Yes, apparently setting exposure to off doesn't actually set it to off as I found out after I'd written the code. So I'm afraid there is no Off option for exposure.Josh04 wrote:As far as I can tell, setting the auto-exposure to 'off' in video mode gives only black output, until for stills. No fiddling with other switches seems to help. Has anyone had any luck with this?
JAMESH, please!If you think about it, having exposure processing off isn't of much use - the images will basically be rubbish, never the correct brightness except in very particular lighting conditions. You need some sort of exposure, and auto generally is the way to go.
But this thread is about video isn't it?axse wrote: HDR photography, panoramas, night photo, infrared, etc etc.
Please don't use capitals. I find it annoying. I wasn't talking about manual exposure setting, I was talking about turning off brightness compensation completely - i.e. fixed gains. That's means no ISO either, although exposure times would still work.axse wrote:JAMESH, please!If you think about it, having exposure processing off isn't of much use - the images will basically be rubbish, never the correct brightness except in very particular lighting conditions. You need some sort of exposure, and auto generally is the way to go.manual exposure is VITAL for a lot of projects. First of all a 3d laser scanner. I need to set ISO at 100 and choose the exposure time.
then, HDR photography, panoramas, night photo, infrared, etc etc.
Sorry for annoying you, i'm just very exited about the possibilities of a raspi with a cam, but i'm feeling a little bit frustrated because the settings I really need doesn't work. All exposure possibilities, as night, disco, sport ect. ect. are simply variation of 3 parameters. ISO, ex time and WB. (and saturation, contrast). To my eyes seams to be easier to let people directly set ISO, ex time and WB. good job!Please don't use capitals. I find it annoying. I wasn't talking about manual exposure setting, I was talking about turning off brightness compensation completely - i.e. fixed gains. That's means no ISO either, although exposure times would still work.
You already have a load of different options for exposure e.g. night mode etc, try some of them out -they might already do what you want. Apart from Infrared unless you abuse the module.
ISO stuff isn't working (supposed to be there, but doesn't appear to work correctly), and there is no facility to set exposure time specifically as yet. Former I might be able to get working once all the more important issues are fixed - second I wouldn't hold my breath for.
Well the price is fixed on cheap. And it's going to be very good (already is in many respects). So, quick is off the tableYou can have it cheap
You can have it good
You can have it quick
Pick any two of the above
seems to me you should be using a proper DSLR and have the raspi connected to it by usb - ultimate control, ultimate picture qualityaxse wrote:Sorry for annoying you, i'm just very exited about the possibilities of a raspi with a cam, but i'm feeling a little bit frustrated because the settings I really need doesn't work. All exposure possibilities, as night, disco, sport ect. ect. are simply variation of 3 parameters. ISO, ex time and WB. (and saturation, contrast). To my eyes seams to be easier to let people directly set ISO, ex time and WB. good job!Please don't use capitals. I find it annoying. I wasn't talking about manual exposure setting, I was talking about turning off brightness compensation completely - i.e. fixed gains. That's means no ISO either, although exposure times would still work.
Problem is the underlying code running the camera does what our major customers want - not what you might want. And remember that these mobile phones sensors do not have the same set of abilities you might find with a device that has a shutter, an aperture etc. So the maths does whatever Samsung want, as does the feature set.towolf wrote:No seriously, being able to set exposure to be fixed at a pre-determined level is pretty crucial.
Big bonus points if the maths used correspond to APEX system.
