chlzr
Run Bash script in PHP
Tue Jun 04, 2013 3:17 pm
Hello!
I'm currently building a very simple server with raspberry pi, with very very little knowledge about sql, php....
When the user goes to the following url "RPi_IP"/main.php?addr=10&value=100, I want it to run a Bash script:
<html><body><h1>Hello! </h1>
Logic Address <?php echo$_GET["addr"]; ?><br>
Value <?php echo$_GET["value"]; ?><br>
$old_path = getcwd();
exec('cd');
exec('./writeknx $addr $value');
chdir($old_path);
Executing the URL I always get the following output:
Logic Address 10
With Value 100
$output = exec('ls -l'); $old_path = getcwd(); $output = exec('cd'); $output = exec('./writeknx $addr $value'); chdir("$old_path");
Thank you in advance!
Re: Run Bash script in PHP
Tue Jun 04, 2013 3:37 pm
That last chunk of code isn't enclosed in "<?php ... ?>" tags.
Also, you don't need to do that for every line, just put the whole code block in it with echo or printf statements.
<?php
echo "Logic Address ${_GET["addr"]}<br>\n";
echo "Value ${_GET["value"]}<br>\n";
exec('cd');
chdir($old_path);
technion
Wed Jun 05, 2013 4:32 am
Just think about what happens when I go and visit this URL:
RPi_IP"/main.php?addr=10&value=100; rm -rf /
Passing PHP variables into a shell is almost always a bad idea.
Wed Jun 05, 2013 5:20 am
technion wrote:Just think about what happens when I go and visit this URL:
True, the values should be at least quoted, if not escaped too, and checked for validity before use.
technion
Wed Jun 05, 2013 9:54 am
Nearly every major software compromise has involved an attempt at "santising" that didn't go far enough. Even if you can put together a completely safe check (must be completely an integer) it's only reinforcing a programming habit that will come up again later ("I'm sure I can sanitise this large complex string just as easily").
If the original poster can tell us what this script is supposed to do, we can probably provide a better solution.
Wed Jun 05, 2013 10:42 am
technion wrote:Nearly every major software compromise has involved an attempt at "santising" that didn't go far enough. Even if you can put together a completely safe check (must be completely an integer) it's only reinforcing a programming habit that will come up again later ("I'm sure I can sanitise this large complex string just as easily").
Oh, believe me, I know this so well. I wouldn't use this method myself. If I needed something done using the parameters given, I would do it within the program. The only time I use any command line options in my web-facing code is when there aren't any parameters other than those I generate myself.
technion
Wed Jun 05, 2013 12:07 pm
Well said!
OP, why don't you show us a copy of writeknx and we'll see if there's a better way to address this.
