dobra-dobra
Python code to detect if camera is available
Tue Jun 04, 2013 3:14 pm
Hi
I'm looking for a way to detect in Python code if camera module is connected to RPi. I have a script which start at boot to take pictures for timelapse, but when I run Pi without camera connected it causes errors.
Thanks in advance for any clue.
alexeames
Re: Python code to detect if camera is available
Tue Jun 04, 2013 4:52 pm
I can't answer the direct question, but perhaps there is another way?
Using a try: except: block in Python, if it causes errors you can program around them and the script won't exit.
You may already know this though, but just in case.
na razie ;)
Alex Eames RasPi.TV, RasP.iO
dobra-dobra
Tue Jun 04, 2013 8:35 pm
Thanks for response. I use Python code to call raspistill in a loop, and so errors which I get (I don't remember them now) are from raspistill, not from Python. So if I understand correctly I can't use Python exceptions.
But sometimes when you ask a question it is easier to find a solution by yourself, and I think that I may have found one. I can try to check if picture was taken and file written, and if it does - that means that camera is connected. And if not - I will break the loop. Still I will get error once, but thats a whole lot better than getting them every 2 seconds.
So...
Dziękuję. :D
znanev
Wed Jun 05, 2013 11:04 am
you could use the output of this command:
vcgencmd get_camera
When the camera is connected, the output is like this:
supported=1 detected=1
I haven't tried disconnecting the camera, but I suppose that if you have the latest firmware, supported will still be 1, but detected should show 0.
Hope this helps :)
sharix
Wed Jun 05, 2013 1:30 pm
With no camera attached and camera not enabled with raspi-config I get:
/opt/vc/bin/vcgencmd get_camera
supported=0 detected=0
dobra-dobra
Thu Jun 06, 2013 5:49 am
That is exactly what I needed, thanks a lot.
pingu512
Sat Jun 08, 2013 1:41 pm
I added this to the /etc/rc.local file just above exit 0
string=$(vcgencmd get_camera)
substring="detected=1"
if test "${string#*$substring}" != "$string"
then
    /home/pi/image_run/capture.sh    # Camera connected start capture
else
    echo "Not camera found"    # Camera not connected.
fi
http://www.weather.dragontail.co.uk
pingu512
Sat Jun 08, 2013 2:06 pm
The above code did not work when the camera was connected. string=$(vcgencmd get_camera) hung the process. Think again
sharix
Sat Jun 08, 2013 3:12 pm
Try with the whole path:
string=$(/opt/vc/bin/vcgencmd get_camera)
dobra-dobra
Sun Jun 09, 2013 6:29 pm
I can confirm, that when camera is connected vcgencmd get_camera does not return what expected. I made updates of system lately (apt-get update, rpi-update), but I'm not sure if this is related. After some tinkering (disconnecting and connecting module, disabling and enabling camera in raspi-config) I managed to get it working and I was able to test my sketch, but after reboot it doesn't work again and I can't reproduce my solution. But still I can use raspistill without any problem, so camera works as it should.
Can someone else confirm this?
alexeames
Sun Jun 09, 2013 9:17 pm
dobra-dobra wrote:I can confirm, that when camera is connected vcgencmd get_camera does not return what expected. I made updates of system lately (apt-get update, rpi-update), but I'm not sure if this is related. After some tinkering (disconnecting and connecting module, disabling and enabling camera in raspi-config) I managed to get it working and I was able to test my sketch, but after reboot it doesn't work again and I can't reproduce my solution. But still I can use raspistill without any problem, so camera works as it should.
Yes, I tried it last night and my Pi didn't respond to this command at all...
from /home/pi with and without sudo
or from the driectory where the command resides, with and without sudo.
Oh and I had to reboot the Pi after that before the camera would work again. Niestety, ale nie udalo sie :(
afargas
Tue Oct 27, 2015 11:55 am
I know that this conversation is from time ago, but in order to help other people, I developed a working code detecting if the camera is connected or not, I call it from a script added in rc.local:
#! /bin/sh
s=$(/opt/vc/bin/vcgencmd get_camera)
sb="supported=1 detected=1"
case $sb in
$s)
echo "Camera detected"
echo "Camera not detected $sb not in $
esac
GuruBastade
Thu Jan 07, 2016 8:02 am
How do I have a new pop up screen showing message "camera is not connected"?
r3d4
Thu Jan 07, 2016 8:07 am
GuruBastade wrote:Hello,
"xmessage Or whiptail" . :?:
Return to “Camera board”
