richiepp
AJAX to show live temp sensor data?
Mon May 27, 2013 12:57 am
I'm looking for a way to display real time data from my temp sensor to a web page. The idea is every time there is a change in temp by .1 degrees only that section of the webpage would update. I've never used AJAX but from what I've read about it it seems like it could be a solution.
Anyone have experience with this kind of thing?
Rich
DeeJay
Re: AJAX to show live temp sensor data?
Mon May 27, 2013 9:17 am
WebIOPi appears to do something similar to what you describe. Perhaps you might find something useful from the way it is implemented?
https://code.google.com/p/webiopi/
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
jpc
Wed May 29, 2013 3:54 am
You may want to look into using WebSockets, which allow for event-based TCP sockets within a web page using JavaScript.
Thu Jun 20, 2013 5:50 pm
I second the use of websockets. Very easy to use.
If you use node.js on your server to serve up websockets there is the socket.io module that makes life really easy and you end up using the same language, JavaScript, in the browser and the server which is a bonus.
http://nodejs.org/
http://socket.io/
Node.js installs easily on the Pi
http://nodejs.org/dist/v0.11.2/node-v0. ... -pi.tar.gz
NewPi
Mon Jul 15, 2013 2:38 pm
The easier way to do that would be to send date to "internet of things" aggregator like https://xively.com/ and get feeds from there.
Raspberry Pi Howto, Tips, Tricks and Tools -> http://bit.ly/RPiTricks
evgkib
Sun Aug 11, 2013 1:56 am
Here's something I wrote to display temperature in browser real time using node.js and socket.io https://github.com/evgkib/RaspberryPi-temp. My next goal is add more weather sensors, and create a live dashboard displaying information
jbeale
Sat Oct 05, 2013 12:40 am
evgkib wrote:Here's something I wrote to display temperature in browser real time using node.js and socket.io https://github.com/evgkib/RaspberryPi-temp.
Wondering if anyone can help me get node.js and socket.io working on my R-Pi. I have them installed but they don't work as I expect. Should the example below (from Scott Blaine's Blog ) work from the R-Pi's own browser (Midori) or does it require Firefox or something else? Here is the simple example I can't get to work, it is two files connectionCounter.js :
var express = require('express');
var app = express();
var socket = require('socket.io');
var server = app.listen(4000);
var io = socket.listen(server);
app.get('/', function(request, response){
  response.sendfile(__dirname + "/index.html");
var activeClients = 0;
io.sockets.on('connection', function(socket){clientConnect(socket)});
function clientConnect(socket){
  activeClients +=1;
  io.sockets.emit('message', {clients:activeClients});
  socket.on('disconnect', function(){clientDisconnect()});
function clientDisconnect(){
  activeClients -=1;
and here is the second file index.html :
<!DOCTYPE html>
<html>
  <head>
    <title>Connection Counter</title>
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js"></script>
    <script src="/socket.io/socket.io.js"></script>
    <script>
      function msgReceived(msg){
        $clientCounter.html(msg.clients);
      $(document).ready(function () {
        $clientCounter = $("#client_count")
        var socket = io.connect('http://localhost:4000');
        socket.on('message', function(msg){msgReceived(msg)});
    </script>
  </head>
  <body>
    <p><span id="client_count">0</span> connected clients</p>
</body>
</html>
I can connect to http://127.0.0.1:4000 from the R-Pi using Midori, from the R-Pi using links2 (text mode browser) and from my Android phone (Opera Mobile) via wifi. In every case I get the static page "0 connected clients" but I never see it increment, no matter how many clients connect. I do see each connection add a line of text on the console output:
pi@raspberrypi:~/nodeJS$ sudo node connectionCounter.js
   info  - socket.io started
   debug - served static content /socket.io.js
...etc.
it also works the same way, that is to say not correctly, if I don't use 'sudo'.
jbeale
Sat Oct 05, 2013 12:59 am
Well, the below demo does work (slowly) in the R-Pi's midori browser, and the no-ip.org site is itself apparently served by a R-Pi. So I ought to be able to do something much simpler on my own Pi- although I don't understand quite how node.js and socket.io is used in this example.
http://chriscavanagh.wordpress.com/2013 ... pberry-pi/
http://bobstrogg.no-ip.org:8080/demo.html
UPDATE: I got Scott's simple socket.io demo to work, yay: http://www.raspberrypi.org/phpBB3/viewt ... 08#p434008
