jrsimeon
Supporting Software Installation on debian6 (Raspberry pi)
Mon Jun 10, 2013 9:06 am
How to install following Modules in debian6 (Raspberry pi)?
1) teamviewer_linux.deb, (dpkg module not supporting).
2) Enable remote desktop& Install VNC Client. i want to access from windows PC
3) python module xlwt & xlrd..
Kindly advise me to do the same correctly.
rpdom
Re: Supporting Software Installation on debian6 (Raspberry p
Mon Jun 10, 2013 11:01 am
jrsimeon wrote:How to install following Modules in debian6 (Raspberry pi)?
Sorry. You can't. teamviewer will only run on Intel type processors (PCs), not ARM based systems like the Pi.
That has been covered on the forums many times before. This thread seems to have at least one way of doing it http://www.raspberrypi.org/phpBB3/viewt ... 62&t=18832
The same way you'd install it on Debian.
sudo apt-get update
sudo apt-get install python-xlwt python-xlrd
Are you really running Debian 6 (Squeeze) on your Pi? That will be a bit slow for some things. Unless you specifically need the armel version you might be better off with Raspbian Wheezy armhf.
