mdasrafulislam
How to disable monitor power saving option in Raspberry PI?
Thu May 16, 2013 6:11 am
I don't want that my monitor will go power saving option after sometime. I tried different option to stop power save option but none of them worked. I am using Raspberry wheezy soft float version.
Can anyone help me how I can configure this issue?
RaTTuS
Re: How to disable monitor power saving option in Raspberry
Thu May 16, 2013 6:53 am
what have you tried
editing /etc/kbd.config should be good enough unless you are running x
Covfefe
jojopi
Thu May 16, 2013 7:02 am
I think you will find that the screen is just blanking and not going into power save, since the latter does not appear to be implemented on the Pi. In any case, power saving is never enabled until after the screen has blanked or the screensaver activated, so it is only the blanking or screensaver timeout that you need to change.
You have not said whether you are using the text console or the X Window System. For the kernel console, just set BLANK_TIME=0 in /etc/kbd/config.
For X you can either install and configure a screensaver; disable the default screensaver with xset; or disable the default screensaver by options on the X server command. See this thread for details: http://www.raspberrypi.org/phpBB3/viewt ... p?p=180028
chorlton2080
Mon Jul 15, 2013 8:40 pm
I had the same problem on Ubuntu. I couldn't find an adequate fix so I used Xdotool to send a benign keystroke every 5 minutes using cron.
Can't check at this moment whether Xdotool is available on Wheezy, but if so that will be a solution to both Console and X screen blanking and screensavers.
jojopi
Thu Jul 18, 2013 9:45 pm
chorlton2080 wrote:Can't check at this moment whether Xdotool is available on Wheezy, but if so that will be a solution to both Console and X screen blanking and screensavers.
xdotool obviously will only work in X, and not on console. Along similar lines and much more portably, you could build a robot to physically press your shift key every couple minutes.
Seriously though, it is better, and really not difficult, to disable screen blanking instead of fighting against it.
chorlton2080
Thu Jul 18, 2013 9:55 pm
Yes. That makes sense. The clue is in the name: Xdotool.
I think it worked for me because I SSHd into Ubuntu whilst the X Session was running, with its resultant grip on the power saving features. This is not how Raspberry Pi users normally access the console.
B.Jay
Thu Jul 18, 2013 11:05 pm
If you want to prevent the blanking of the console:
sudo nano /etc/rc.local
ABOVE the "exit 0" line insert:
setterm -blank 0 -powerdown 0 -powersave off
The file should look like this:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
# Disable console blanking
exit 0
Save the file.
Either reboot or issue the command right away on the command line (don't forget to prefix "sudo").
That's it - the console won't blank.
Works for me on the latest Raspbian 7 Hard Float as well on Minibian (created by some forum user).
ds18s20
Sun Mar 02, 2014 7:21 pm
Ok I'm confused. Just for the console (exclude X from the discussion). Which one is it?
sudo nano /etc/rc.local or /etc/kbd.config
Was the previous suggestion to edit /etc/kbd.config a defective solution to the problem?
~B
RaTTuS
Mon Mar 03, 2014 9:29 am
ds18s20 wrote:Ok I'm confused. Just for the console (exclude X from the discussion). Which one is it?
~B
if you edit
/etc/kdb/config
and change BLANK_TIME=30 to 0
it will stop blanking
if you edit
/etc/rc.local
and add
setterm -blank 0
you will have to same effect
in unix [and linux] there are many ways to skin a cat
Covfefe
Return to “Advanced users”
