This kernel hack FIXed the SHDC / SHDX kernel issues on OpenSuSE 12.3 with class 6/10 cards Bigger then 16GB.
Myself have 64GB SD Cards from Kingson / Sandisk in use.
Bernhard made the raspberrypi-opensuse-20131206Image avalible :
http://www.zq1.de/bernhard/linux/opensu ... 06x.img.xz
I Found an workaround : Installed the Debianbetta kernel on Open Suse 13.1 Raspberrry .
OpenSuSE RPI and debian RPI seems to use the SAME Kernel source repro at Current.
I got 3.8.13 ( rpi-update "next" BRANCH current ) /
3.9.3 ( selfcompiled ) running on the 20130407 Image
How HACK that kernel Update on you RPI:
( assume you have 3.6.11 as current i.e , but works for older as well - NO warranty - TEST KERNEL - ):
#----Simple Users Guide -----RPI-TEST-Desktop-Kernel---------
1- backup :
tar cpfj /root/bootsuseold3611.tar.bz2 /boot
zypper update
zypper upgrade
reboot
zypper install git-core sudo wget p7zip
wget http://goo.gl/1BOfJ -O /usr/bin/rpi-update && sudo chmod +x /usr/bin/rpi-update
4- kernel Update to 3.11.x Latest ~ ( DEC 2013 ) ALPHA TEST KERNEL & Firmware
BRANCH=next rpi-update
Note - rpi-update
if rpi-update does not update - saing you have it allready -
then delete the repro copy at /root/.rpi-firmware just and run rpi-update again
rm -rf /root/.rpi-firmware
5. reboot
6- "next" Kernel 3.11.x+ or newer - Have fun using your new kernel.
lb2:~ # uname -a
Linux app1 3.10.19+ #600 PREEMPT Sat Nov 16 20:34:43 GMT 2013 armv6l GNU/Linux
Note 08-May-2013 - BRANCH=next featgers
This test RPI Update 3.8.x have ´nd LCX , KRB5 , DLM , USBLP , SPI options at Current,
ipvs and aprd where added at 3.8.10 due my requests, thus nfsroot shuold work with rarp now.
Note IPVS & ipvsadm
ipvs been successfuly with an patched ipvsadm ( rasberian debian 1.26.-2 are incomplete patched )
an patched & precompiled RPI ipvsadm Tarball are droped to https://www.dropbox.com/sh/2pkbntk4enwt ... RPI-binary
reported gotten issues with ipvsadm to lvs-users mailing list.
Myself provide this Guide for selfhelp..
Someone ask me do delete this help .. sorry fellows - I don´t do that .
So many SD card Corruption and / or stabilty issues
with +16G issues with class 6/10 seen here past Weeks ,
and most Users ask for FIX or either an workarround.
Reinstall the OS all 3 weeks / manualy fsck on sutch cards may the wrong way.
AnyHow : DON´T Juge the PI for Software issues with RPI Firmware & Kernels.
#----Enhanced Users Guide --build own RPI kernel----RPI-Server-Kernel---------
7. Compile & Install your own Kernel +3.8.7 and up
- see http://elinux.org/RPi_Kernel_Compilation
- get and Install required Software to compile kernel:
zypper install gcc make autoconf automake bison flex gettext u-boot-tools ncurses-devel
cd /usr/src
wget http://www.raspberrypi.org/phpBB3/download/file.php?mode=view&id=3174&sid=960bc650c8639db17984e8c8de720450
- get RPI 3.8.y source as GIT clone from GitHUB and push the config
cd /usr/src
cat >git3.8.y-update.sh << EOF
#!/bin/sh
# Simple GIT fetch latest RPI "next" Kernel source tar ball script ..
cd /usr/src
if [ ! -d SOURCES ]; then
mkdir SOURCES
fi
if [ ! -d GIT ]; then
mkdir GIT
fi
cd GIT
if [ -d .git ]; then
rm -rf .git
rm .gitignore .mailmap
fi
git init
D=`date +"%m-%d-%Y"`
if [ -d rpi-3.8.y.$D ]; then
rm -rf rpi-3.8.y.$D
fi
mkdir rpi-3.8.y.$D
git fetch git://github.com/raspberrypi/linux.git rpi-3.8.y:refs/remotes/origin/rpi-3.8.y
git checkout rpi-3.8.y
cd /usr/src/GIT
mv ./* rpi-3.8.y.$D
tar cpfj /usr/src/SOURCES/rpi-3.8.y.$D.tar.bz2 rpi-3.8.y.$D
# EOF
chmod 755 git3.8.y-update.sh
./git3.8.y-update.sh
cd /usr/src
tar xpfj SOURCES/rpi-3.8.y.$D.tar
rm linux
ln -s linux-rpi-3.8.y.$D linux
tar xpfj config-3.8.7.ipvs+krb5+arpd.tar.bzip2
cp linux/.config .config_386
- get RPI 3.8.y source as ZIP from GitHUB and push the config
cd /usr/src; D=`date +"%m-%d-%Y"`
wget https://github.com/raspberrypi/linux/archive/rpi-3.8.y.zip
mv rpi-3.8.y.zip rpi.3.8.y.D.zip
7z x rpi-3.8.y.$D.zip 2>/dev/null
rm linux
ln -s linux-rpi-3.8.y linux
- Updated attached .config to my selfcompiled v3.8.7 kernel.
- KRB5 options enabled ( secure NFS with KRB requirement )
- ARPD / RAP options enabled ( Linux Virtual Server & NFS boot
- IP_VS options enabled. ( Linux Virtual Server requirement )
- CONFIG_FUSE_FS=m enabled ( fuse ZFS requirement )
- CONFIG_CIFS_SMB2=y enabled ( samba 4 requirement )
- CONFIG_SQUASHFS=m enabled
-CONFIG_SECURITY_SELINUX enabled.
- CONFIG_CRYPTO* CONFIG_XZ* and subfeatgers enabled
Notes & Issues :
- CONFIG_MMC_BCM2708=[m|y] failed to build - disabled , code bug
see https://github.com/raspberrypi/linux/issues/277
- CONFIG_BCM_VC_CMA=y , can´t build as Module anyhow.
-mfloat-abi=hard compiled kernel seems not work with any < 3.9.x <
see https://github.com/raspberrypi/linux/issues/276
- using-Class 6 and 10 SD cards seems Forbidd to use OverClocking allways
when use SDcards and often also USB-sticks devices.
It been reported as well when use external Terabyte USB 2.0 Disks as ROOT disks .
This will cause to Coorupt ANY Filesystem type on the used devices - verified.
Root cause seems : The used RPI SD card controler are overvolated and overfrequenced and go OUT of SPEC.
see i.e https://github.com/raspberrypi/linux/issues/280
- Adding LXC will one of my next targets -
seems require extra patches( i.e CONFIG_MMC_BCM2708 ) ,
if any Coder can help , send me an personal Note.
- rpi-3.8.y "next" seems updated to 3.8.12 so no extra Incremental Patching at current.
just wait for next
Make the kernel
cd /usr/src/linux
make oldconfig
nohup make \
CPPFLAGS="-Ofast -mfpu=vfp -march=armv6zk -mtune=arm1176jzf-s" \
CFLAGS="-Ofast -mfpu=vfp -march=armv6zk -mtune=arm1176jzf-s" \
dep zImage modules &
install kernel same way as described here :
http://elinux.org/Talk:RPi_Kernel_Compi ... le_example
cd /usr/src/linux
kversion=$(make -s kernelrelease)
echo $kversion
cp System.map /boot/System.map-$kversion
make ARCH=arm modules_install INSTALL_MOD_PATH=/
make ARCH=arm INSTALL_PATH=/boot/ install
cp .config /boot/config-$kversion
cp ./Module.symvers /boot/symvers-$kversion
cp arch/arm/boot/Image /boot/kernel.img
Check it :
ls -l /lib/modules/3.8.6-4-raspberrypi/
ls -l /boot/
Update please /boot/cmdline.txt and /boot/config.txt and /etc/sysctl.conf , uppon your own needs
lb2:/boot # cp cmdline.txt cmdline.txt.orig
lb2:/boot # cp config.txt config.txt.orig
vi /boot/cmdline.txt
console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 elevator=noop sdhci-bcm2708.missing_status=0 sdhci-bcm2708.sync_after_dma=0 profile=2 loglevel=7 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootflags=commit=120,data=writeback rootwait ro
The Important flags for SD(HC/HX) cards +16G ( i.e class 6 / 10 ) are thehttp://blogofterje.wordpress.com/2012/0 ... n-sd-card/
To further reduce IO and increase performance,
the following seem to be common recommendations, that he did:
Change /etc/fstab so that entry for root partition fourth parameter
is changed from “default” to “default,noatime,nodiratime”
Add linux boot parameter “elevator=noop” in u-boot so that the kernel does not
assume that the disk is a spinning medium and does not try to incorrectly optimize the IO.
elevator=noop
This are the AFAIK default settings for some more :
dwc_otg.microframe_schedule=1
dwc_otg.fiq_fix_enable=1
sdhci-bcm2708.enable_llm=1
dwc_otg.lpm_enable=0
If it doesn't help, you can install the "watchdog"-package. Add the "bcm2708_wdog" module to /etc/modules (and invoke "modprobe bcm2708_wdog"), install the watchdog package and uncomment the line with "watchdog-device =" in it.
vi /etc/fstab
/dev/mmcblk0p2 / ext4 default,noatime,nodiratime 0 1
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=0
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
# WARNING for Class 6 & 10 cards ( any size, any vendor ) : DON`T overclock
# see :
# http://elinux.org/index.php?title=RPiconfig§ion=14|SD#SD_Card_Usage_with_Overclocking
#uncomment to overclock the arm. 700 MHz is the default.
arm_freq=700
# for more options see http://elinux.org/RPi_config.txt
gpu_mem=32
core_freq=250
sdram_freq=400
over_voltage=0
# /etc/sysctl.conf
# Generated file - do not edit.
# Disable the hung task timer by default. (bnc#552820)
kernel.hung_task_timeout_secs = 0
# Increase defaults for IPC (bnc#146656)
kernel.msgmax = 65536
kernel.msgmnb = 65536
kernel.sem = 250 256000 32 1024
# ipv4 , reed by cluster
net.ipv4.ip_forward = 1
# ipv6 disabled ( currently )
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.all.forwarding = 0
If failed , restore kernel from backup tar.
HAPPY KERNEL hacking !!
lsmod
Module Size Used by
spidev 5509 0
i2c_bcm2708 3613 0
spi_bcm2708 4722 0
rtl8150 9236 0
ip_vs 159069 0
nf_conntrack 83958 1 ip_vs
xfs 500984 0
dm_mod 73179 0
# uname -a
Linux ad1 3.11.4-1-raspberrypi #1 PREEMPT Fri Oct 11 00:02:13 UTC 2013 (f1558bf) armv6l armv6l armv6l GNU/Linux
cat /etc/SuSE-release
openSUSE 13.1 (armv6hl)
VERSION = 13.1
CODENAME = Bottle
Anyhow : This hack works on Debian weezly and Fedora remix 18 as well.
BUG reports for the TEST kernel please to : https://github.com/raspberrypi/linux/issues?state=open
Hope this helps.
