I have an application in mind that pushes either the main or extended desktop of a Windows PC (probably a laptop) simultaneously to multiple RPis connected to either TVs or projectors, to form a distributed media presentation solution.
Many projectors now have network (incl wireless) interfaces, including the NEC NP1000 I have (an older model), but to create a multi-screen system with a mix of projector and TVs, NEC's own Image Express Utility software won't cut it, as (i) there's no TV that can receive the network media stream, and (ii) the Vista/Win7 version doesn't support extended desktop.
The PC will therefore do the screen image 'push' out across the network, and the RPis will receive the stream, decode it and output the resulting audio+video vis the HDMI port. I need the software for both sides of the solution.
