incans
Wait for hard disk during boot
Mon Apr 29, 2013 7:35 pm
A while ago I started configuring the Pi as a server for Slimserver (the Logitech) music server. As part of doing this I set the Pi up with an external 2.5" hard disk with two partitions-
/dev/sda2 mounted on /var
/dev/sda1 mounted on /share
The idea was to get better speed and more space for swap by putting /var on the hard disk. /share is bulk storage space for media files. The disk partitions are configured (using disk labels) in fstab
Problem-
This was running ok until the first time I rebooted the Pi.
When the Pi boots it can't "see" the disk partitions. Thus it fails to mount /var which leaves the machine a bit upset because it can't find a bunch of files, and you can't start X because it needs to write into /var.
Now, interestingly once the machine has been running for few seconds or so, if I run "mount -a" as root, the disk partitions mount and most things start working.
However at this point things look a bit weird-
  • The command "mount" shows each of /var and /share being mounted TWICE. So for example /var is listed as mounted on both /dev/sda2 AND /dev/sdb2
  • Even stranger, if I list /dev, there ARE no sda or sdb devices, my disk now shows as /dev/sdc, /dev/sdc1, and /dev/sdc2
Some of this is a timing issue I think. On a cold (power up) boot the Pi is trying to mount the disk before it has spun up to to speed. However these problems occur if I restart the Pi only with the disk already spinning, so it may also be something to do with the time it takes to enumerate devices and create the entries in /dev.
Am I on a hiding to nothing here and i'd be better off starting from scratch, or is there a way of persuading the Pi to wait for the disk devices to be ready before i tries to mount them?
Any hints much appreciated.
PS: What AM I doing wrong with the BBCode for numbered lists in the forum? I can never get them to work...
Andresen
Re: Wait for hard disk during boot
Wed May 01, 2013 10:01 pm
Try to add a boot_delay, by adding something like:
boot_delay=32
to your /boot/cmdline.txt. I have / on an usb-disk and my file is:
[email protected] ~ $ cat /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/sda2 boot_delay=32 rootfstype=ext4 elevator=deadline rootwait
Regards,
Andresen
Joe Schmoe
Wed May 01, 2013 10:40 pm
What are the units?
Is 32 32 seconds?
Andresen
Thu May 02, 2013 5:30 am
Joe Schmoe wrote:What are the units?
Is 32 32 seconds?
I don't recall it as the pi waits 32 seconds .. but from http://www.raspberrypi.org/phpBB3/viewt ... 50&t=22809 sure it does look the unit is seconds...
Regards,
Andresen
