Mosa
TSL235 and Raspberry Pi
Thu May 23, 2013 11:31 pm
i want to add a light sensor (http://www.produktinfo.conrad.com/daten ... SL_235.pdf) to the Raspberry Pi Modell B rev2 but the sensor need more Volt and i know that the Raspberry Pi can only get 3.3 V. I draw some circuit and i want to check if this is correct.
Can someone help me pls?
http://s1.directupload.net/images/130523/zg7zf25m.jpg
mahjongg
Re: TSL235 and Raspberry Pi
Thu May 23, 2013 11:49 pm
yes, this should work fine!
rares
Mon Nov 04, 2013 7:21 am
Hi, I just used the TSL235 directly connected to GPIO and powered by 3.3V with no voltage divider attached.
It's also in the sensor specs that supply voltage can be from 2.7V up to 5.5V so Raspberry Pi should't have a problem
"reading" it while 3.3 V powered.
It works very nice, the light values graph during a day are almost identical to the ones generated with a "classic"
LDR photoresistor.
The C code for the Raspberry reading an TSL235 is here :
https://github.com/RaresPlescan/daisypi ... 235r/t13.c
and some more documented explanations in Wiki :
https://github.com/RaresPlescan/daisypi/wiki/TSL235R
The code is using WiringPi for reading the pin, so all the credits for that goes to Gordon.
cquarinto
Tue Aug 04, 2015 9:10 pm
I just used your code with my RPI and it works great. Thank you for that! -
Just one small, insignificant change, it's "iteration" not "itteration". :)
CQ
ferdywallinx
Mon Sep 28, 2015 6:57 am
I've run your script and it worked like a charm, momentarily. When I strongly increase or decrease the light intensity or when I attach another device to my Pi on a different 3.3V pin then I get the output of "No TSL-235 found on wiringpi_pin(1)". And it keeps outputting this, even when I detach the Pi, other device or TSL-235 and then plug them in again. At some seemingly random point it starts working again. Would you know a reason why it does this?
Thanks!
