mesmariusz
pgrep -n motion - difference if run from command and script
Mon Apr 29, 2013 5:43 am
[quote="mesmariusz"]Script:
#!/bin/sh
pgrep -n motion
returns independent if motion is run or not:
root@raspberrypi:/home/pi# /home/pi/scripts/motion-act.sh
18411
18419
n...
As we can see it returns some random and still increasing value.
Another if it is run directly from command line. Then it is still and the same value when motion is turned on:
root@raspberrypi:/home/pi# pgrep -n motion
18391
18391
18391
and when turned off:
Why is works different in these two cases?
I would like to force motion is olways working follow example:
http://ni.recoverydata.pl/content/uruch ... %82a-pgrep
But it will never work due to reason abowe.
Maybe I could get some help here?
Thank you very much.
rpdom
Re: pgrep -n motion - difference if run from command and scr
Mon Apr 29, 2013 6:30 am
Because you have called your script "/home/pi/scripts/motion-act.sh".
"pgrep motion" will search for any process name that contains "motion", so it will match your script name and return the PID of that. The reason it gives a different number everytime you run it is because the script has a new PID each time.
Try using "pidof motion" instead, and read the manpages of pgrep and pidof. ("man pidof" or "man pgrep").
