Sure this has been covered many times but the few previous posts on here I went through didn't help.
I'm using the Pi to use my Pi headless, accessing it through SSH on my Win7 desktop. I connected the Pi to my router and all was fine and dandy, expect the router is downstairs. I went through a couple of tutorials and explanations on how to set up my pi to connect to my PC through an ethernet cable. I have got to the point where I can access my Pi with SSH with it directly connected to the PC. Great! But I don't have internet access on the pi, which although not vital, would be useful for updates and downloading packages etc. Can someone point out where i've gone wrong with my set-up?
If useful, here is my ifconfig and interfaces files:
eth0 Link encap:Ethernet HWaddr b8:27:eb:13:16:17
inet addr:192.168.250.2 Bcast:192.168.250.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:128 errors:0 dropped:0 overruns:0 frame:0
TX packets:95 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:13245 (12.9 KiB) TX bytes:12980 (12.6 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.250.2
netmask 255.255.255.0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
http://www.raspberrypi.org/phpBB3/viewt ... ne#p326039
http://www.raspberrypi.org/phpBB3/viewt ... ne#p305085
http://glynrob.com/hardware/raspberry-pi-headless/
http://www.raspberrypi.org/phpBB3/viewt ... ne#p271196
and a few others.
Thanks in advance!
Andrew
