Mon Apr 15, 2013 5:26 pm
jim01 wrote:So both my 8GB SD/SDHC and 4GB SDHC cards have returned with the same exact error message, " "Error 34 occurred while writing to disk at sector 382976." There is no way that the darned cards are both bad and failing at the exact same sector. Since I know it's not my iso file, I guess it has to be my brand new, out of the box card reader.
You may be right, but the im(a)g(e) file that's being written is of fixed size (a little under 2Gb) and thus the write could fail at the same sector. I don't write my SDHC cards with Windows tools because my netbook is dual-boot Ubuntu Linux/Windows XP and I can use Ubuntu's "ImageWriter" tool. There have been mixed posts w.r.t. Win32DiskImager written cards on the forum in the few weeks I been here - some people have had no problems, others have had subsequent booting issues. One point that has been mentioned is that you must have admin rights when writing. I'm guessing that "safely remove" is a good idea too. My external SDHC card reader/writer is one of two "integral" devices purchased with 4Gb SDHC cards not long after they became available (I don't use the SD card slot on my netbook since it's not marked as SDHC compatible). One possibility is to try a "Live Linux Distro." which runs from CD/DVD without using your m/c's hard drive and use the "command-line" "dd" utility of that, with care - be sure you are writing to the correct drive/device! I don't know for sure, but the (current) "Ubuntu Live" may include "ImageWriter", one of its other uses being to create a bootable USB stick version of the live distro. it's part of.
Trev.
