nipunbatra
ch341- UART convertor not working in RPi
Mon Apr 22, 2013 12:20 pm
I am using a CH341-UART convertor ( which converts RS 485 serial to USB). This gets detected on RPi as confirmed by lsmod and dmesg. However i am not able to communicate with my host device. A lot of googling led me to understand that this is a known issue with Linux.
http://git.kernel.org/cgit/linux/kernel ... 423d17538e shows that a single line needs to be added to ch341.c file.
I do not see ch341.c file and i did a recursive grep to find it. However i was able to find ch341.ko file, which obviously is not a native source file.
What is the recommended procedure in such a case?
slink
Re: ch341- UART convertor not working in RPi
Sun May 05, 2013 1:06 am
I would be very interested to know if you ever found a solution to this problem as I have just encountered it myself.
mesmariusz
Thu Aug 01, 2013 10:06 pm
Did you manage? Does it work?
I see:
- win driver: http://www.winchiphead.com/download/CH341/CH341SER.ZIP
- datasheet: http://www.winchiphead.com/download/CH341/CH341DS1.PDF
But if you could let me know if it is working with linux for you it would be great!
akatran
Sun Feb 15, 2015 3:28 pm
The main problem that this dongle doesn't work is because, possibly, you can not change the port settings from software.
I found trying to do some java modbus programming that what ever setting I put the port uses the casual 8 databits, 1 stop bit and no parity.
I know it is an old question but it came up!!!
dkeverne
Sun Feb 15, 2015 4:48 pm
I use both ch341 and pl2303 USB to serial devices. The RS-422 device I use is this one:
http://www.ebay.co.uk/itm/USB-2-0-to-RS ... 4aba17779a
It is a pl2303 device and works fine. It connects to my solar inverter for monitoring.
I also have devices that come up as ch341 although they are RS-232, so maybe not the same as yours, but they work fine for me too.
I use minicom for testing, because you can easily change the comms settings.
Hope it helps.
mimi123
Mon Feb 16, 2015 9:09 am
you should recompile the kernel
Return to “Raspberry Pi OS”
