Tue May 14, 2013 7:33 am
jasonjpeters wrote:I am having the same issue with this. if the power goes out, or I unplug the system while still running, the card will no longer boot unless I re-flash it.
Whilst genuine power failures "can't be helped", never just unplug power to the Pi, always shutdown cleanly first ("sudo shutdown -h now"), wait until all green LED activity has finished (no more writes to the SD card, usually 20 - 30 secs.) and only then switch-off the PSU - if you must unplug to do this do it at the "wall-wart" end rather than at the micro-usb connector. That way you reduce the chance of ending up with a corrupted SD card to almost zero. Of course, if the system hangs (equivalent to the Windows "blue screen of death") simply unplugging is the only way, but this is as a "last resort" not "normal practice".
Trev.
