rasberrypip
Rasberry Pi Wireless Adapter
Sat Apr 27, 2013 4:01 pm
I have purchased the Pi Hut Wireless Adapter but am unable to get it working.
I have the B board with 512 MB and a 16GB SDHC card preloaded with Rasbian "Wheezy"
I also have a D-Link 4 Port powered hub. The PS2 mouse and keyboard connected to the hub through a PS2/USB adapter. The CDrom drive also connect to the hub.
I have read several posts indicating problems with power and I am not sure whether the wireless adapter should connect to the Pi USB port or a hub port.
I have tried loading the drivers that came with the wireless adapter but my limited knowledge means I am groping in the dark. I would greatly appreciate any assistance with setting this up.
Regards
DBryant
Re: Rasberry Pi Wireless Adapter
Tue May 07, 2013 10:24 am
Wireless adapters seem to be hungry devices so attaching to the hub might prove to be better. I purchased an adapter that stated it would run plugged directly into the Pi, but not a bit of it. And now its configured and fully functional in the hub it still won't function in the Pi itself.
Do you have a wired connection at all? And if so, does your system work with all these peripherals connected? Remove non-essential devices i.e the CD drive and see if things change. I'd guess not, but a marginal PS may be coaxed to cooperate.
When you plug the adapter in, what does the command lsusb report? Has the USB sub-system detected its presence? If you tail -f /var/log/messages while plugging in the adapter, do you see messages? And are these reporting any error?
If the USB sub-system 'sees' the adapter, then this should trigger the loading of the relevent kernel modules, lsmod will list the modules loaded into the kernel. Do you see a likely named module?
Execute ifconfig -a to list all know interfaces, can you recognised anything? If connected via wire, and if so you should see eth0, its status (UP/DOWN) and the assigned IP address.
Is there a wireless device? Is its status DOWN?
What are the contents of your network files? Have you tried to add wireless capability at all, and failed, or just not done anything?
jbntx
Sat Jul 06, 2013 6:35 am
I had a variety of issues getting mine up and running as well. I wrote down how I got mine working well on my site, here's the url: http://onlineextremist.com/blog/2013/07 ... pberry-pi/. I hope it helps you.
jb
Return to “Beginners”
