okieng
crontab get ip question
Thu May 23, 2013 9:50 pm
My goal is find and write ip address with crontab
here is my script
findip.sh
#!/bin/bash
echo "myip:"
ifconfig eth0 | grep inet | grep -v inet6 | awk '{print $2}' > ip.txt
here is cron (create : crontab -e)
*/1 * * * * /root/findip.sh
I am run findip.sh with ssh terminal. Everythings working. I saw ip address ip.txt
myip
192.168.0.111
But whan ip.txt create with cron there is no ip. address only
myip:
what is the problem?
Thanks for help.
Oki
pepedog
Re: crontab get ip question
Thu May 23, 2013 11:48 pm
Maybe cron is running without PATH?
ie this needed
/sbin/ifconfig eth0 | grep inet | grep -v inet6 | awk '{print $2}' > ip.txt
sprinkmeier
Fri May 24, 2013 7:06 am
hostname --all-ip-addresses | xargs --max-args 1 | grep --invert-match :
nothing wrong with your solution but it's always handy to know an extra way to skin a cat.
consider writing to /dev/shm/ip.txt. this is a RAM filesystem and won't wear out your SD card.
okieng
Fri May 24, 2013 12:13 pm
Thanks Guys,
Pepedog your code is works.
Actually i just try */usr/bin/ifconfig ... buy this was not work.
But */sbin/ifconfig ... is working .
Thanks again
Oki
Return to “Arch”
