ejolson
Re: Raspberry Pi Benchmarks
Thu Apr 12, 2018 3:06 pm
bensimmo wrote:
Thu Apr 12, 2018 10:14 am
That doesn't show you what the platform can do, other than only showing how well it can handle legacy compiled code.
I see there are two different ideas here both with the goal of comparing and increasing performance. In one case you consider a particular hardware configuration and tune the software until it solves a given problem as fast as possible. This is the best effort benchmarking scenario previously discussed. In the other case you consider a particular item of (compiled legacy) software and tune the hardware until it runs that code as fast as possible. This is sometimes called over clocking instead of benchmarking. Thus, in benchmarking you tune the software keeping the hardware the same, while in over clocking you tune the hardware keeping the software the same.
It goes without saying that tuning the hardware to run a particular software as fast as possible is perhaps more common (and useful) than traditional benchmarking. The reason for this is the vast amount of precompiled binary code available both commercially-produced for purchase and for free as in beer. For example, since the Raspbian user land has been compiled for ARMv6 compatibility, it is possible to over clock the ARMv8 cores on the Pi3B and Pi3B+ and still correctly execute all of user land. By some accounts the stock clock settings for the 3B and 3B+ have already been tuned in this way, but never mind that.
If the hardware has been tuned to execute a particular set of binaries fast, it may crash or produce incorrect results for differently optimized code that was not taken into account during the over clocking. However, the usage scenario in which the binary executables are fixed is so common that over clocking might well be the more important type of performance tuning and grounds for comparison, at least in the short term.
bensimmo
Thu Apr 12, 2018 3:32 pm
I've never heard the term overclocking used in that context.
To me that is taking the hardware, say a Pi1 or a Pi3 or an Intel P5 i4460K or a 6502 and running it beyond it default designated safe parameters.
But if overclocking is running a ARMv6 optimised fft and pi calculation and running it on and ARMv8 then so be it and seeing how fast it performs, then so be it.
jahboater
Thu Apr 12, 2018 4:52 pm
For me "benchmarking" and "overclocking" are two entirely different things. Benchmarking is pure "measurement", "overclocking" is performance tuning (likely beyond manufacturers spec). The two are only related because benchmarking is required to assess the effectiveness of an overclock.
ejolson
Fri Apr 13, 2018 12:57 pm
Given the accuracy in how parts are speed graded, over clocking almost always breaks the hardware in some way. The only reason it works is because the sequence of instructions that fail due to the over clock don't happen to be used in whatever specific software (usually a game) under consideration.
Benchmarking in general requires tuning the software (or writing new code) for the computer being measured. Many websites that run things like Sandra CPU test and Doom on a bunch of PCs are not answering the question, how fast can a particular computer solve a particular problem, but rather trying to monetize some sort of online advertising.
ejolson
Tue Apr 24, 2018 12:12 am
I'm posting a link to a Linpack benchmarking run showing the Pi 3B+ can achieve 6.718 Gflops, which is hopefully closer to a best-effort result than the 605 Mflops reported earlier in this thread. From what I can tell, Roy's results indicate how well modern computers run historical benchmark codes without specialized tuning. Such results are important, in my opinion, because a significant percentage of numerical codes used in production actually fall into this category.
I'm posting here because current usage of the term Linpack generally refers to best-effort attempts to solve problems scaled to the size of available memory using carefully optimized code. As these forum posts show up early on web searches, I believe it is important to include results for comparison which reflect the performance of the Pi 3B+ following the practices currently used for other computers.
I'm also posting here in the hope that someone interested in benchmarks might verify whether 6.718 Gflops really reflects a best-effort Linpack result for the Pi 3B+. In particular, based on relative clock speeds I had expected a speed of over 7 Gflops and would appreciate it if someone else could verify my results.
RoyLongbottom
Thu Apr 26, 2018 5:06 pm
Raspberry Pi 3B+ Memory Benchmarks
Full details of 32 bit and 64 bit memory benchmarks (and single core tests) are available at ResearchGate in Raspberry Pi 3B+ 32 Bit and 64 Bit Benchmarks and Stress Tests.pdf, from the following link (then click on down arrow to select download)
https://www.researchgate.net/publicatio ... ress_Tests
This includes 3B+ comparisons with the older Mode 3B and 64 bit versus 32 bit performance. The latter is repeated below for the newer processor (3B similar). The 3B+/3B performance is essentially proportional to respective CPU MHz speeds, where date from caches is processed, but 3B+ is often shown to be slightly slower with RAM data transfers. The benchmarks are as follows, most doubling up data size used, to cover caches, and RAM, with performance measured in MegaBytes per second. Example full results and comparisons are provided below.
MemSpeed - carries out the calculations shown in the following, the first being of the same format as the Linpack benchmark time dependent function. Maximum MFLOPS are also shown for these, plus MFLOPS/MHz ratios, these being higher that those for Linpack, mainly due to the smoother data flow and slightly using L1 cache based results. Best 64 bit performance gains were using double precision floating point but one result indicates that the older RPi was faster using RAM based data.
            Memory Reading Speed Test vfpv4 32 Bit Version 1
  Memory   x[m]=x[m]+s*y[m] Int+   x[m]=x[m]+y[m]         x[m]=y[m]
  KBytes    Dble   Sngl  Int32   Dble   Sngl  Int32   Dble   Sngl  Int32
    Used    MB/S   MB/S   MB/S   MB/S   MB/S   MB/S   MB/S   MB/S   MB/S
        3B+/3B
           Raspberry Pi 3B+ CPU 1400 MHz, SDRAM ?                        Avg Gain
       8    1899   2125   4041   2783   2624   4448   3164   3693   3693  1.17 L1
      16    1901   2128   4058   2791   2628   4462   3177   3703   3707
      32    1852   2049   3817   2686   2508   4161   3186   3715   3711
      64    1796   1959   3574   2542   2367   3855   2945   3347   3347  1.16 L2
     128    1826   1989   3741   2600   2408   4031   3042   3506   3508
     256    1833   1995   3771   2617   2414   4068   2860   3616   3617
     512    1517   1618   2587   2039   1911   2687   2459   2825   2832
    1024     968   1098   1221   1172   1140   1211   1455   1144   1137  0.98 RAM
    2048     911    980   1060   1038   1026   1062   1013    941    935
    4096     913    993   1064   1047   1038    948    992    902    903
    8192     926   1013   1077   1074   1065   1085    782    784    783
 Max MFLOPS  238    532
    Per MHz 0.17   0.38
    64 bit  0.43   0.52
 #################### Compare 64 bit / 32 bit Pi 3B+ ######################
       8    2.54   1.36   1.08   2.22   1.51   1.09   1.70   1.17   1.17
     256    2.12   1.39   1.05   1.86   1.53   1.06   1.71   1.13   1.13
    8192    0.71   1.19   1.17   1.14   1.03   1.17   1.29   1.38   1.38
NeonSpeed - executes the same functions as MemSpeed, but with all floating point calculations using single precision floating point (for compatibility with NEON). Some normal calculations are also included for comparison purposes. The NEON calculations are carried out using NEON Intrinsic Functions but the latest compilers convert these into more appropriate vector instructions. This leads to little difference between 32 bit and 64 bit speed, the former being faster in one case. For some reason, 32 bit normal calculations were faster than in MemSpeed, but maximum NEON MFLOPS per MHz were significantly faster.
   NEON SP Float & Integer Benchmark RPi 3B+ 64 Bit
  Memory  Float v=v+s*v  Int v=v+v+s   Neon v=v+v    3B/3B+
  KBytes   Norm   Neon   Norm   Neon  Float    Int  Avg Gain
      16   2724   5109   3961   4841   5446   5607  1.16 L1
      32   2612   4645   3726   4450   4968   5036
      64   2523   4247   3540   4150   4521   4519  1.16 L2
     128   2583   4363   3666   4253   4616   4635
     256   2576   4314   3674   4254   4591   4631
     512   1852   2871   2608   2466   2916   2698
    1024   1222   1207   1305   1179   1280   1216  1.08 RAM
    4096   1157   1144   1214   1109   1181   1160
   16384   1175   1245   1244   1134   1191   1180
   65536   1143   1258   1185    909   1144   1260
Max MFLOPS  681   1277
  Per MHz  0.49   0.91
  32 Bit   0.57   0.84
      16   0.86   1.10   0.99   0.99   1.05   1.02
     256   0.88   1.07   0.98   1.01   1.06   1.00
   65536   0.85   0.94   0.88   0.90   0.91   0.93
BusSpeed - is designed to identify reading data in bursts over buses and possible maximum data transfer speed from RAM (using 1 core - see MP version). The program starts by reading a word (4 bytes) with an address increment of 32 words (128 bytes) before reading another word. The increment is reduced by half on successive tests, until all data is read. Data is read using inner loops containing 64 AND statements, that appear to essentially generate the same code for 32 bit and 64 bit compilations, with only 32 bit data words being used. Surprisingly, the 64 bit version produced slow speeds on reading all data from what should be L1 cache.
                    BusSpeed 64 Bit
  Memory  Inc32  Inc16   Inc8   Inc4   Inc2   Read  3B+ Gain
  KBytes  Words  Words  Words  Words  Words    All  Read All
      16   3823   4251   4638   4945   5045   3854  1.15 L1
      32   1543   1677   2423   3331   4152   3680
      64    672    694   1306   2169   3300   3577  1.17 L2
     128    635    648   1211   2055   3202   3604
     256    600    615   1163   1971   3152   3612
     512    328    278    695   1272   2256   2978
    1024     94    140    281    543    960   2075  1.12 RAM
    4096     99    128    259    448   1016   1931
   16384    125    129    258    500    898   1863
   65536    125    114    257    500   1015   1898
      16   1.02   1.03   0.98   1.00   0.99   0.76
     256   0.96   0.97   1.00   0.96   0.99   0.90
   65536   0.99   0.88   1.02   1.02   1.01   1.10
Fast Fourier Transforms - There are two FFT benchmarks, the second one benefiting from being optimised to make better use of burst data transfers, with the procedures dependent of skipped sequential access. FFT sizes vary between 1K and 1024K, covering caches and RAM. Three copies are run using both single and double precision data, the middle ones used here, as best choice due to varying millisecond running times. Because of the latter, 3B/3B+ comparisons are not as constant as for other benchmarks, this being reflected in the different 64/32 bit comparisons provided below.
With running times of the smaller FFTs being less than a millisecond, that for the first few measurements can be extended with the CPU MHz scaling governor set as on demand. A performance setting is required to produce more acceptable results. An example is shown below.
                 FFT Benchmarks
    Size  -------- milliseconds --------
       K  Single  Double  Single  Double
                 scaling_governor
             performance      ondemand
       1    0.17    0.14    0.40    0.14
       2    0.38    0.32    0.93    0.32
       4    1.07    0.77    1.97    0.75
       8    2.13    1.89    4.64    1.76
      16    4.57    5.83    4.47    5.83
 #################### Compare 64 bit / 32 bit ######################
                RPi3           RPi3B+
  FFT1
   1 to 8    1.05    0.86    1.06    0.90
  16 to 128  1.17    0.83    1.14    1.06
 256 to 1M   1.26    0.88    1.58    1.13
 FFT3C
   1 to 8    1.24    0.89    1.17    0.88
  16 to 128  1.05    1.04    1.15    1.17
 256 to 1M   1.14    1.01    1.26    1.16
jahboater
Thu Apr 26, 2018 5:28 pm
NEON happily does double precision by the way (even VFP did), or have I missed something?
RoyLongbottom
Thu Apr 26, 2018 5:55 pm
I could not find any Intrinsics when I wrote the program, See the following with no sign of double or f64:
https://gcc.gnu.org/onlinedocs/gcc-4.8. ... nsics.html
jahboater
Thu Apr 26, 2018 7:00 pm
I don't know why there are no intrinsics for it. Perhaps because there are only two lanes - who knows.
Your link points to a GCC 4.8 doct which is very old - the current version of GCC is 7.3 with 8.1 due to be released next week.
The arm intrinsics doct. mentions double precision:-
http://infocenter.arm.com/help/topic/co ... cs_ref.pdf
A few seconds look at the "armv8 arm" shows that all the floating point instructions, both vector and scalar, accept double precision operands.
C7.2.42
FADD (vector)
Floating-point Add (vector). This instruction adds corresponding vector elements in the two source SIMD&FP
registers, writes the result into a vector, and writes the vector to the destination SIMD&FP register. All the values
in this instruction are floating-point values.
This instruction can generate a floating-point exception. Depending on the settings in FPCR, the exception results
in either a flag being set in FPSR or a synchronous exception being generated. For more information, see
Floating-point exceptions and exception traps on page D1-1899.
Depending on the settings in the CPACR_EL1, CPTR_EL2, and CPTR_EL3 registers, and the current Security state
and Exception level, an attempt to execute the instruction might be trapped.
Half-precision
ARMv8.2
31 30 29 28 27 26 25 24 23 22 21 20
0 Q 0 0 1 1 1 0 0 1 0
U
16 15 14 13 12 11 10 9
Rm
0 0 0 1 0 1
5 4
Rn
0
Rd
Half-precision variant
FADD <Vd>.<T>, <Vn>.<T>, <Vm>.<T>
Decode for this encoding
if !HaveFP16Ext() then UnallocatedEncoding();
integer
integer
integer
integer
integer
integer
d = UInt(Rd);
n = UInt(Rn);
m = UInt(Rm);
esize = 16;
datasize = if Q == '1' then 128 else 64;
elements = datasize DIV esize;
boolean pair = (U == '1');
Single-precision and double-precision
0 Q 0 0 1 1 1 0 0 sz 1
U
Rm
1 1 0 1 0 1
5 4
Rn
0
Rd
Single-precision and double-precision variant
integer
integer
integer
if sz:Q
integer
integer
integer
d = UInt(Rd);
n = UInt(Rn);
m = UInt(Rm);
== '10' then ReservedValue();
esize = 32 << UInt(sz);
ejolson
Fri Apr 27, 2018 6:00 am
Recently there has been a change in the default Pi 3B+ RAM settings from 500 MHz down to 450 MHz. I think the schmoo memory timings change as well between the two frequencies, so it's not clear which actually performs better in the end. Did the slower RAM data transfers for the 3B+ occur with the memory clock set to 500 MHz or 450 MHz?
jahboater
Fri Apr 27, 2018 7:32 am
Yes. At 450Mhz schmoo is off. If you set 500Mhz by hand, schmoo gets set to
sdram_schmoo=0x2000020
and you cannot override it ....
Is the schmoo setting increasing the drive level or relaxing the timings?
RoyLongbottom
Tue May 22, 2018 10:06 am
I have disassembled my MemSpeed type benchmarks to see why I thought that NEON was inapplicable for double precision calculations. As shown in the code below, there are calculations using intrinsic functions and normal four way unrolled C code. each of the four Vector Multiply Accumulate intrinsic statements should lead to execution of four multiplies and four adds (total of 16 floating point operations). The C code loop has four multiples and four adds, but the compilers might be expected to unroll this further, where appropriate (they didn’t - is there a parameter to force this?). This lead to the fastest speeds being produced by the intrinsics, using assembly code instructions shown below.
                         Program Code
   NEON Intrinsics                    MemSpeed and NEONSpeed C Code for Compilation
{                                     Single and Double Precision
   x41 = vld1q_f32(ptrx1);
   x42 = vld1q_f32(ptrx2);          for (m=0; m<kd; m=m+inc)
   x43 = vld1q_f32(ptrx3);          {
   x44 = vld1q_f32(ptrx4);            xn[m]   = xn[m]   + sumn * yn[m];
                                      xn[m+1] = xn[m+1] + sumn * yn[m+1];
   y41 = vld1q_f32(ptry1);            xn[m+2] = xn[m+2] + sumn * yn[m+2];
   y42 = vld1q_f32(ptry2);            xn[m+3] = xn[m+3] + sumn * yn[m+3];
   y43 = vld1q_f32(ptry3);          }
   y44 = vld1q_f32(ptry4);
   z41 = vmlaq_f32(x41, y41, c4);
   z42 = vmlaq_f32(x42, y42, c4);
   z43 = vmlaq_f32(x43, y43, c4);
   z44 = vmlaq_f32(x44, y44, c4);
   vst1q_f32(ptrx1, z41);
   vst1q_f32(ptrx2, z42);
   vst1q_f32(ptrx3, z43);
   vst1q_f32(ptrx4, z44);
   ptrx1 = ptrx1 + 16;
   ptry1 = ptry1 + 16;
   ptrx2 = ptrx2 + 16;
   ptry2 = ptry2 + 16;
   ptrx3 = ptrx3 + 16;
   ptry3 = ptry3 + 16;
   ptrx4 = ptrx4 + 16;
   ptry4 = ptry4 + 16;
NeonSpeed - At 32 bit working the Vector Multiply Accumulate intrinsic were directly converted to NEON vmla.f32 instructions using quad word registers. The 64 bit compiler converted the intrinsics to A64 instructions “Floating-point fused multiply-add to accumulator” , using 128 bit vector registers.
Next are instructions generated for normal C code, using neon and funsafe compiler directives at 32 bits and standard parameters at 64 bits, acting on single precision calculations. At 32 bits, a single SIMD NEON instruction is used - vfma.32 (Vector Fused Multiply Accumulate) with four calculations. At 64 bits, vfma is generated again. The difference in speed is apparent from using a single SIMD instruction in the loop, compared with four with intrinsics.
               NEON Speed Intrinsics
   32 Bit                             64 Bit
   1173 MFLOPS                        1277 MFLOPS
.L75:                               .L13:
   add     r0, r3, #48                ldr     q4, [x3, -16]
   add     ip, r3, #32                add     x3, x3, 64
   add     lr, r3, #16                ldr     q3, [x3, -64]
   add     r10, r2, #48               add     x1, x1, 64
   add     r7, r2, #32                ldr     q2, [x3, -48]
   add     r4, r2, #16                ldr     q1, [x3, -32]
   vld1.32 {d24-d25}, [r3]            cmp     x3, x2
   vld1.32 {d18-d19}, [r0]            ldr     q16, [x1, -64]
   vld1.32 {d20-d21}, [ip]            ldr     q7, [x1, -48]
   vld1.32 {d22-d23}, [lr]            ldr     q6, [x1, -32]
   vld1.32 {d26-d27}, [r2]            ldr     q5, [x1, -16]
   vld1.32 {d6-d7}, [r10]             fmla    v4.4s, v0.4s, v16.4s
   vld1.32 {d30-d31}, [r7]            fmla    v3.4s, v0.4s, v7.4s
   vld1.32 {d28-d29}, [r4]            fmla    v2.4s, v0.4s, v6.4s
   vmla.f32        q9, q3, q8         fmla    v1.4s, v0.4s, v5.4s
   vmla.f32        q10, q15, q8       str     q4, [x3, -80]
   vmla.f32        q11, q14, q8       str     q3, [x3, -64]
   vmla.f32        q12, q13, q8       str     q2, [x3, -48]
   add     r1, r1, #1                 str     q1, [x3, -32]
   add     r2, r2, #64                bne     .L13
   cmp     r1, r5
   vst1.32 {d24-d25}, [r3]
   vst1.32 {d22-d23}, [lr]
   add     r3, r3, #64
   vst1.32 {d20-d21}, [ip]
   vst1.32 {d18-d19}, [r0]
   bne     .L75
                    NEON Speed Normal
   -mfpu=neon-vfpv4
   -funsafe-math-optimizations        -march=armv8-a
   797 MFLOPS                         681 MFLOPS
   32 Bit                             64 bit
.L54:                                 .L37:
        vld1.32 {q9}, [r2]                    ldr     q0, [x0, x26]
        vld1.32 {q8}, [r3]                    add     w1, w1, 1
        add     r1, r1, #1                    ldr     q1, [x0, x28]
        add     r2, r2, #16                   cmp     w24, w1
        cmp     r1, r4                        fmla    v0.4s, v1.4s, v2.4s
        vfma.f32        q8, q9, q7            str     q0, [x0, x26]
        vst1.32 {q8}, [r3]                    add     x0, x0, 16
        add     r3, r3, #16                   bhi     .L37
        bcc     .L54
MemSpeed - Single Precision vs Double Precision - For the 32 bit version, using the NEON compiling parameter shown, NEON instructions were not generated, four scalar Floating-point multiply-accumulate (fmacs or fmacd) were produced instead, producing the slowest speeds.
Adding that funsafe parameter produced the same vfma.f32 NEON instruction as NeonSpeed for four single precision calculations. But four vfma.f64 were generated for double precision. Yes these are NEON instructions but SISD (Single Instruction Single Data), each with data in 64 bit scalar registers.
64 Bit MemSpeed - For the four sets of calculations, the fmla vector instructions were again produced, requiring two for double precision and speed closer to that from single precision calculations.
        MemSpeed 32 Bit Single and Double Precision
   Parameters -mfpu=neon-vfpv4
   Single Precision                   Double Precision
   MFLOPS 532                         mFLOPS 238
.L45:                               .L31:
   mov     ip, r2                     fldd    d5, [r2, #-24]
   flds    s15, [r3]                  fldd    d6, [r3, #-24]
   flds    s11, [ip]                  fldd    d7, [r3, #-16]
   flds    s12, [r3, #-12]            fldd    d4, [r3, #-8]
   flds    s13, [r3, #-8]             mov     r6, r2
   flds    s14, [r3, #-4]             fmacd   d6, d5, d8
   flds    s8, [r2, #-12]             fldd    d3, [r3]
   flds    s9, [r2, #-8]              add     r2, r2, #32
   flds    s10, [r2, #-4]             fstd    d6, [r3, #-24]
   fmacs   s15, s11, s30              fldd    d6, [r2, #-48]
   fmacs   s12, s8, s30               fmacd   d7, d6, d8
   fmacs   s13, s9, s30               fstd    d7, [r3, #-16]
   fmacs   s14, s10, s30              fldd    d7, [r2, #-40]
   add     r2, r2, #16                fmacd   d4, d7, d8
   fmrs    ip, s15                    fstd    d4, [r3, #-8]
   fsts    s12, [r3, #-12]            fldd    d7, [r6]
   fsts    s13, [r3, #-8]             fmacd   d3, d7, d8
   fsts    s14, [r3, #-4]             fmrrd   r8, r9, d3
   str     ip, [r3], #16   @ float    strd    r8, [r3], #32
   cmp     r3, r6                     cmp     r3, r1
   bne     .L45                       bne     .L31
      More MemSpeed 32 Bit Single and Double Precision
   Parameters -mfpu=neon-vfpv4 -funsafe-math-optimizations
   MFLOPS 695                         MFLOPS 236 MLOPS
.L44:                               .L28:
   vld1.64 {d16-d17}, [r3:64]         fldd    d17, [r2, #-24]
   vld1.64 {d18-d19}, [r1:64]         fldd    d16, [r3, #-24]
   add     r2, r2, #1                 fldd    d18, [r3, #-16]
   add     r1, r1, #16                vfma.f64        d16, d17, d8
   cmp     r4, r2                     mov     r4, r2
   add     r3, r3, #16                fldd    d17, [r3, #-8]
   vfma.f32        q8, q9, q7         add     r2, r2, #32
   vstr    d16, [r3, #-16]            fcpyd   d19, d16
   vstr    d17, [r3, #-8]             fldd    d16, [r3]
   bhi     .L44                       fstd    d19, [r3, #-24]
                                      fldd    d19, [r2, #-48]
                                      vfma.f64        d18, d19, d8
                                      fstd    d18, [r3, #-16]
                                      fldd    d18, [r2, #-40]
                                      vfma.f64        d17, d18, d8
                                      fstd    d17, [r3, #-8]
                                      fldd    d17, [r4]
                                      fmrrd   r4, r5, d16
                                      strd    r4, [r3], #32
                                      cmp     r3, r1
                                      bne     .L28
           MemSpeed 64 Bit Single and Double Precision
   Parameters - -march=armv8-a
   MFLOPS 726                         MFLOPS 602
.L56:                               .L34:
   ldr     q0, [x27, x0]              ldr     q5, [x2, 16]
   add     w1, w1, 1                  add     w1, w1, 1
   ldr     q1, [x23, x0]              ldr     q1, [x0, 16]
   cmp     w21, w1                    cmp     w28, w1
   fmla    v0.4s, v1.4s, v2.4s        ldr     q3, [x2], 32
   str     q0, [x27, x0]              add     x0, x0, 32
   add     x0, x0, 16                 ldr     q0, [x0, -32]
   bhi     .L56                       fmla    v1.2d, v5.2d, v2.2d
                                      fmla    v0.2d, v3.2d, v2.2d
                                      str     q1, [x0, -16]
                                      str     q0, [x0, -32]
                                      bhi     .L34
Later Compiler - I have been running my LAN/WiFi benchmark on the 3B+ and will be posting results next. Wifi did not work on Raspbian. I eventually download Raspbian Stretch to see if WiFi worked, and it did. This includes gcc 6. Recompiling MemSpeed with this made no difference to the floating point instructions generated by the earlier compiler.
RoyLongbottom
Thu Jun 14, 2018 12:01 pm
More Disassembly For MP-MFLOPS Benchmarks - up to 11.6 GFLOPS
The arithmetic operations executed are of the form x = (x + a) * b - (x + c) * d + (x + e) * f with 2 and 32 operations per input data word, using 1, 2, 4 and 8 threads. Data sizes are limited to three to use L1 cache, L2 cache and RAM at 12.8, 128 and 12800 KB (3200, 32000 and 3200000 single precision floating point words or half for double precision). Each thread uses the same calculations but accessing different segments of the data. The program checks for consistent numeric results, primarily to show that all calculations are carried out and can be run.
This benchmark was intended to demonstrate near maximum throughput using single precision floating point calculations. It nearly did on an Intel Core i7 CPU, compiled with gcc under Linux, obtaining 23 out of 32 MFLOPS/MHz with SSE instructions (4 cores, quad word registers, linked multiply and add). The latter arrangement (I believe) also applies to the ARM Cortex-A53 where, with the same efficiency, a Raspberry Pi 3B, at 1200 MHz, would be expected to achieve 27600 MFLOPS and a 3B+ 29900 MFLOPS, at 1300 MHz. For ARM, and probably Intel, as shown below, 20 instructions could be executed at the full speed, with 12 at half speed, nearly corresponding with the 72% (23*100/32) efficiency obtained with Intel.
Single Precision and Double Precision Raspberry Pi 3B+ MFLOPS results are show below for existing compiled 32 bit and 64 bit benchmarks and one that uses Single Precision NEON Intrinsic functions, then those from a new compilation using gcc 7. None achieve the levels of performance suggested above.
Performance using one and four threads is shown, along with the gain via the latter. Note that particularly four thread performance can vary significantly, sometimes influenced by higher temperatures [On a hot day, using 4 threads, CPU MHz reduced to 600 MHz when temperature was indicated as exceeding 55°C.]
     Raspberry Pi 3B+ MFLOPS at 32 Operations Per Data Word
                                             NEON
                  32 bit        64 bit      64 bit  64 bit gcc7
                  SP     DP     SP     DP     SP     SP     DP
     1 Thread    797    798   1793   1405   2999   2800   1403
     4 Threads  3134   3119   6981   4398  11563  10608   4492
     4T/1T      3.93   3.91   3.89   3.13   3.86   3.79   3.20
Source and Assembly Codes for these benchmarks runs are shown below. The 32 bit compilations uses 12 scalar add and multiply instructions and 10 using fused multiply accumulate NEON type, but limited to scalar operation (SISD - Single Instructions Single Data). All the others use NEON or 64 bit vector SIMD instructions (Multiple Data), carrying out four calculations simultaneously at single precision, with 128 operations in the execution loops, or half these at double precision. Each has its own variation of fused multiply and add or subtract instructions.
In the original single precision benchmarks, the NEON version produced significantly faster performance, where the compiler converted the 32 intrinsic calculating functions into 22 instructions, with those fused operations, and a total in-loop count of 27. Performance of the first 64 bit version was degraded through making use of only 12 vector registers, for a programming function involving 23 variables, necessitating frequent load instructions. The gcc 7 compiler made use of 25 vector registers with out of loop loads to achieve similar performance as the hand code NEON benchmark. Both the 64 bit double precision benchmarks included the higher efficient code, with external data loading, but best speed was, as expected, half that for single precision SIMD calculations.
   MP-MFLOPS on Raspberry Pi 3B+
   Function triadplus2
   for(i=0; i<n; i++)
   x[i] = (x[i]+a)*b-(x[i]+c)*d+(x[i]+e)*f-(x[i]+g)*h+(x[i]+j)*k
   -(x[i]+l)*m+(x[i]+o)*p-(x[i]+q)*r+(x[i]+s)*t-(x[i]+u)*v+(x[i]+w)*y;
    gcc 4.9 32 bit
   SP MFLOPS                          DP MFLOPS
   797 1t 3134 4T                     798 1T 3119 4T
.L21:                              .L21:
   flds      s23, [r3]                fldd      d17, [r1]
   fadds     s15, s8, s23             faddd     d16, d17, d2
   fadds     s24, s10, s23            faddd     d18, d17, d0
   fadds     s31, s6, s23             faddd     d25, d17, d4
   fadds     s30, s4, s23             faddd     d24, d17, d6
   fnmuls    s15, s15, s7             fnmuld    d16, d3, d16
   fadds     s29, s3, s23             faddd     d23, d17, d15
   fadds     s28, s1, s23             faddd     d22, d17, d13
   fadds     s27, s0, s23             faddd     d21, d17, d11
   vfma.f32  s15, s9, s24             faddd     d20, d17, d9
   fadds     s26, s17, s23            faddd     d19, d17, d31
   fadds     s25, s18, s23            vfma.f64  d16, d18, d1
   fadds     s24, s20, s23            faddd     d18, d17, d29
   fadds     s23, s21, s23            faddd     d17, d17, d27
   vfma.f32  s15, s5, s31             vfma.f64  d16, d25, d5
   vfma.f32  s15, s14, s30            vfms.f64  d16, d24, d7
   vfma.f32  s15, s2, s29             vfma.f64  d16, d23, d14
   vfma.f32  s15, s13, s28            vfms.f64  d16, d22, d12
   vfma.f32  s15, s16, s27            vfma.f64  d16, d21, d10
   vfma.f32  s15, s12, s26            vfms.f64  d16, d20, d8
   vfma.f32  s15, s19, s25            vfma.f64  d16, d19, d30
   vfma.f32  s15, s11, s24            vfms.f64  d16, d18, d26
   vfma.f32  s15, s22, s23            vfma.f64  d16, d17, d28
   fstmias   r3!, {s15}               fstmiad   r1!, {d16}
   cmp       r3, r2                   cmp       r1, r0
   bne       .L9                      bne      .L21
   gcc 6 64 bit
   SP MFLOPS                          DP MFLOPS
   1793 1T to 6981 4T                 1405 1T to 4398 4T
.L65:                               .L84:
   ldr     q16, [x2, x5]              ldr     q16, [x2, x0]
   add     w6, w6, 1                  add     w3, w3, 1
   ldr     q15, [sp, 64]              cmp     w3, w6
   cmp     w3, w6                     fadd    v15.2d, v16.2d, v14.2d
   ldr     q17, [sp, 80]              fadd    v17.2d, v16.2d, v12.2d
   ldr     q0, [sp, 112]              fmul    v15.2d, v15.2d, v13.2d
   fadd    v15.4s, v16.4s, v15.4s     fmls    v15.2d, v17.2d, v11.2d
   fmul    v15.4s, v15.4s, v17.4s     fadd    v17.2d, v16.2d, v10.2d
   ldr     q17, [sp, 96]              fmla    v15.2d, v17.2d, v9.2d
   fadd    v17.4s, v16.4s, v17.4s     fadd    v17.2d, v16.2d, v8.2d
   fmls    v15.4s, v17.4s, v0.4s      fmls    v15.2d, v17.2d, v31.2d
   ldr     q0, [sp, 128]              fadd    v17.2d, v16.2d, v30.2d
   fadd    v17.4s, v16.4s, v0.4s      fmla    v15.2d, v17.2d, v29.2d
   ldr     q0, [sp, 144]              fadd    v17.2d, v16.2d, v28.2d
   fmla    v15.4s, v17.4s, v0.4s      fmls    v15.2d, v17.2d, v0.2d
   ldr     q0, [sp, 160]              fadd    v17.2d, v16.2d, v27.2d
   fadd    v17.4s, v16.4s, v0.4s      fmla    v15.2d, v17.2d, v26.2d
   ldr     q0, [sp, 176]              fadd    v17.2d, v16.2d, v25.2d
   fmls    v15.4s, v17.4s, v0.4s      fmls    v15.2d, v17.2d, v24.2d
   ldr     q0, [sp, 192]              fadd    v17.2d, v16.2d, v23.2d
   fadd    v17.4s, v16.4s, v0.4s      fmla    v15.2d, v17.2d, v22.2d
   ldr     q0, [sp, 208]              fadd    v17.2d, v16.2d, v21.2d
   fmla    v15.4s, v17.4s, v0.4s      fadd    v16.2d, v16.2d, v19.2d
   ldr     q0, [sp, 224]              fmls    v15.2d, v17.2d, v20.2d
   fadd    v17.4s, v16.4s, v0.4s      fmla    v15.2d, v16.2d, v18.2d
   ldr     q0, [sp, 240]              str     q15, [x2, x0]
   fmls    v15.4s, v17.4s, v0.4s      add     x0, x0, 16
   ldr     q0, [sp, 256]              bcc     .L84
   ldr     q0, [sp, 272]
   ldr     q0, [sp, 288]
   fmls    v15.4s, v17.4s, v14.4s
   fadd    v17.4s, v16.4s, v13.4s
   fmla    v15.4s, v17.4s, v12.4s
   fadd    v17.4s, v16.4s, v11.4s
   fadd    v16.4s, v16.4s, v9.4s
   fmls    v15.4s, v17.4s, v10.4s
   fmla    v15.4s, v16.4s, v8.4s
   str     q15, [x2, x5]
   add     x5, x5, 16
   bhi     .L65
   gcc6 neon
   SP MFLOPS                          C code
   2999 1T to 11563 4T              for(i=0; i<n; i=i+4)
.L41:                               {
   ldr     q1, [x1]                   x41 = vld1q_f32(ptrx1);
   ldr     q0, [sp, 64]               z41 = vaddq_f32(x41, a41);
   fadd    v18.4s, v20.4s, v1.4s      z41 = vmulq_f32(z41, b41);
   fadd    v17.4s, v22.4s, v1.4s      z42 = vaddq_f32(x41, c41);
   fadd    v0.4s, v0.4s, v1.4s        z42 = vmulq_f32(z42, d41);
   fadd    v16.4s, v24.4s, v1.4s      z41 = vsubq_f32(z41, z42);
   fadd    v7.4s, v26.4s, v1.4s       z42 = vaddq_f32(x41, e41);
   fadd    v6.4s, v28.4s, v1.4s       z42 = vmulq_f32(z42, f41);
   fadd    v5.4s, v30.4s, v1.4s       z41 = vaddq_f32(z41, z42);
   fmul    v0.4s, v0.4s, v19.4s       z42 = vaddq_f32(x41, g41);
   fadd    v4.4s, v10.4s, v1.4s       z42 = vmulq_f32(z42, h41);
   fadd    v3.4s, v12.4s, v1.4s       z41 = vsubq_f32(z41, z42);
   fadd    v2.4s, v14.4s, v1.4s       z42 = vaddq_f32(x41, j41);
   fadd    v1.4s, v8.4s, v1.4s        z42 = vmulq_f32(z42, k41);
   fmls    v0.4s, v21.4s, v18.4s      z41 = vaddq_f32(z41, z42);
   fmla    v0.4s, v23.4s, v17.4s      z42 = vaddq_f32(x41, l41);
   fmls    v0.4s, v25.4s, v16.4s      z42 = vmulq_f32(z42, m41);
   fmla    v0.4s, v27.4s, v7.4s       z41 = vsubq_f32(z41, z42);
   fmls    v0.4s, v29.4s, v6.4s       z42 = vaddq_f32(x41, o41);
   fmla    v0.4s, v31.4s, v5.4s       z42 = vmulq_f32(z42, p41);
   fmls    v0.4s, v9.4s, v1.4s        z41 = vaddq_f32(z41, z42);
   fmla    v0.4s, v4.4s, v11.4s       z42 = vaddq_f32(x41, q41);
   fmls    v0.4s, v3.4s, v13.4s       z42 = vmulq_f32(z42, r41);
   fmla    v0.4s, v2.4s, v15.4s       z41 = vsubq_f32(z41, z42);
   str     q0, [x1], 16               z42 = vaddq_f32(x41, s41);
   cmp     x1, x0                     z42 = vmulq_f32(z42, t41);
   bne     .L41                       z41 = vaddq_f32(z41, z42);
                                      z42 = vaddq_f32(x41, u41);
                                      z42 = vmulq_f32(z42, v41);
                                      z42 = vaddq_f32(x41, w41);
                                      z42 = vmulq_f32(z42, y41);
                                      ptrx1 = ptrx1 + 4;
   gcc 7
   SP MFLOPS                          DP MFLOPS
   2800 1T to 10608 4T                1403 1T 4492 4T
.L51:                               .L44:
   ldr     q15, [x2, x3]              ldr     q15, [x3, x2]
   add     w4, w4, 1                  add     w4, w4, 1
   cmp     w4, w6                     cmp     w4, w5
   fadd    v0.4s, v15.4s, v14.4s      fadd    v7.2d, v15.2d, v14.2d
   fadd    v17.4s, v15.4s, v12.4s     fadd    v16.2d, v15.2d, v12.2d
   fmul    v0.4s, v0.4s, v13.4s       fmul    v7.2d, v7.2d, v13.2d
   fmls    v0.4s, v17.4s, v11.4s      fmls    v7.2d, v16.2d, v11.2d
   fadd    v17.4s, v15.4s, v10.4s     fadd    v16.2d, v15.2d, v10.2d
   fmla    v0.4s, v17.4s, v9.4s       fmla    v7.2d, v16.2d, v9.2d
   fadd    v17.4s, v15.4s, v8.4s      fadd    v16.2d, v15.2d, v8.2d
   fmls    v0.4s, v17.4s, v31.4s      fmls    v7.2d, v16.2d, v31.2d
   fadd    v17.4s, v15.4s, v30.4s     fadd    v16.2d, v15.2d, v30.2d
   fmla    v0.4s, v17.4s, v29.4s      fmla    v7.2d, v16.2d, v29.2d
   fadd    v17.4s, v15.4s, v16.4s     fadd    v16.2d, v15.2d, v28.2d
   fmls    v0.4s, v17.4s, v28.4s      fmls    v7.2d, v16.2d, v27.2d
   fadd    v17.4s, v15.4s, v27.4s     fadd    v16.2d, v15.2d, v26.2d
   fmla    v0.4s, v17.4s, v26.4s      fmla    v7.2d, v16.2d, v25.2d
   fadd    v17.4s, v15.4s, v25.4s     fadd    v16.2d, v15.2d, v24.2d
   fmls    v0.4s, v17.4s, v24.4s      fmls    v7.2d, v16.2d, v23.2d
   fadd    v17.4s, v15.4s, v23.4s     fadd    v16.2d, v15.2d, v22.2d
   fmla    v0.4s, v17.4s, v22.4s      fmla    v7.2d, v16.2d, v21.2d
   fadd    v17.4s, v15.4s, v21.4s     fadd    v16.2d, v15.2d, v20.2d
   fadd    v15.4s, v15.4s, v19.4s     fadd    v15.2d, v15.2d, v18.2d
   fmls    v0.4s, v17.4s, v20.4s      fmls    v7.2d, v16.2d, v19.2d
   fmla    v0.4s, v15.4s, v18.4s      fmla    v7.2d, v15.2d, v17.2d
   str     q0, [x2, x3]               str     q7, [x3, x2]
   add     x3, x3, 16                 add     x2, x2, 16
   bcc     .L51                       bcc     .L44
RoyLongbottom
Fri Jun 29, 2018 9:44 am
Slow 3B+ Multithreading Performance - Temperature or Power?
On running my multithreading benchmarks, I noted unusual slow performance from certain tests. The first was the Whetstone benchmark, with independent copies of the program, using 1, 2, 4 and 8 threads. Then, the running time should not increase much using up to 4 threads, but should be just over twice as long using 8. As shown in the example below, the 4 thread test was too slow and this was particularly due to the long running COS test.
  MP-Whetstone Benchmark armv8 64 Bit Mon Jun 18 23:09:29 2018
                    Using 1, 2, 4 and 8 Threads
      MWIPS MFLOPS MFLOPS MFLOPS   Cos   Exp     Fixpt      If  Equal
                 1      2      3  MOPS  MOPS   ## MOPS    MOPS   MOPS
 1T  1112.9  352.1  379.0  319.2  22.0  12.7 1641076.6  2722.5 1328.7
 2T  2250.7  717.5  767.4  656.4  44.5  25.5 2684285.1  5456.3 2652.7
 4T  2899.0 1342.3 1525.3 1048.1  42.6  46.1 1959513.0  4497.3 4319.1
 8T  3433.1 1654.1 1804.6 1106.4  55.2  47.8 2453184.1 10960.3 4994.0
   Overall Seconds   5.14 1T,   5.11 2T,   8.08 4T,  13.66 8T
  ## over optimised but always had little effect on overall MWIPS
A (not official) 2.5 amp power supply was used and this was connected via a digital meter that measures current and voltage. During the tests, this reported constant over 5 volts and less than 1 amp. I suspected overheating and ran my RPiHeatMHz program at the same time, producing the results below and showing that the CPU MHz flipped into 600 MHz at the time of slow recorded performance. Although the temperature was not excessive. I carried out further tests with the system wrapped in bags of frozen food. The failures still occurred with recorded temperatures of less than 30°C.
 Temperature and CPU MHz Measurement
 Start at Mon Jun 18 23:09:26 2018
 Using 40 samples at 1 second intervals
 Seconds
    0.0     1400 scaling MHz,   1400 ARM MHz, temp=55.8'C
    1.0     1400 scaling MHz,   1400 ARM MHz, temp=55.8'C
    2.2     1400 scaling MHz,   1400 ARM MHz, temp=55.8'C
    3.3     1400 scaling MHz,   1400 ARM MHz, temp=56.4'C 1T
    4.5     1400 scaling MHz,   1400 ARM MHz, temp=56.9'C
    5.7     1400 scaling MHz,   1400 ARM MHz, temp=56.9'C
    6.9     1400 scaling MHz,   1400 ARM MHz, temp=56.9'C
    8.0     1400 scaling MHz,   1400 ARM MHz, temp=57.5'C 2T
    9.2     1400 scaling MHz,   1400 ARM MHz, temp=58.0'C
   10.4     1400 scaling MHz,   1400 ARM MHz, temp=58.0'C
   11.7     1400 scaling MHz,   1399 ARM MHz, temp=59.1'C
   12.9     1400 scaling MHz,   1400 ARM MHz, temp=59.1'C 4T
   14.1     1400 scaling MHz,    600 ARM MHz, temp=59.1'C
   15.4     1400 scaling MHz,    600 ARM MHz, temp=59.1'C
   16.8     1400 scaling MHz,    600 ARM MHz, temp=58.0'C
   18.3     1400 scaling MHz,   1400 ARM MHz, temp=60.1'C
   19.6     1400 scaling MHz,   1400 ARM MHz, temp=60.7'C
   20.8     1400 scaling MHz,   1400 ARM MHz, temp=61.2'C
   22.0     1400 scaling MHz,   1400 ARM MHz, temp=61.8'C 8T
   23.3     1400 scaling MHz,    600 ARM MHz, temp=60.1'C
   24.9     1400 scaling MHz,    600 ARM MHz, temp=60.1'C
   26.4     1400 scaling MHz,   1400 ARM MHz, temp=60.7'C
   27.6     1400 scaling MHz,   1400 ARM MHz, temp=61.2'C
   To
   38.8     1400 scaling MHz,   1400 ARM MHz, temp=60.1'C
Next, I tried using my official Pi 2 amp power supply and that seemed to be fine, but caused the failures when the meter was included, needing connection using a longer wire. It also failed when just the wire extension was included.
The above benchmarks were the 64 bit variety, run via Gentoo. So next, I ran the 32 bit program via Raspbian. That ran successfully using the 2.5 amp power supply, with the meter monitoring demands. There was also no problem using the 2 amp unit, but note that the 32 bit benchmark is slightly slower than the 64 bit version. However, it did fail after including the power extension cable.
I have ordered an official 2.5 amp power supply and will see how it goes.
ejolson
Sat Jun 30, 2018 2:26 am
I hear fresh-frozen garden peas are the best kind of food to use for SOC cooling. Did you provide any protection to prevent short circuits from condensation?
davidcoton
Sat Jun 30, 2018 9:13 am
Doesn't the W(h)etstone benchmark need some water? :lol:
Don't try it at home :roll:
Signature retired
RoyLongbottom
Sat Jun 30, 2018 10:28 am
I didn't need to as I used the above then ran the Dhrystone Benchmark.
RoyLongbottom
Thu Jul 26, 2018 2:42 pm
Raspberry Pi 3B+ Multithreading Benchmarks
This is a summary of 32 bit and 64 bit results on Rpi 3B and 3B+, run via Raspbian Stretch and the latest version of 64 bit Gentoo
Full details are available at ResearchGate in:
Except for the OpenMP benchmarks, all run using 1, 2, 4 and 8 threads, executing common code. One and four thread results are provided here.
This has an overall rating in MWIPS, mainly dependent on floating point calculations shown under MFLOPS, Cos MOPS and Exp MOPs, with the latter MOPS currently having the most impact. Each thread used dedicated variables to provide best case multithreading speeds.
Based on MWIPS, in all cases, 4 thread performance was around four times single thread performance and 3B+ speed about 17% faster than that for 3B, proportional to CPU MHz ratio (1400/1200). Test functions are too simple to be helped much by advanced architecture, leading to 64 bit benchmark average performance being 6% faster than the 32 bit compilation.
                     1      2      3  MOPS  MOPS      MOPS    MOPS   MOPS
 32 Bit
 3B  1T   924.2  335.9  276.8  298.5  18.5  10.4    5817.2  1035.3  719.4
     4T  3718.4 1286.3 1303.9 1193.5  74.3  41.5   19961.4  4698.4 2862.7
 3B+ 1T  1084.2  391.0  384.9  348.6  21.7  12.1    6967.0  1013.1  822.3
     4T  4343.8 1540.9 1558.3 1389.5  86.6  48.4   27529.5  5549.8 3338.5
 64 Bit
 3B  1T   979.8  330.4  322.9  281.5  20.0  10.8 1368033.3  2335.5 1177.1
     4T  3914.5 1206.2 1295.8 1122.2  78.3  44.3 3007162.3  9230.2 4636.6
 3B+ 1T  1151.6  383.0  382.7  327.6  23.2  13.0 1717931.5  2720.5 1364.5
     4T  4579.6 1505.5 1525.7 1304.4  92.0  51.6 4647842.5 10777.1 5448.5
   ######### over optimised but little effect on MWIPS rating
MP-Dhrystone Benchmark
This runs multiple copies of the whole program at the same time. Dedicated data arrays are used for each thread but there are numerous other variables that are shared. The latter can reduce performance gains via multiple threads and, in some cases, these can be slower than using a single thread (not in this case).
Comparisons are shown below, as expected 3B+/3B, MP performance not good, 64 bit faster than 32 bit - additional registers provide more options for optimisation (or over optimisation for which this benchmark is notorious).
Rating in VAX MIPS aka DMIPS
Threads        1        2        4        8    4T/1T
32 Bit
3B          2338     3956     5730     5780     2.45
3B+         2694     4720     6716     6729     2.49
3B+/3B      1.15     1.19     1.17     1.16
64 Bit
3B          3622     5752     6290     6359     1.74
3B+         4198     6158     7354     7411     1.75
3B+/3B      1.16     1.07     1.17     1.17
64/32 bit
3B          1.55     1.45     1.10     1.10
3B+         1.56     1.30     1.09     1.10
MP-Linpack Benchmark
The original Linpack benchmark, operates on double precision floating point 100x100 matrices (N = 100). This version uses NEON intrinsic functions with single precision calculations. It is run run on 100x100, 500x500 and 1000x1000 matrices and includes a test without threading overheads. The benchmark was produced to demonstrate that the original Linpack 100x100 code could not be converted (by me) to show increased performance using multiple threads. The official line is that users are allowed to use their own linear equation solver for this purpose. These Raspbian tests were carried out under the later Stretch release.
Performance can vary somewhat with this benchmark but reflects the usual 3B+ speed gains, at least on averaging all results. On the same basis, average 64 bit speeds are suggested as being the same as those at 32 bits, but some indicate slower performance. Similar performance could be expected as the compiled code is derived from high level NEON SIMD vector functions.
The poor performance, even using a single thread, is due to the frequent starting and stopping of threads to execute the critical calculations. Consistent threaded speed indicates shared data write back to RAM dependency. This probably increases with larger matrices as more calculations are carried out during a threaded function call.
Threads      None        1        2        4
32 bit 3B
 N  100     542.22    61.00    60.67    60.74
 N  500     480.55   311.06   316.00   303.48
 N 1000     364.07   272.49   231.10   232.07
32 bit 3B+
 N  100     633.11    70.82    70.13    70.20
 N  500     505.37   323.24   326.81   327.73
 N 1000     378.29   337.34   337.01   337.80
64 bit 3B
 N  100     551.48    87.43    81.66    82.68
 N  500     359.51   258.43   242.92   255.61
 N 1000     296.11   281.75   279.20   282.71
64 bit 3B+
 N  100     639.82   100.30    95.24    95.25
 N  500     430.41   292.80   291.12   290.04
 N 1000     349.47   313.59   312.38   313.40
MP-BusSpd Benchmark
This runs integer read only tests using caches and RAM, each thread accessing the same data sequentially, in this case, each thread starts reading from different addresses. To start with, data is read with large address increments to demonstrate burst data transfers. Below are results for reading all data.
Most striking is the poor relative performance of the 64 bit version, with data from L1 caches. this is due to the compile options used, with the 32 bit program using four way multiple data vector instructions, but with the 64 bit compiler producing single data scalar. Using the later gcc 7 compiler made no difference.
The usual 3B+/3B gains can be assumed to apply, along with 4 core / 1 core throughput increases from cache based data, with those from RAM indicting some improvement.
MB/Second Reading All Data, 1, 2, 4, 8 Threads
 KB and         32 Bit          64 Bit
 Theads       3B     3B+      3B     3B+
 12.3  1T   4223    4928    1492    1731
       2T   8159    9648    2928    3404
       4T  15720   18252    5346    5524
       8T  13789   16504    5016    5780
 122.9 1T   3934    4565    1470    1694
       2T   7686    8962    2932    3408
       4T  13860   15935    5261    6781
       8T  13125   15826    5271    6250
 12288 1T   1906    2085    1024    1048
       2T   1978    2126    1590    2025
       4T   2135    2338    1546    1623
       8T   2158    2488    1821    2018
MP-RandMem Benchmark
The benchmark has cache and RAM read only and read/write tests using sequential and random access, each thread accessing the same data but starting at different points. Although performance via the L1 cache, L2 cache and RAM can be different, it is normally consistent, in each of these areas, during read/write tests.
On all tests, 3B+/3B performance gains were as expected for cache based results, with averages between 1.6 and 1.7, with RAM performance being similar. Read only MP gains were mainly greater than 3.5 times for cache tests, except on random access to L2, at around 2.4 times, understandably lower using a shared cache. There were also some MP increased throughput using RAM. Raspbian based results indicate slightly improved performance over those using 64 bit Gentoo.
                MB/Second Using 1, 2, 4 and 8 Threads
            3B 32 Bit                         3B+ 32 Bit
      KB    SerRD   SerRW   RndRD   RndRW     SerRD   SerRW   RndRD   RndRW
 12.3 1T     4078    3814    4018    3798      4747    4447    4776    4435
      2T     8045    3768    8043    3777      9253    4362    9378    4362
      4T    15622    3724   15625    3730     18114    4343   18080    4322
      8T    15208    3723   15020    3724     17813    4345   17788    4321
122.9 1T     3289    3393     827     891      3871    3893     948    1016
      2T     6556    3379    1512     880      7612    3954    1742    1021
      4T    12125    3364    2078     886     14399    3929    2383    1025
      8T    12309    3364    2042     886     14089    3935    2367    1023
12288 1T     1669     878      65      64      1850     860      67      68
      2T     3485     872     121      65      3670     867     126      67
      4T     4296     876     146      65      4097     874     146      68
      8T     2435     878     147      65      2919     873     148      68
            3B 64 Bit                         3B+ 64 Bit
 12.3 1T     4260    3071    4261    3081      4939    3573    4941    3574
      2T     7500    3054    7496    3059      8730    3553    8704    3545
      4T    15092    3018   14794    3019     17121    3499   17197    3498
      8T    14315    2977   14544    2989     16685    3454   17097    3471
122.9 1T     3385    2861     867     837      3936    3347    1014     975
      2T     6323    2653    1543     838      7334    3344    1794     976
      4T    10638    2873    2009     835     12475    3333    2281     973
      8T    10810    2841    1947     834     12261    3314    2323     974
12288 1T     1607     746      71      60      1921     793      77      63
      2T     1605     696     123      59      1896     784     113      58
      4T     1939     766     129      58      1621     707     126      58
      8T     1682     681     141      58      1302     764     106      57
The benchmarks carry out calculations using 2 and 32 floating point operations per data word read. The latter is of the form form x = (x + a) * b - (x + c) * d + (x + e) * f + ............), to take advantage of linked multiply and add instructions that, with SIMD, could produce 32 single precision MFLOPS per MHz (4 words at a time x 4 cores x 2 for linked instructions). The same benchmark, compiled with gcc Linux, obtains 23 MFLOPS/MHz on an Intel Core i7 four core processor, using SSE instructions, but it is not clear what theoretical sustained rate that could be obtained on a Raspberry Pi 3.
There are three each of 32 bit and 64 bit programs provided, Single Precision (SP), Double Precision (SP) and one using NEON Intrinsic Functions (SP). A fourth variation was produced using OpenMP, that also includes tests using 8 operations per word. Each thread uses the same calculations but accessing different segments of the data. The program checks for consistent numeric results, primarily to show that all calculations are carried out and can be run. The standard format is shown below.
           MP-MFLOPS Gentoo RPi 3B+ 64 Bit
   MP-MFLOPS armv8 64Bit Wed Apr 25 10:22:43 2018
   FPU Add & Multiply using 1, 2, 4 and 8 Threads
        2 Ops/Word              32 Ops/Word
 KB     12.8     128   12800    12.8     128   12800
 MFLOPS
 1T      824     763     380    1793    1795    1704
 2T     1620    1577     404    3584    3588    3324
 4T     2093    2933     387    6981    6843    4189
 8T     2481    2263     409    6851    6391    2944
 Results x 100000
 1T    76406   97075   99969   66015   95363   99951
 2T    76406   97075   99969   66015   95363   99951
 4T    76406   97075   99969   66015   95363   99951
 8T    76406   97075   99969   66015   95363   99951
         End of test Wed Apr 25 10:22:48 2018
Calculations show that the usual 3B+ performance gains were produced on all benchmarks and that maximum performace was always using 32 operations per word. Indications of maximum performance from the various benchmarks is provided below, where most MP gains are reasonable. Best case was using NEON Intrinsic Functions at 8.26 MFLOPS/MHz (a long way from 32). Note the 64/32 bit speed gains with the original benchmarks. These are typical for all tests, excluding those wit RAM based data.
The original 32 bit versions converted the 32 operations into 22 scalar instructions, with 10 fused multiply accumulate type. The 64 bit variations unrolled the execution loop to include 128 operations, comprising 22 four way vector instructions, but speed of the original versions were degraded through using too few registers with too many register loads. A new 64 bit program is now provided, compiled with gcc 7, and this provides the same order of performance as the NEON benchmark, using 25 vector registers (4 way SP) with out of loop loads.
                                         NEON               64 bit OpenMP
              32 bit        64 bit      64 bit  64 bit gcc7  gcc6   gcc7
              SP     DP     SP     DP     SP     SP     DP     SP     SP
 1 Thread    813    798   1793   1405   2999   2800   1403   1692   [email protected]
 4 Threads  3189   3109   6981   4398  11563  10608   4492   6469  10007
 4T/1T      3.92   3.90   3.89   3.13   3.86   3.79   3.20   3.82   3.60
OpenMP Benchmarks
These benchmarks use OpenMP complier directives and programming options to automatically spread the load over multiple CPUs or Cores. Two benchmarks are provided, one named notOpenMP-name, that is compiled from the same code without using OpenMP options, to provide single core performance.
OpenMP-MFLOPS Benchmark
This benchmark carries out the same calculations as the MP-MFLOPS Benchmarks but, in addition, calculations with eight operations per data word. As indicated in the above table, recompiling with gcc 7 produced similar performance as the best C version. Note, these benchmarks are from the same code as the Linux PC versions, with higher memory demands than MP-MFLOPS, starting at 400 KB, L2 cache size. Below are single and multi-core 64 bit 3B+ results, indicating that MP performance was much slower when RAM data was involved.
Comparisons are also provided, indicating the usual 3B+/3B performance gains, at least on using a single core. Respectable MP gains were obtained at 64 bits but less so at 32 bits. The latter leads to indications that 64 bit working is faster on multi-tasking, but the detail shows that 32 bit speeds are faster using a single core.
            notOpenMP MFLOPS64 GCC7 Mon Jul  9 11:28:16 2018
  Test             4 Byte  Ops/   Repeat    Seconds   MFLOPS       First   All
                    Words  Word   Passes                         Results  Same
 Data in & out     100000     2     2500   0.646220      774    0.929538   Yes
 Data in & out    1000000     2      250   1.199940      417    0.992550   Yes
 Data in & out   10000000     2       25   1.158499      432    0.999250   Yes
 Data in & out     100000     8     2500   1.049060     1906    0.957117   Yes
 Data in & out    1000000     8      250   1.403440     1425    0.995518   Yes
 Data in & out   10000000     8       25   1.375663     1454    0.999549   Yes
 Data in & out     100000    32     2500   2.876464     2781    0.890215   Yes
 Data in & out    1000000    32      250   3.176167     2519    0.988088   Yes
 Data in & out   10000000    32       25   3.171387     2523    0.998796   Yes
                End of test Mon Jul  9 11:28:33 2018
           OpenMP MFLOPS64 GCC7 Mon Jul  9 11:25:46 2018
 Data in & out     100000     2     2500   0.250953     1992    0.929538   Yes
 Data in & out    1000000     2      250   1.185075      422    0.992550   Yes
 Data in & out   10000000     2       25   1.194995      418    0.999250   Yes
 Data in & out     100000     8     2500   0.332016     6024    0.957117   Yes
 Data in & out    1000000     8      250   1.182464     1691    0.995518   Yes
 Data in & out   10000000     8       25   1.157733     1728    0.999549   Yes
 Data in & out     100000    32     2500   0.799423    10007    0.890215   Yes
 Data in & out    1000000    32      250   1.260969     6344    0.988088   Yes
 Data in & out   10000000    32       25   1.196507     6686    0.998796   Yes
                End of test Mon Jul  9 11:25:55 2018
                                Comparisons
              Raspbian 32 Bit      Gentoo 64 Bit        Gentoo 64 Bit gcc 7
                3B    3B+  3B+/3B    3B    3B+  3B+/3B    3B    3B+  3B+/3B
 8 Ops/Wd
 1 Core       1723   2005   1.16   1623   1892   1.17   1654   1906   1.15
 4 Cores      4485   5071   1.13   5713   6504   1.14   5893   6024   1.02
 4/1 Cores    2.60   2.53          3.52   3.44          3.56   3.16
 32 Ops/Wd
 1 Core       1592   1857   1.17   1461   1692   1.16   2395   2781   1.16
 4 Cores      1858   2420   1.30   5493   6469   1.18   8722  10007   1.15
 4/1 Cores    1.17   1.30          3.76   3.82          3.64   3.60
OpenMP-MemSpeed Benchmark
This is the same as the single core Memory Speed Benchmark, with similar results to NotOpenMP varieties, but with measurements extending to test more memory, with 16 sets of results between 4 KB and 128 MB. Floating point and integer calculations are carried out as indicated in the table headings. Samples of results are provided below, covering L1 cache, L2 cache and RAM based data.
Comparing characteristics provides wide ranges of variations. The 3B+/3B ratio was almost entirely in the expected 1.6 to 1.7 ratio for L1 cache data, but with some significant differences via L2 cache and RAM. On comparing MP performance, the most noticeable were many at half speed with integer arithmetic. Then, 32 bit Raspbian produced more than three times increase on double precision calculations and twice at single precision. The 64 bit Gentoo floating MP gains were around 1.5 times. These strange results were highlighted in 64/32 bit comparisons, where the former tended to be faster standalone but slower in MP mode. Alternative compilations might be of interest.
                                 Raspbian 32 Bit
Pi 3B Not
       8    1594   2547   3811   2388   3469   3812   2717   2716   2716
      16    1595   2553   3825   2393   3478   3825   2728   2728   2728
      64    1508   2300   3304   2177   3065   3303   2542   2485   2485
     128    1515   2305   3353   2183   3108   3356   2644   2573   2574
   32768     928   1166   1206   1119   1224   1206    760    746    746
   65536     970   1171   1210   1140   1225   1212    811    810    808
Pi 3B OMP
       8    6068   3107   1382  10109   5056   1486  16438   8104   1258
      16    5739   3119   1317  10193   5114   1393  16624   7862   1220
      64    5416   3055   1303   8618   4928   1403  12254   8045   1218
     128    5396   3050   1359   9101   4932   1379   9496   8089   1249
   32768    3351   2499   1080   2089   3216   1437   1005   1001    794
   65536    3820    614   1026   3901   3078   1209   1006   1008    954
Pi 3B+ Not
       8    1860   2973   4449   2787   4047   4447   3169   3169   3170
      16    1862   2978   4463   2791   4058   4462   3137   3183   3182
      64    1753   2664   3806   2526   3541   3805   3016   3028   3046
     128    1776   2721   3968   2574   3683   3965   3073   2989   2989
   32768     939   1218   1205   1192   1219   1213    909    864    864
   65536    1052   1221   1216   1197   1214   1213    905    870    869
Pi 3B+ OMP
       8    6142   3447   1613  11721   5857   1721  19080   9581   1465
      16    6315   3608   1568  11687   5911   1699  19295   9528   1468
      64    5795   3522   1456  10640   5718   1627  14169   9392   1397
     128    5657   3542   1485  10485   5713   1588  11330   9181   1398
   32768    1388   2107   1090   4044   3099   1355    941    933   1358
   65536    2576   1750   1159   2296   3825   1661    943    971   1509
                               Gentoo 64 Bit
Pi 3B Not
       8    3935   2507   4155   5339   3399   4168   4646   3730   3732
      16    3857   2506   4171   5358   3417   4155   4680   3744   3751
      64    3074   2242   3416   3956   2940   3438   4432   3635   3618
     128    3042   2274   3495   3933   3008   3492   4209   3488   3498
   32768     529   1059    939   1106    975    898    695    701    495
   65536    1095    986   1017    990   1104    694    682    686    625
Pi 3B OMP
       8    6064   3205   1690   9310   4858   1824  10003   5704   2052
      16    3584   3228   1634   8855   4902   1742  10164   5598   1856
      64    3697   2665   1563   8723   4798   1655  10674   5331   1758
     128    2947   3206   1672   8900   4841   1618   9060   5456   1768
   32768     605    792   1562   1143   2709   1019    899    861    591
   65536    1312    555   1163   3974    803   1181    908    833    780
Pi 3B+ Not
       8    4625   2906   4828   6167   3957   4828   5384   4307   4318
      16    4624   2902   4840   6203   3954   4838   5422   4347   4332
      64    3857   2704   4232   4873   3589   4202   5002   4121   4122
     128    3899   2760   4371   4906   3720   4373   5030   4079   4111
   32768     498   1107   1064   1197   1202   1135    799    649    763
   65536    1176   1060   1165   1177   1203   1230    588    959    963
Pi 3B+ OMP
       8    7385   3728   1976   8941   5652   2107  13290   6637   2392
      16    7099   3769   1945  11092   5751   2105  11593   2798    993
      64    1432   1264    801   4343   2345    852   3740   2531    914
     128    4476   3711   1812   9677   5654   2070   4091   2665    846
   32768     777   1994   1471   1223   1269   1800    958    945    790
   65536    1736   1275   1271   1006   1249   1787    869    980   1293
RoyLongbottom
Thu Sep 13, 2018 10:45 am
Raspberry Pi 3B+ Stress Tests
I have finished running my benchmarks on the Raspberry Pi 3B+. A full report is available from ResearchGate:
https://www.researchgate.net/publicatio ... ationTitle
The last programs run were my Stress Tests that, at least, identify the 3B+ thermal characteristics. These are single core programs with input parameters for duration and test selection, with multiple copies run for maximum loading, and an updated monitor, measuring CPU MHz, temperature and core voltage. The main programs are one running integer arithmetic, another with floating point and My OpenGL program. The first exercise was with the 3B+ card installed in a plastic case, with no heatsink on the CPU.
Following is an example results from my monitoring program, whilst running four copies of the integer stress test program. These are instantaneous samples that can vary up and down within the sampling period. Above 70°C, CPU frequency is reduced from 1.4 GHz to 1.2 GHz, when core voltage is also reduced. Later thermal throttling is applied on reaching 80°C, in this case, occasionally reducing sample MHz to 1087.
 Temperature and CPU MHz Measurement  Start at Tue Jul 31 21:14:36 2018
 Seconds
    0.0     1400 scaling MHz,   1400 ARM MHz, core volt=1.3438V, temp=58.0°C
   16.0     1400 scaling MHz,   1400 ARM MHz, core volt=1.3500V, temp=65.0°C
   32.5     1400 scaling MHz,   1400 ARM MHz, core volt=1.3563V, temp=69.3°C
   49.1     1400 scaling MHz,   1200 ARM MHz, core volt=1.3563V, temp=70.4°C
   65.6     1400 scaling MHz,   1199 ARM MHz, core volt=1.2375V, temp=70.9°C
   82.1     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=71.4°C
   98.7     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=72.0°C
  115.2     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=73.1°C
  131.7     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=74.1°C
  148.3     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=74.1°C
  164.9     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=74.7°C
  181.5     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=75.2°C
  197.9     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=75.2°C
  214.4     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=75.2°C
  230.9     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=76.3°C
  247.5     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=77.4°C
  264.0     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=77.4°C
  280.5     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=77.4°C
  297.1     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=77.4°C
  313.6     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=77.4°C
  330.1     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=77.4°C
  346.7     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=78.4°C
  363.2     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=78.4°C
  379.8     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=78.4°C
  396.4     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  413.0     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  429.6     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  446.1     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  462.6     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  479.2     1400 scaling MHz,   1195 ARM MHz, core volt=1.2375V, temp=80.1°C
  495.9     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  512.3     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  528.8     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  545.3     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  561.8     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=78.4°C
  578.3     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.0°C
  594.9     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=79.5°C
  611.6     1400 scaling MHz,   1195 ARM MHz, core volt=1.2375V, temp=79.5°C
  628.1     1400 scaling MHz,   1195 ARM MHz, core volt=1.2375V, temp=79.5°C
  644.6     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=80.6°C
  661.1     1400 scaling MHz,   1200 ARM MHz, core volt=1.2375V, temp=80.6°C
  677.6     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.1°C
  694.2     1400 scaling MHz,   1194 ARM MHz, core volt=1.2375V, temp=80.6°C
  710.7     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.6°C
  727.3     1400 scaling MHz,   1195 ARM MHz, core volt=1.2375V, temp=80.6°C
  743.8     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.6°C
  760.3     1400 scaling MHz,   1087 ARM MHz, core volt=1.2375V, temp=80.1°C
  776.8     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.6°C
  793.3     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.6°C
  809.8     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.6°C
  826.3     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=81.1°C
  842.9     1400 scaling MHz,   1087 ARM MHz, core volt=1.2375V, temp=80.6°C
  859.5     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.6°C
  876.0     1400 scaling MHz,   1087 ARM MHz, core volt=1.2375V, temp=81.1°C
  892.5     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.6°C
  909.1     1400 scaling MHz,   1140 ARM MHz, core volt=1.2375V, temp=80.6°C
  925.6     1400 scaling MHz,   1087 ARM MHz, core volt=1.2375V, temp=81.1°C
  942.2     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=80.6°C
  958.7     1400 scaling MHz,   1141 ARM MHz, core volt=1.2375V, temp=81.1°C
Integer Stress Tests
This has 12 tests using different data patterns, 6 of them Write/Read and 6 read only, performance being measured in MB/second. In this case, each test has the same running time, set at 80 seconds (overall 16 minutes), for this test. Below are 32 bit and 64 bit results from the 3B+, where the former is somewhat faster. There were "Cool" and "Hot" runs (room 3 °C to 4°C higher). All show CPU frequency throttling, below 1 GHz with the "Hot" tests, with similar reductions in measured performance.
           Multiply MB/second by four for overall performance
           Cool              Hot               Cool              Hot
           MB/s   MHz    °C  MB/s   MHz    °C  MB/s   MHz    °C  MB/s   MHz    °C
 Write/Read      1400  44.0        1400  59.1        1400  47.8        1399  65.5
        1  3699  1400  68.2  3240  1200  75.2  2927  1400  69.8  2589  1200  78.4
        2  3415  1200  70.9  3297  1200  79.0  2611  1200  70.9  2509  1141  81.1
        3  3218  1200  72.9  3247  1195  80.6  2536  1200  72.0  2375  1087  81.7
        4  3299  1200  73.1  3045  1141  81.1  2525  1200  75.2  2302  1034  81.7
        5  3288  1200  75.2  2929  1087  81.7  2533  1200  75.8  2263  1034  81.7
        6  3291  1200  76.3  2882  1033  81.7  2533  1200  77.4  2231  1034  81.7
 Read
        1  3620  1200  75.8  3343  1141  81.7  2832  1200  77.4  2646  1141  81.7
        2  3602  1200  78.4  3153  1034  81.7  2841  1200  78.4  2539  1034  81.7
        3  3592  1195  79.5  3015   980  82.2  2829  1195  80.1  2470  1034  81.7
        4  3567  1141  80.5  2938   926  82.2  2790  1141  80.6  2444  1033  82.2
        5  3500  1141  80.6  2922   980  82.7  2733  1141  80.6  2414  1034  82.2
        6  3432  1087  80.6  2876   980  82.2  2679  1087  80.1  2152   980  82.2
Average    3460  1197  76.0  3074  1075  81.0  2697  1197  76.5  2411  1066  81.5
1 Core     4065  1400        4065  1400        3168  1400        3168  1400
%Av/1 Core   85    86          76    77	         85    86          76    76
Start                  44.0              59.1              47.8              65.5
Max                    80.6              82.7              80.6              82.2
Floating Point Stress Tests
The program uses single precision floating point calculations, with run time options for the number of operations per data word read/written and data size, in this case, 8 operations per word and 16 KB for L1 cache use. A summary of results is below. This time, the 64 bit version is the faster (up to 17.4 GFLOPS from 4 cores). "Cool" and "Hot" test results are again provided, not particularly comparable with those for the integer tests, but suggesting slightly less performance degradation. All exceeded 70°C but the "Cool" 64 bit test did not suffer from 80°C thermal throttling.
          Multiply MFLOPS by four for overall performance
          Cool              Hot               Cool              Hot
          MFLOPS  MHz    °C MFLOPS  MHz    °C MFLOPS  MHz    °C MFLOPS  MHz    °C
Average    2945  1212  75.7  2833  1168  78.7  3809  1227  71.8  3690  1203  77.4
1 Core     3439  1400        3439  1400        4360  1400        4360  1400
%Av/1 Core   86    87          82    83	         87    88          85    86
Start                  47.8              55.8              45.1              61.2
Max                    80.1              81.7              76.3              80.1
OpenGL Stress Test
My OpenGL benchmark can also be included in stress testing, with a choice of window size, test function and running time. The detailed results PDF report shows that the Tiled Kitchen test produced the highest loading, along with performance being faster, using the 64 bit benchmark. Running a second 15 minute “Hot Test”, the latter, showed rapid varying speed between 20 and 18 FPS, with CPU frequency sometimes reducing to 1200, and maximum temperature of 70.9°C. VMSTAT measurements indicated that more than one CPU core was being used (average utilisation 116%).
OpenGL Extended Power Cable
After noting slow CPU benchmark performance whilst using an extended power cable, the procedure was repeated running the OpenGL test, when performance immediately reduced to 8 FPS, with the following recorded decreases in CPU MHz to 600 and core voltage to 1.2. The Pi 3B+ deserves a commendation for actually running in these circumstances (a permanent way of running cool?).
 Seconds
    0.0     1400 scaling MHz,   1400 ARM MHz, core volt=1.2000V, temp=52.6°C
    1.0     1400 scaling MHz,    600 ARM MHz, core volt=1.2000V, temp=52.6°C
    2.4     1400 scaling MHz,    600 ARM MHz, core volt=1.2000V, temp=52.6°C
OpenGL + 3 CPU Stress Tests Gentoo 64 Bit
Further 15 minute tests were carried out, running the OpenGL program at the same time as three CPU tests. Below are summaries of results, comprising a “Hot Test” using the plastic enclosure, with “Cool and Hot” using a FLIRC aluminium case, with the built in efficient CPU heat sink. “Hot” indicates a second run shortly after a “Cool” test.
Using the plastic case, 80°C thermal throttling again occurred, during both integer and floating point tests. Speeds of the latter appeared to be worse than when four copies of the program were run. Perhaps the high OpenGL CPU utilisation involved heavy use of floating point instructions.
With the FLIRC case, the CPU cores were running at 1400 MHz continuously during “Cool” sessions, the 5% per core reduction in performance being typical when running multiprocessor tests. During the “Hot” tests there was no thermal throttling, but there were instances of the 1200 MHz when 70°C was reached (not necessarily noted in instantaneous sample).
          MB/second and MFLOPS are for each core
          Integer + OpenGL
          Plastic Case            FLIRC Case Cool         FLIRC Case Hot
          MB/sec   MHz  FPS   °C  MB/sec   MHz  FPS   °C  MB/sec   MHz  FPS   °C
Average     2376  1093 14.9  80.0   3025  1400 18.9  59.6   2954  1387 18.4  68.8
1 Core      3168  1400   20         3168  1400   20         3168  1400   20
%Av/1 Core    75    78   74           95   100   95           93    99   92
Start                        55.8                    37.6                    53.7
Max                          82.7                    67.6                    70.4
          Floating Point + OpenGL
          MFLOPS   MHz  FPS   °C  MFLOPS   MHz  FPS   °C  MFLOPS   MHz  FPS   °C
Average     2880  1137 10.5  79.8   4162  1400 18.4  64.4   4096  1393 18.8  66.8
1 Core      4360  1400   20         4360  1400   20         4360  1400   20
%Av/1 Core    66    81   53           95   100   92           94    99   94
Start                        66.1                    46.2                    50.5
Max                          82.2                    69.3                    69.8
RoyLongbottom
Re: Raspberry Pi Benchmarks
Fri Sep 21, 2018 10:55 am
Graphics and Input/Output Benchmarks
The 32 bit and 64 bit versions of these benchmarks have been run on a 3B+, the latter via Gentoo. Full details, results and 3b+/3B comparisons are provided in the following ResearchGate report:
LAN and WiFi Benchmark
This message provides a summary of LAN and WiFi tests via Raspbian Stretch, an upgrade to this being required to avoid communication complications. The benchmark measures writing and reading performance of large files, small files and random access. Three large files, in two sizes, are written and read (default 8 and 16 MB). A run time parameter is provided to indicate the number of MB (1048576 bytes) for the first set, the second ones doubling up. Maximum file size for, 32 bit Raspbian, was found to be less than 2048 MB (or less than 1024 input parameter for the whole program to run).
The following results are via Pi 3B+ connections to a PC using Windows 7 and to a PC with dual boot options to Windows 10 and Linux Ubuntu, and from 3B to Windows 7. Average 3B+ to 3B performance gains are shown.
Large Files - Performance using the 3B+ was reasonably consistent using the various platforms and providing significant gains over 3B. Writing/Reading speeds of 3B+, via LAN, equate to around 320/230 Mbits per second and 110/85 with WiFi. The latter can be compared with 62/15.5 download/upload using SpeedTest, the same as a phone with 5 GHz WiFi capabilities (2.4 GHz phone obtained 28/13 Mbps and current smart hub broadband sync speeds are 70.47/16.62).
Random Access - Note slowest performance communicating with Windows 10 and fastest to Linux/Ubuntu, using the same PC.
Small Files - Performance did not vary much over the systems tested (using 3B+) . Speeds in MB/second are shown for one test, to illustrate how slow data transfers can be, using numerous small files.
                       16 MB Files MBytes/Second               Average Gain
         Write1   Write2   Write3    Read1    Read2    Read3   Write   Read
 LAN
 3B >W7   11.42    11.44    11.44    11.67    11.67    11.67
 3B+>W7   35.46    36.18    36.22    25.79    25.74    25.59    3.14   2.20
 3B+>W10  35.55    35.95    36.00    26.95    26.95    27.65
 3B+>Ubu  34.58    34.46    34.54    27.19    27.29    27.28
 WiFI
 3B >W7    4.96     5.07     5.06     5.23     6.76     6.63
 3B+>W7   11.34    13.82    14.14     8.98     9.97     9.77    2.60   1.54
 3B+>W10  11.24    13.78    14.19     8.67    10.22     8.57
 3B+>Ubu  11.31    13.30    13.62    10.72    13.25     8.93
 Random         Read milliseconds          Write milliseconds   Average Gain
 1KB From MB    4        8       16        4        8       16   Read  Write
 LAN
 3B >W7     0.014    0.685    0.829     1.49     1.22     1.35
 3B+>W7     0.005    0.659    0.857     0.85     0.91     0.99   1.00   1.48
 3B+>W10    0.005    0.660    1.118    11.79    12.84    14.38
 3B+>Ubu    0.005    0.019    0.456     0.49     0.49     0.49
 WiFi
 3B >W7     3.360    3.445    3.654     3.64     3.39     3.35
 3B+>W7     2.275    2.755    2.782     2.93     2.68     2.76   1.34	1.24
 3B+>W10   10.197    6.838    2.785    20.95    18.85    16.46
 3B+>Ubu    2.429    2.778    2.829     1.39     1.39     1.39
 200 Files    Write ms/file           Read ms/file       Delete  Average Gain
 File KB      4       8      16       4       8      16    secs   Read  Write
 LAN
 3B >W7    4.60    4.42    6.08    2.61    3.22    5.20   0.547
 3B+>W7 ## 3.30    3.38    3.68    2.29    2.03    2.71   0.385   1.46   1.57
 3B+>W10   4.49    4.41    4.81    2.15    2.34    2.54   0.274
 3B+>Ubu   5.00    5.02    5.33    2.41    2.72    4.19   0.311
 WiFi
 3B >W7   13.80   15.00   18.23   12.20   16.37   14.66   2.616
 3B+>W7   10.36   11.25   11.22    9.91   10.64   11.11   1.910   1.43   1.37
 3B+>W10  11.18   11.91   13.13   10.03   10.52   11.22   1.259
 3B+>Ubu  13.46   13.46   14.05   24.57   11.88   12.19   1.509
 MB/sec ## 0.40    0.73    1.46    0.41    0.77    1.47
ejolson
Fri Sep 21, 2018 5:07 pm
If I understand these results correctly, the 3B+ write speeds are faster than the read speeds. This seems consistent with previously reported properties of the 3B+ hardware.
Are these benchmarks for SMB/CIFS filesystems or NFS? I wonder how SSHFS compares, as that is what PiNet uses for home directories.
RoyLongbottom
Sat Sep 22, 2018 11:56 am
For these in house benchmarks, run from the Raspberry Pi, remote drives were mounted using CIFS. The program generates data once for sending, with repetitive data transfers. These are written to the mounted drive, where actual writing might be deferred, with measured time only reflecting that for data transmission.
Besides the results shown here, a Windows EXE version is provided that can be executed from a remote PC. SAMBA has to be installed on the RPi (so is SMB/CIFS used?). Following are repeated Raspbian results for large files, along with those measured on PCs via Windows, plus one CIFS mounted from Linux Ubuntu.
For the latter, note that reading was faster than writing (RPi transmission faster than reception). With Windows control, speeds were more inconsistent and writing was faster than reading, the latter being particularly slow. {more confusion now!).
 LAN
 W7 >3B+  25.67    25.34    16.71    11.49     8.77     7.09
 W10>3B+  25.02    16.97    16.93    11.44     8.66     6.97
 Ubu>3B+  27.52    27.49    27.59    38.91    39.01    39.08
RoyLongbottom
Fri Mar 29, 2019 11:04 am
High Performance Linpack Benchmark and Stress Tests
Along with others in 2016 and later, I found that running the HPL benchmark on the Raspberry Pi 3 could result in incorrect numeric results and system crashes. See:
Pi3 incorrect results under load (possibly heat related)
viewtopic.php?f=63&t=139712
My results here
viewtopic.php?p=1022010#p1026831
Pi3B+ Hopefully Correct Results Under Load
viewtopic.php?p=1287237
I have now run two versions of the benchmarks on Raspberry Pi 3B and 3B+, via Raspbian Jessie and Stretch. These were an old precompiled version and one that I generated that uses ATLAS, with alternative Basic Linear Algebra Subprograms. The latter took 14 hours to build from scratch, including hundreds of MFLOPS speed tuning calculations. Although a later compiler was used, performance was slower than the original. Full details and numerous results are at ResearchGate in:
https://www.researchgate.net/publicatio ... rror_Tests
Results provided include MFLOPS speed plus CPU MHz, core voltage and temperature.
The benchmarks were run using multiple data sizes, with parameters specified to use 1, 2 and 4 cores. Results from the older Pi 3B are below. The tets were repeated specifying a higher voltage in the boot configuration file, a suggested fix to avoid failures. Without the power boost (Normal), failures occurred at all data sizes, but only using all four cores. Failures also occurred with the boost (Volts+), but using the largest data size. An exception being via the slower ATLAS/Stretch combination.
                       Old Pi 3B Performance, Errors and Crashes
            Stretch Original HPL      Jessie  Original HPL      Stretch ATLAS HPL
            Normal       Volts+       Normal       Volts+       Normal       Volts+
  N  Cores  MFLOPS Sumck MFLOPS Sumck MFLOPS Sumck MFLOPS Sumck MFLOPS Sumck MFLOPS Sumck
 1000  1        80   OK      79   OK      82   OK      78   OK     970   OK     978   OK
 1000  2       178   OK     159   OK     158   OK     177   OK    1124   OK    1097   OK
 1000  4      2468  NO*    2477   OK    2494  NO*    2512   OK    1390  NO*    1385   OK
       4      2426  NO*    2479   OK    2464   OK    2527   OK    1385   OK    1374   OK
       4                   2445   OK    2524   OK    2499   OK    1387   OK    1362   OK
 2000  1       221   OK     222   OK     219   OK     225   OK    1139   OK    1142   OK
 2000  2       506   OK     439   OK     472   OK     496   OK    1609   OK    1613   OK
 2000  4     CRASH         3727   OK    3804  NO*    3799   OK    2159  NO*    2226   OK
       4      3775  NO*    3799   OK    3747   OK    3810   OK    2259  NO*    2260   OK
       4                   3782   OK    3826  NO*    3797   OK    2267  NO*    2215   OK
 4000  1       602   OK     598   OK     601   OK     601   OK    1294   OK    1292   OK
 4000  2      1298   OK    1311   OK    1310   OK    1057   OK    2039   OK    2025   OK
 4000  4     CRASH         4831   OK   CRASH         4864   OK   ERROR         3077   OK
       4     CRASH         4813   OK   CRASH         4873   OK   CRASH         3119   OK
       4                   4736   OK                 4777   OK                 3142   OK
 8000  1      1085   OK    1088   OK    1094   OK    1096   OK    1358   OK    1354   OK
 8000  2      1996   OK    2009   OK    2036   OK    2027   OK    2278   OK    2355   OK
 8000  4     CRASH         5056  NO*   CRASH        CRASH        ERROR         3514   OK
       4                                                         CRASH         3620   OK
       4        3665   OK
         NO*   SumCheck  such as  86232467 5841191 or 1281583765 12822
          OK   See 3B+ Sumcheck results
       ERROR   Fatal error indication
       CRASH   Frozen display  reboot required
As for the Pi 3B+ tests, the system board is in FLIRC case, with its built in heatsink that minimises CPU temperature. Failures occurred at small data sizes that finished before high temperatures could be reached. The table below shows temperatures using the largest data size, with a failure at relatively low temperature and power boost tests with no failures at high temperatures.
                     Raspberry Pi 3B High Temperatures
     Original HPL CRASH       Original HPL              ATLAS HPL
     Normal Volts             Over Volts                Over Volts
     MHz   Volts      °C       MHz   Volts      °C       MHz   Volts      °C
    1200  1.2563    44.5      1200  1.3188    52.6      1200  1.3188    59.1
    1200  1.2563    48.3      1200  1.3188    61.2      1200  1.3188    61.2
    1200  1.2563    50.5      1200  1.3188    65.5      1200  1.3188    65.5
    1200  1.2563    51.5      1200  1.3188    68.8      1200  1.3188    65.5
    1200  1.2563    51.5      1200  1.3188    70.9      1200  1.3188    67.7
    1200  1.2563    53.2      1200  1.3188    71.4      1199  1.3188    67.7
                              1200  1.3188    73.1      1200  1.3188    68.8
                              1200  1.3188    74.1      1200  1.3188    69.3
                              1200  1.3188    75.2      1200  1.3188    70.4
                              1200  1.3188    76.8      1199  1.3188    70.4
                              1200  1.3188    76.3      1200  1.3188    70.9
                              1200  1.3188    77.4      1200  1.3188    71.4
                              1200  1.3188    78.4      1200  1.3188    72.5
                              1200  1.3188    79.0      1200  1.3188    72.5
                              1200  1.3188    79.0      1200  1.3188    72.0
                              1200  1.3188    79.5      1200  1.3188    73.1
                              1200  1.3188    79.5      1199  1.3188    73.6
                              1200  1.3188    75.2      1200  1.3188    73.6
                              1200  1.3188    71.4      1200  1.3188    73.6
Running the same test procedures on a Pi 3B+ did not produce any failures but, initially, performance via Raspbian Stretch could be slower than Jessie. Temperatures only reached less than 63°C but the Stretch system reduced CPU voltage and MHz at 60°C, compared with the original specification of 70°C. Another booting option fixed this, when it was eventually discovered. Details of results are below where XXX is Stretch without the limit=70 setting.
            Inconsistent Four Core Performance (samples over test periods)
  ------- Stretch Original -------   --------- Stretch ATLAS ---------   Jessie Original
  MFLOPS       5063           5607                 3120           3914           5311
  XXX                   limit=70      XXX                   limit=70
                      All 1400 MHz                        All 1400 MHz   All 1400 MHz
  Volts   MHz    °C    Volts    °C    Volts   MHz    °C    Volts    °C    Volts    °C
 1.3500  1400  53.7   1.3563  49.4   1.3500  1400  56.9   1.3563  53.7   1.3875  53.7
 1.3500  1400  57.5   1.3563  49.9   1.3500  1400  60.1   1.3563  55.8   1.3875  56.9
 1.3500  1399  58.0   1.3563  55.9   1.2563  1200  60.1   1.3563  58.0   1.3875  58.0
 1.3500  1400  59.1   1.3563  59.1   1.2563  1200  60.1   1.3563  60.7   1.3875  58.5
 1.3500  1400  59.1   1.3563  60.1   1.2563  1200  60.7   1.3563  62.3   1.3875  59.1
 1.2563  1200  59.6   1.3563  61.2   1.2563  1200  60.1   1.3563  62.3   1.3938  60.1
 1.3500  1400  59.1   1.3563  62.3   1.2563  1200  60.1   1.3563  62.3   1.3938  60.7
 1.3500  1200  60.1   1.3563  62.3   1.2563  1200  60.1   1.3563  62.8   1.3938  60.7
 1.2563  1200  59.1   1.3563  62.8   1.2563  1200  60.1   1.3563  63.4   1.3938  61.2
 1.2563  1200  60.1   1.3563  63.4   1.2563  1200  60.1   1.3563  62.8   1.3938  62.3
 1.3500  1200  59.6   1.3563  63.9   1.2563  1199  60.7   1.3563  63.4   1.3938  62.3
Stress Tests
In view of the Pi 3B failures, I decided to see if I could reproduce similar problems running my floating point stress test program, using four copies to saturate all CPU cores. Experiments showed that I could produce data comparison failures and system crashes, when each program was allocated 160 KB memory, to overfill shared L2 cache. No failures occurred during Pi 3B+ tests but, to start with, performance was degraded due to the slower CPU MHz at 60°C.
As shown in the ResearchGate report, numerous failures occurred during tests on the older Pi 3B, apparently affected by CPU temperature above 71°C and total MFLOPS throughput, that was probably influenced by variable RAM accesses. As in other tests, there were unexpected small variations in recorded voltages, in one Pi 3B case, increasing following a reboot, still with high temperatures, but no failures.
The same stress test, compiled for 64 bit operation, was run via Gentoo, leading to errors and crashes on the Pi 3B but not on the 3B+ (details are in the ResearchGate Report).
ejolson
Sat Mar 30, 2019 6:23 pm
Thanks for the confirmation, rerunning these tests on 64-bit and the detailed report.
While the observed susceptibility of the Pi 3B to transients when the 3.3V power steps up to handle all four cores at full load was solved with the 3B+ update, the 3B+ seems to have introduced its own set of problems including some unexpected failures in the field where the 3.3V power supplied by the new MxL7704 power circuit doesn't come up at all. I hope the Pi 4 will be properly stress tested before it goes into full production.
Given your confirmation of incorrect results and crashes under load, I wonder how Los Alamos National Labs have been fairing with their cluster of 750 Pi 3B computers.
https://www.lanl.gov/discover/news-rele ... rry-pi.php
https://www.zdnet.com/article/raspberry ... -software/
https://www.raspberrypi.org/magpi/bitsc ... -computer/
https://www.raspberrypi.org/blog/raspbe ... me-of-age/
Do you think the pilot project was ever expanded to the envisioned 10,000-node 40,000-core machine? Ideally 10,000 Pi's should produce more than 50 TFLOPs of double-precision floating-point performance on the Linpack benchmark. It would be interesting if someone involved provided an update concerning reliability, performance and uptimes.
RoyLongbottom
Mon Apr 01, 2019 11:15 am
Probably you have had the same problem, but I can’t find any reports about how the Los Alamos National Labs Raspberry Pi Cluster is behaving. The articles I have read indicate that the system is intended for use in developing software techniques that can be used on the expensive big brothers.
The following reference that you quoted indicates that a four Raspberry Pi 3s obtain an HPL score of 3.463 GFLOPS but performance of a single 4 core node was not mentioned, nor which versions of the benchmark packages were used. That speed is what I saw with my ATLAS version on one Pi 3 and, for the other version, I see over 5 GFLOPS.
https://www.raspberrypi.org/magpi/bench ... i-cluster/
It was indicated that Gigabit Ethernet would provide a lot higher speed, but that only runs at up to around 12.5 million DP words per second (for 10,000 nodes?). However, developing software to reduce this traffic might be well worth while and some real applications might be able to use the available processing power.
