jezmck
CLI output of webcam (i.e. in ASCII)
Thu Apr 25, 2013 5:51 pm
Hi everyone,
I'd like to be able to see output from my webcam (either live video or a single frame) on the command line.
I've been misunderstood elsewhere, so I'll reiterate: on the command line, via ssh (putty), as ASCII, I don't want to stream anything, I don't want to save a jpg or mpg or any other file.
I'm certain this is possible (because I've got very close a couple of different ways*), so if you don't think it is please don't say so.
If anyone can help it'd be hugely appreciated!
*- I won't mention which yet, in case they put people onto the same trail as me.
evildave
Re: CLI output of webcam (i.e. in ASCII)
Thu Apr 25, 2013 6:33 pm
jp2a <- is able to convert a jpg to ASCII
If the webcam works with v4l then you could open it with vlc.. VLC automatically outputs "ASCII-Art" when started over ssh
jezmck
Fri Apr 26, 2013 6:25 pm
Yep, that's the option I've had most success with.
But .... It only draws a few frames, seems to always update only the area circled, and then hangs.
The pi is then usuable (in a different ssh session), but vlc uses ~91% cpu and is unkillable!
topguy
Fri Apr 26, 2013 6:36 pm
mplayer also supports AAlib, but I dont know how well it works with webcams.
http://oreilly.com/pub/h/4441
