Jun 17, 2013 8:49 pm
sorry, read your last post wrong. Can I delete that directory or not?
sprinkmeier
Mon Jun 17, 2013 8:56 pm
I'd check to see what was in it first :-)
Return to “Beginners”
