I cant find the raspi-config. It is not in /usr/bin/ , can it be elswhere or can I replace it
kindly
Re: missing raspi-config
That's odd. Are you sure you're using one of the Raspbian distros?
I think you should be able to install it with
HTH
Dirk
sudo apt-get update
sudo apt-get install raspi-config
Dirk
- Contact: Website
Try the find command:
sudo find / -name 'raspi-config'
Yes I use, raspibmc distro.DirkS wrote:That's odd. Are you sure you're using one of the Raspbian distros?
I think you should be able to install it withHTHCode: Select all
sudo apt-get update sudo apt-get install raspi-config
Dirk
I have tryed
sudo apt-get update
but I get an error, that raspi-config cant be found
kindly
Preben
Unfortunately the way other distros work raspi-config is not compatible in many instances. That's why it can't be installed. Typically other settings will overwrite it if you did get it installed or it can break your installation. raspi-config if not installed by default is best to probably stay away from and find the way to change the settings on your setup. Raspbmc expands the disk by default it also sets ram split for a more optimized setup for xbmc the time is configured from setting within xbmc. With those examples your not missing anything by it not being installed.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
My problen is that I cant find a way to install a danish keybord layoutUnfortunately the way other distros work raspi-config is not compatible in many instances. That's why it can't be installed. Typically other settings will overwrite it if you did get it installed or it can break your installation. raspi-config if not installed by default is best to probably stay away from and find the way to change the settings on your setup. Raspbmc expands the disk by default it also sets ram split for a more optimized setup for xbmc the time is configured from setting within xbmc. With those examples your not missing anything by it not being installed.
Is that the keyboard layout for xbmc or for when you log in using SSH?
Not sure if you can change the layout used *inside* XBMC.
When you're logged in using SSH you can use
after this you need to reboot.
Gr.
Dirk.
sudo dpkg-reconfigure locales
sudo dpkg-reconfigure keyboard-configuration
Gr.
Dirk.
- Contact: Website
try
wget http://archive.raspberrypi.org/debian/pool/main/r/raspi-config/raspi-config_20121028_all.deb
wget http://http.us.debian.org/debian/pool/main/l/lua5.1/lua5.1_5.1.5-4_armel.deb
wget http://http.us.debian.org/debian/pool/main/t/triggerhappy/triggerhappy_0.3.4-2_armel.deb
dpkg -i triggerhappy_0.3.4-2_armel.deb
dpkg -i lua5.1_5.1.5-4_armel.deb
dpkg -i raspi-config_20121028_all.deb
Can't see the relevance of this. AFAICT the OP is just trying to get his keyboard to behave for which you really don't need any additional software.xXAzazelXx wrote:tryCode: Select all
wget http://archive.raspberrypi.org/debian/pool/main/r/raspi-config/raspi-config_20121028_all.deb wget http://http.us.debian.org/debian/pool/main/l/lua5.1/lua5.1_5.1.5-4_armel.deb wget http://http.us.debian.org/debian/pool/main/t/triggerhappy/triggerhappy_0.3.4-2_armel.deb dpkg -i triggerhappy_0.3.4-2_armel.deb dpkg -i lua5.1_5.1.5-4_armel.deb dpkg -i raspi-config_20121028_all.deb
And why would you install armel software on a armhf distro? The software seems to be available in the repo anyway and as such can be installed with a 'normal' apt-get.
Gr.
Dirk.
"Old" post, however....prefalch wrote:Yes I use, raspibmc distro.DirkS wrote:That's odd. Are you sure you're using one of the Raspbian distros?
Dirk
I have tryed
sudo apt-get update
kindly
Preben
I've tried on raspbmc and OpenElec yesterday; 2 things :
- I've chosen Raspbmc and not OpenElec because it's my choice (no reason except I feel it this way)
- During install of raspbmc (1st boot), RPi will reboot at least 3 times : 1st reboot is for expand the root partition (it seems) (others are for locales, keyboard, timezone, ...)
(depending on how you feel with linux), you could manually :
resize the mmcblk0p2 partition
change the locales
do a lot of other things
However I guess that editing the /etc/apt/sources.list could be useful to make apt-get working
I'll look at it this evening
Just one thing to consider if a distro seems to be missing something chances are it isn't there for a reason. How is apt-get not working?
raspi-config is a Raspbian tool it isn't much use inside of Raspbmc setting the keyboard layout for X won't help in XBMC files are missing and since it doesn't have an X Gui, etc..
Yes, we have to keep this in mind.malakai wrote:Just one thing to consider if a distro seems to be missing something chances are it isn't there for a reason.
And as I said, it is essential to remember a lot of thing (all, but all is not as easy as to change the keyboard layouts) could be configured, moded, tweaked by hand, I mean with a command-line
I think it comes down to there isn't always one setting to be changed. Keyboard and locale on the Pi seems a bit buggy at times many configs the first time around just don't want to save for some reason. And that has to be taken into consideration set save reboot. Hopefully the setting gets saved. If it isn't it's a glitch not really much you can do but try again, post and see if it gets resolved but if 1 in 10 have a glitch it can be hard to track down. Also there are many commands that can do it. This is a Debian issue not really a Raspbian issue though.
For example http://hexample.com/2012/02/05/fixing-l ... em-debian/ note this is not necessarily a current issue just an example.
- Contact: Website
as for raspbmc, you can only change locale (keys) and timezone, unlike in raspi-config for the official raspberry image
you can try this code:
then reboot, then ssh...
as it is shown here >>> http://forum.stmlabs.com/showthread.php?tid=6278
rm /home/pi/.configureduser
This does not longer work, this works:xXAzazelXx wrote:tryCode: Select all
https://github.com/snubbegbg/install_raspi-config
