I hope this is the right subforum.
In addition to the Raspberry Pi, I know we need an SD card with the OS on it. In addition to that, a keyboard and something to serve as a monitor are also assumed in the documentation I can find. The Wiki says they are "More or less essential."
My question is whether someone can perform the initial installation boot using just one piece of external hardware that has both a keyboard and a screen (such as a PC or serial or USB enabled tablet or cellphone or PDA), or if an actual keyboard and separate external monitor are absolutely required.
I ask because I only have a PDA with serial and USB ports, an external USB keyboard and a dialup CF modem. I will have to buy an SD card with the OS already on it, and want to use the Pi from the command line because it will be more capable than my PDA.
Can the initial boot of Fedora Remix (or any other approved distro) be made via the commandline on another device, with the display appearing on that device?
Thank you,
sdjf
