raspberryPI911
File sync 2 pi's, pc's and as file server
Thu May 09, 2013 8:52 pm
I own two Raspberry pi's type B (512 MB RAM),
The situation:
2 houses with one Pi each, So SECURE communication over the web;
pc's (windows and linux) in every house;
Main Goal:
use the Pi's as Backup/sync/file server
3 goals:
-> The Pi's have to backup selected folders from different pc's (pictures from pc1, music from pc2 etc)
-> The Pi's have to sync selected folders between different pc's
-> One of the pi's has to store data (movies) which can be played by xbmc (in both houses)
Requirements
- secure file transfer and storage (except for HD streaming)
- quick enough to watch full HD movies over the internet (internet connections are fast enough)
- stable solution
- All the files that have to be backuped should be stored on a location in both houses (for example on both raspberry PI's
Solutions?
- rsync over ssh
- sftp with a (update) script on all the pc's
- barracudaDrive (not open source)
- owncloud (slow)
Thanks in advance!
Last edited by raspberryPI911 on Sun May 12, 2013 4:19 pm, edited 1 time in total.
ghans
Re: File sync 2 pi's, pc's and as file server
Fri May 10, 2013 9:03 am
"Secure" means encryption , and that's generally not fast on
a Pi at all. Perhaps both your routers support an old type of
VPN , but else secure HD streaming might be simply out of reach.
ghans
raspberryPI911
Sun May 12, 2013 4:18 pm
That's a good point, changed the opening post
