I've got a question about using a regular unpowered USB-Hub in the following manner:
The three-way cable between the power supply, the USB-out of the Pi and the USB-hub connects the power-pins of the hub's USB-input to the power pins of the power supply output and connects the data pins of the Pi's USB output to the data pins of the hub's USB-input.
This way:
1) The Pi is powered through the hub
2) Devices can be connected to the pi with their data pins, and the power will be drawn from the power supply
Am I making clear what I want to achieve?
Another question is: can, say a WiFi-dongle, draw it's power from a different source than the data? If not, this won't work of course.
