which arduino should i choose?
hi, i would like to buy an arduino, but i am not that experienced, which arduino would you suggest for starters?
Re: which arduino should i choose?
myself i would say uno - but thats just me
You do realise this is a Raspberry Pi forum? (even if it is in the off topic section!). Seriously, I'm sure Arduino's forums would be able to give a better opinion.noob wrote:hi, i would like to buy an arduino, but i am not that experienced, which arduino would you suggest for starters?
Well...no doubt. But in the Arduino forums he'd probably get blasted for asking which model he should get to use with a Raspberry Pi.jamesh wrote:You do realise this is a Raspberry Pi forum? (even if it is in the off topic section!). Seriously, I'm sure Arduino's forums would be able to give a better opinion.noob wrote:hi, i would like to buy an arduino, but i am not that experienced, which arduino would you suggest for starters?
- mahjongg
- Forum Moderator
You can plug in any arduino board into a PI using USB, but thats a bit of a circumbendibus, as an ATmega chip on 3V3 is a perfect companion to a PI and can connect directly to its UART.
if you just want an "arduino" to expand the I/O capabilities of the PI, like the gertboard does, then don't use a real arduino, better simply use any of the arduino compatible Atmega chips, that runs off 3.3V so you can connect it directly to the PI's UART port, just like the gerboard does. If I'm not mistaken there are expansion boards (lets call them "PIDuino's") that do exactly this already, or there probably will be soon! I thought I saw Element14 selling something like it already. Another possible source might be adafruit.
P.S. picture googling for http://www.google.nl/search?q=raspberry ... 97&bih=948 ("raspberry pi shield") gave me numerous interesting pictures
P.P.S element14's device is called "embeddedPI" and is an "arduinoshield" (with Arduino CPU) for the raspberry PI.
You find more about it here: http://www.element14.com/community/docs ... essory-epi
but there are probably cheaper similar boards here already or coming soon....
Not really. If you ask in the non-tech subforum then you get much useful information:W. H. Heydt wrote: Well...no doubt. But in the Arduino forums he'd probably get blasted for asking which model he should get to use with a Raspberry Pi.
http://forum.arduino.cc/index.php?topic=169417.0
I bet you can also ask under interface with software since pi is considered as a computer and you can just plug Arduino into its usb port.
Arduino UNO is the best choice in Arduino line-up for beginners.
I would strongly voice against trying out the pi GPIO first with no prior electronics experience. You may toss your pi out of the window if you make ONE wrong move. For Arduino over USB, it has a polyfuse to cut the loss when current flows too much so you may damage the chip on Arduino UNO but it is a few dollars to replace. You move on with more experience and caution, instead of moving on, and away from all this experience together. It is also easily portable to another computer, say when you do need processing power of a modern-day microprocessor. PCs don't have exposed GPIOs but have plenty USB to plug things in. I am using a Debian laptop for projects with arduino that will eventually run on pi. It's faster to compile anything with a laptop. Just my 2 cents.
Arduino data loggers, user interface, printed circuit board designer since 2009, RPI 3B 2B 2B Zero Jessie, assembly/C/C++/java/python programmer since the 80's
Try this : http://www.bitwizard.nl/catalog/product ... cts_id=126
The Raspduino is an Arduino compatible microcontroller board, designed to plug on top of a Raspberry Pi (some people like to call this a Pi Plate). It is then possible to add Arduino shields to the Raspduino.
The Raspduino is powered by a ATmega328 microcontroller, and can be programmed with the regular Arduino software. The Raspduino can communicate with the Raspberry Pi via the serial port or I2C port on the GPIO connector. Programming can also be done over the GPIO connector.
http://www.raspberrypi-dmx.org/
Open Source DMX/RDM/MIDI/OSC/Art-Net/sACN solutions
- mahjongg
- Forum Moderator
Thats what I meant, the ideal direct coupling of "an arduino micro controller + shield pinheaders" to a PI, without going through the troublesome USB serial route!liudr wrote:Not really. If you ask in the non-tech subforum then you get much useful information:W. H. Heydt wrote: Well...no doubt. But in the Arduino forums he'd probably get blasted for asking which model he should get to use with a Raspberry Pi.
All the plusses of using an arduino, including the possibility of using shields, and no silly business of using USB capacity.
Thats why the PI has a UART!!!!
You can also destroy your pi with one wrong move. With USB interface as shield, you have the polyfuse on Arduino board to take care of some mishaps. With the bare wires and wrong settings, it is fairly easy to smoke something. You may be extra careful type but that won't apply to most beginners. If someone shifts the P1 by one pin, puff. I did that before and I consider myself careful. If 5V is supplied to the SD card, puff, goes the system, more than money can replace.
The TI Launchpad with Energia would have been my first choice if it was still priced at USD 4.30. In the UK it's now GBP 7.20.
Ah, I forgot about that. If they carry the spirit of open source, why not? There's also picaxe netduino, etc. that are not expensive to damage.joan wrote:The TI Launchpad with Energia would have been my first choice if it was still priced at USD 4.30. In the UK it's now GBP 7.20.
Even with the new price (I've paid 9.99$ to get that in Portugal) it's an excellent choice. I'm really happy with the bought. Don't forget: for that price you also get a Fed-Ex shipping for free.joan wrote:The TI Launchpad with Energia would have been my first choice if it was still priced at USD 4.30. In the UK it's now GBP 7.20.
Btw: you can also get free samples of MSP430 chips, if (most likely) you need more for your launchpad. (2 of each model, 5 models per order and, at least, one order per month)
- Contact: Website
Still £3-70 from CPCIn the UK it's now GBP 7.20
http://cpc.farnell.com/texas-instrument ... 20Products
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
- Contact: Website
yepIf someone shifts the P1 by one pin, puff. I did that before and I consider myself careful.
Simon
Praise the polyfuse lord! IIRC, 100mA polyfuses were removed from model B to provide more current to connected devices so having that polyfuse elsewhere is very necessary.simplesi wrote:yepIf someone shifts the P1 by one pin, puff. I did that before and I consider myself careful.I did it once but luckily my USB battery seems to have fast short-circuit protection so it tripped and my RPi lived to fight another day
Simon
- Contact: Website
em - I've got all my polyfuses bypassed as I use just a single battery to power my stepper bots and it was just slowing me downPraise the polyfuse lord! IIRC
Simon
The reason given by TI for increasing the price was that they didn't want to compete with their distributors yet their distributors also raised their price to $10 USD so it still cheaper to order directly from TI as shipping is free. Go figure.joan wrote:The TI Launchpad with Energia would have been my first choice if it was still priced at USD 4.30. In the UK it's now GBP 7.20.
Polyfuses are pretty useful. They are only a few ohms in resistance.
It's a great buy at that price. I last bought at £3.64. It's a nice fit with the Pi.simplesi wrote:Still £3-70 from CPCIn the UK it's now GBP 7.20
- Contact: Website
What we (well me anyway) is some Firmata or NanPy type code so we can just bolt it on and use it to provide some cheap and easy A/D and hardware PWM
Simon
Simon
Energia gives an Arduino like interface,simplesi wrote:What we (well me anyway) is some Firmata or NanPy type code so we can just bolt it on and use it to provide some cheap and easy A/D and hardware PWM
Simon
http://www.energia.nu/
- Contact: Website
Yep - got that - I'm after a way of reading/writing values to and from it like NanPy or Pyfirmata
Remember - I like working on an IPad from my jacuzzi on the top floor of a 5 star hotel - I haven't the skills to work on the generator in the basement like you C gurus
Simon
Simon
Give Arduino/Energia a go. It's a gentle introduction to C/C++.
- mahjongg
- Forum Moderator
luckily the one used in the PI (F3) isn't a "few ohms", as that would mean a several volts would fall over it when one ampere is running through it! It would mean that the PI would only receive 3 volt instead of 5.liudr wrote:Polyfuses are pretty useful. They are only a few ohms in resistance.
In fact F3 is a tiny fraction of an ohm to ensure that even when fully loaded less than a tenth of a volt is lost in it!
