Svenn
Cannot disable preview
Thu May 16, 2013 4:02 pm
I tired using the -n command as shown in the documentation but I cannot disable the preview. This is the command I am using:
raspistill -t 2000 -o image.jpg -n
Which gives me this error:
mmal: Unknown status error
mmal: main: Failed to connect camera to preview
Segmentation fault
tvjon
Re: Cannot disable preview
Thu May 16, 2013 6:10 pm
Same here. presumably that wasn't tested, as:
pi@raspberrypi ~ $ raspistill -n
Segmentation fault
pi@raspberrypi ~ $
pluggy
Thu May 16, 2013 6:12 pm
try :
raspistill -t 0 -o image.jpg -hf
Thu May 16, 2013 6:23 pm
Weird. Dom reported something like that but everything worked fine for me, so I wasn't able to say what the problem was. If preview is disabled, IIRC it shouldn't even try to connect the camera to the preview component...I'll take another look.
Thu May 16, 2013 6:44 pm
Ah, think I've found an uninitialised variable which explains why some people see the problem and other don't
Can someone who is seeing this problem and can recompile, correct line 1016 in RaspiStill.c as follows
   MMAL_STATUS_T status = MMAL_SUCCESS;
and report back if it fixes the problem. Ta.
tvjon
Thu May 16, 2013 9:40 pm
Line 1016 is the signal_handler function in the file I've downloaded.
Any pointers to the function where MMAL_STATUS_T status needs initialising?
It's init'd to -1 in main() for example.
MattHawkinsUK
Thu May 16, 2013 10:56 pm
I think it is line 984
   MMAL_STATUS_T status;
to
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
leol
Fri May 17, 2013 6:54 am
Did not work for me. I changed line 984. Got this warning on compiling:
[ 95%] Building C object host_applications/linux/apps/raspicam/CMakeFiles/raspistill.dir/RaspiStill.c.o
/home/pi/work/userland/host_applications/linux/apps/raspicam/RaspiStill.c: In function âencoder_buffer_callbackâ:
/home/pi/work/userland/host_applications/linux/apps/raspicam/RaspiStill.c:549:33: warning: âstatusâ may be used uninitialized in this function [-Wuninitialized]
When running I got::
pi@raspberrypi ~/work $ ./raspistill -n -v -o test.jpg
RaspiStill Camera App
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Preview No, Full screen Yes
Preview window 0,0,1024,768
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 400, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
Camera component done
Encoder component done
Starting component connection stage
Closing down
Segmentation fault
This was built on the Pi by the way.
Leo
Fri May 17, 2013 8:05 am
Sorry it should be line 1027 (almost the first line in the main () function).
I'd made the change before I did a git pull so my raspistill.c was slightly out of date from some changes DOm made.
leol
Fri May 17, 2013 8:46 am
Seems to be line 1034 and in my copy it is:
MMAL_STATUS_T status = -1;
I have changed the source but unfortunately my pi with the camera attached has crashed and I can't get to it until this evening. (I'm at work and Pi is at home!)
I'm getting these crashes quite a lot. Reading other threads I think it is a power issue. I will investigate this weekend.
Leo
Fri May 17, 2013 9:05 am
leol wrote:Seems to be line 1034 and in my copy it is:
Leo
Weird that it's got -1 and it's on a different line, that means my source tree is out of date, and yet is supposed to be the main dev tree....
-1 is certainly wrong.
m1m1
Fri May 17, 2013 9:29 am
I have changed it from -1 to MMAL_SUCCESS, compiled fine on the Pi and works, thanks.
tvjon
Fri May 17, 2013 10:10 am
Yes, that was the line I posted last night.
I'm slightly more awake now, & have just recompiled & confirm that does indeed work, no longer seg' faulting :)
I recompiled it on the Pi. I have yagarto on the mac, but have only used it for non-Pi ARM® code so far.
jamesh, thanks for the fix. Can you elaborate on your "unusual" cross compilation technique, or is it secret? :)
brendanwells
Fri May 17, 2013 11:19 am
I have git pulled the code and altered the line in question;
1034 MMAL_STATUS_T status = MMAL_SUCCESS;
But cannot get it to make?
How are you guys re-compiling this?
m1m1
Fri May 17, 2013 12:01 pm
Here is what worked for me (on the Pi, on Raspbmc):
sudo apt-get install git gcc build-essential cmake
git clone git://github.com/raspberrypi/userland.git
cd userland
sed -i 's/if (DEFINED CMAKE_TOOLCHAIN_FILE)/if (NOT DEFINED CMAKE_TOOLCHAIN_FILE)/g' makefiles/cmake/arm-linux.cmake
"sed -i 's/if (DEFINED CMAKE_TOOLCHAIN_FILE)/if (NOT DEFINED CMAKE_TOOLCHAIN_FILE)/g' makefiles/cmake/arm-linux.cmake"
is one command from double quote to double quote ;)
Change line 1034 in host_applications/linux/apps/raspicam/RaspiStill.c to:
then again in the userland dir:
mkdir build
cd build
sudo cmake -DCMAKE_BUILD_TYPE=Release ..
sudo make
sudo make install
brendanwells
Fri May 17, 2013 1:29 pm
You are a gentleman and a scholar, thankyou very much that worked great, well done to JamesH too for getting all this together! Will there be a fix in the repo's and for raspivid too?
mikerr
Fri May 17, 2013 1:34 pm
That's for that guide, m1m1 - I had to also install cmake:
sudo apt-get install cmake
and sudo'd your final line to
sudo make install
all worked like a charm from then and now disabling preview works fine.
Get my ready fixed binary here if you trust me ;)
wget https://www.dropbox.com/s/cu3aviqktx7xru9/raspistill
sudo cp /opt/vc/bin/raspistill /opt/vc/bin/raspistill.orig
sudo cp raspistill /opt/vc/bin/
Svenn
Fri May 17, 2013 3:15 pm
Thanks m1m1! That worked perfectly.
Fri May 17, 2013 3:17 pm
Not that unusual, I set up Eclipse to do cross compilation using the Linaro tools from the github tools, then tweaked all the includes and libraries in Eclipse to use github userland. The Foundation doesn't work that way, so it 'unusual' to them, just not to me! Problem is it doesn't move from machine to machine well due to Eclipse not allowing relative paths for tool chains (as far as I can tell)
Fri May 17, 2013 3:18 pm
I posted the fix so Dom has it now - I also got another fix for the problem with the --help option but haven't had time to look at the image being flipped problem yet.
Not sure how long it takes Dom to push any changes to github. Not long.
SN
Fri May 17, 2013 3:41 pm
for those not into recompilation, this little bodge works
a simple solution to the flickering on the screen (because -nopreview is broken) is to make the preview size very small and place it to the left and above the screen so only ONE pixel is updated on the console like so
/opt/vc/bin/raspistill -t 0 -w 1024 -h 768 -p -31,-23,32,24 -o -
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
Chris_Reynolds
Fri May 17, 2013 4:01 pm
Thanks for the build instructions m1m1, they're not quite working for me and wondered if anyone can help.
I get a 'fatal error: interface/vcos/vcos.h: No such file or directory'
All the userland stuff is on my Pi under ~/userland including that vcos.h so I'm guessing that the compiler doesn't know to use ~/userland or /home/pi/userland as a place to start looking for include files. I've never built anything like this under Debian before (my makefile knowledge stopped in about 1992 and was for Microsoft C 5.1) so before I start randomly hacking stuff in is there an obvious thing I need to do or set?
Many thanks.
towolf
Fri May 17, 2013 4:34 pm
raspivid has the same problem, how does the fix for that one look?
quagga
Fri May 17, 2013 6:16 pm
towolf wrote:raspivid has the same problem, how does the fix for that one look?
Do as above, but
Change line 852 in host_applications/linux/apps/raspicam/RaspiVid.c to:
m1m1
Fri May 17, 2013 6:32 pm
Thanks for the feedback, I've edited my post with your corrections.
Return to “Camera board”
