DarthTobias
Connecting to the Internet with ICS
Sat May 11, 2013 5:20 am
Hi all! ^_^
So i recently got my Model B Pi, but haven't been able to set it up on the internet yet.
Due to my location, i am unable to get Internet access in the conventional way, and only have a small laptop, an Ethernet cable and a Pre-Paid USB modem.
Could anybody outline how i would go about setting up ICS from my Windows 7 laptop to share my USB internet connection over Ethernet? Thanks in advance! ^_^
obcd
Re: Connecting to the Internet with ICS
Sat May 11, 2013 1:21 pm
Simply find a tutorial about how to share an internet connection on a pc with windows 7.
Instead of connecting a network, other pc's to the lan adapter, simply connect the Pi.
The PC should have a DHCP server running, so the Pi should receive a DHCP IP adress from it.
You can run ifconfig on the Pi to check that it got a valid ip on it's eth0 adapter.
lmarmisa
Sat May 11, 2013 7:59 pm
You have to configure static local IP addresses for the Ethernet subnet.
For example, you can assign 192.168.100.1 to Windows 7 and 192.168.100.2 to RPi.
I will explain how define both configs.
1) Config the Windows 7 USB modem interface.
Go to control panel -> network & sharing center -> manage network connections ->USB modem interface -> properties -> sharing
Tick -> Allow other network users to connect through this computer's internet connection
2) Config the Window 7 ethernet interface.
Go to control panel -> network & sharing center -> manage network connections -> local area connection -> properties -> networking -> Internet protocol v4 -> properties and select
Use the following IP address:
IP address: 192.168.100.1
Subnet mask: 255.255.255.0
3) RPI.
Copy the current file /etc/network/interfaces to /etc/network/interfaces.bak
sudo cp /etc/network/interfaces /etc/network/interfaces.bak
Edit the file /etc/network/interfaces
sudo nano /etc/network/interfaces
and change the contents to this:
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.100.2
netmask 255.255.255.0
network 192.168.100.1
broadcast 192.168.100.255
gateway 192.168.100.1
nameserver 8.8.8.8
Save, exit and reboot.
This link shows another example of ICS:
http://www.morrisville.edu/documents/te ... haring.pdf
elstcb
Thu Aug 15, 2013 3:50 pm
To get internet access you might need to add a route on the Pi to tell it how to access the outside world. e.g.
sudo route add default gw 192.168.137.1
Joe Schmoe
Thu Aug 15, 2013 5:55 pm
I don't understand why every time this question comes up, responders say that you need to configure static IP on the Pi. Nothing could be further from the truth.
In principle, this should be easy [Just setup ICS on the host PC's Internet-facing device and go!] - but of course, theory and practice often diverge.
In the past, I've had the problem where Windows, in its majesty, refused to let me share a "cellular modem" device (PCMCIA) because it thought that it was not a "high speed device" - that is, it thought it was just a puny little modem, and thus not worth sharing. My workaround for this was to install VMWare on the Windows box and run a Linux VM there. Then I setup the usual IPTABLES stuff under Linux to serve a local network, all driven off the cellular modem.
Another option (which I've never gotten to work very well) is "bridging" under Windows...
ravikanth3110
Thu Aug 15, 2013 8:24 pm
I tried as you have said. But could not get the internet up. can you suggest how to debug the issue..
Thanks in Advance.
ravikanth3110
Thu Aug 15, 2013 8:28 pm
Hi lmarmisa,
I followed the all the steps, but still could not make the internet up on my pi (via my Windiws 7 PC with USB dongle.)
Any furthur suggestions for debigging this issue??
smp
Mon Sep 16, 2013 6:27 am
Hi
Anyone has got the solution / updates for the subject line Post. Since I'm also facing the same issue. Could not connect to internet using Pi through Windows 7 ICS.
Ping between Pi and Win 7 laptop OK
Ping between Win 7 and Pi laptop OK
Ping from Win 7 to google (8.8.8.8) OK
Ping from Pi to www.google.com NOT OK - reply as ping: unknown host www.google.com
And for command
reply received as SIOCADDRT: Networks is unreachable
Thanks in advance,
