mad-hatter
Find sha1 & md5 check sums - QT4 - C++ - program & source
Fri May 17, 2013 3:39 pm
If these are of any use:-
Attached, source for compiling under QT4/C++, run file and a layout picture.
This is a program to find the sha1 and/or md5 checksums of any program/file on your system.
I’m fed up with cd’ing and then typing the command in a terminal, I made a simple GUI
program to do this.
If you don’t trust the run file, compile it yourself in QT4.
I checked the sum against the downloaded wheezy hf zip file, took about
50 seconds (900mhz pi) and even agreed with the web-site checksum.
Browse for a file, select which sums you want (sha1, md5 or both), calculate then compare
to a pasted checksum (hash, you can copy and paste directly from a browser).
The run file was compiled on wheezy hard float, I don't know if will run on any other system.
You will have to change ownership and permissions on the run file.
I’m a novice at C++ & QT4, so I’m sure the source can be drastically improved.
Regards
sha1-19-5-2013-revised.zip
MD5 Checksum: 9f0b00e092731333a648cde7da773de0
SHA-1 Checksum: 8e598debac9be3fcc46af7f83bccf8f269d23a57
source-19-5-2013-revised.zip
MD5 Checksum: 085804e5304263c7f0c2ab28685eb908
SHA-1 Checksum: 92238b569534ab91315ed7b45cac46131a3eb712
(15.38 KiB) Downloaded 157 times
(2.96 KiB) Downloaded 169 times
DaveDriesen
Re: QT4 - find sha1 & md5 check sums - program & source
Fri May 17, 2013 3:56 pm
Your code is fine!!
Thanks for this -- not only is it useful as a tool but it's also a good example of QT/C++
Dave Driesen
Linux dev and oldskool elite
mad-hatter
Re: Find sha1 & md5 check sums - QT4 - C++ - program & sourc
Sun May 19, 2013 1:13 pm
Hello DaveDriesen,
There is an error in the code that was posted.
The original post has been updated.
Regards
Return to “C/C++”
