MCM
Issues when playing music from playlist
Sun May 19, 2013 8:01 pm
Hello
I use the raspberry pi to play playlists which contain about 400 to 500 songs. The songs are stored in ogg format.
When i play the playlist, i get a crackling sound when the one song finishes playing and before the second song starts to play. I only get this problem if i play it on a simple home music system. When i play it through a professional sound system with amplifiers etc. i do not get this sound.
The other problem i have is that there is a delay of 5 seconds between the time the song finishes till the time the next song plays (on the home music system) and 8 seconds delay on the professional sound system.
Any suggestions?
redhawk
Re: Issues when playing music from playlist
Sun May 19, 2013 9:09 pm
What software are you using??
Richard S.
ghans
Mon May 20, 2013 8:23 am
The crackling sound issue has been "solved" about a month ago.
Are you using a preloaded card ?
sudo apt-get update
sudo apt-get upgrade
should fix it anyway.
ghans
MCM
Fri May 24, 2013 7:44 am
I am using software that we designed.
I just ordered a number of raspberry pis. I used the SD card i had and mirrored it. When i used it on the new raspberry pi i still had the crackling sound. GHANS i have not tried what you suggested. I will give it a try and see if it fixes it.
I also have a few delayes when playing the songs. On a normal home hi-fi i have a delay of 8 seconds. On a commercial music system (with amplifiers etc.) i also get 8 seconds delay. If i play it through the TV i get a 5 second delay. Any suggestions?
Regards,
Elena
ghans
Fri May 24, 2013 11:56 am
WHEN did you image the very first card or was it a preloaded
one ?
ghans
