john564
[How to] using stunnel + openvpn from China or Syria
Sat Apr 13, 2013 2:45 am
# Some countries like China, Syria, North Korea etc, are using deep packet inspection
# to detect and block openvpn connections.
# To get around this, VPN connections can be hidden inside another SSL envelope
# using a program called stunnel making the VPN look like something else
# This post is based upon these
# http://kyl191.net/2012/12/tunneling-ope ... h-stunnel/
# https://syria.hacktivist.me/?p=161
# http://pve.proxmox.com/wiki/Stunnel_in_DAB_appliances
# http://www.jeffyestrumskas.com/index.ph ... ntication/
# mirror post at http://tryapi.wordpress.com/
# Using Raspberry PI as Openvpn server located outside China or Syria
# we wrap the openvpn signalling inside another SSL envelope using stunnel
# On Raspberry PI, after you have installed openvpn
# (for openvpn see http://www.raspberrypi.org/phpBB3/viewt ... 36&t=21566)
# Install stunnel and openssl
sudo apt-get install stunnel4 openssl -y
# Generate your own Private Key (server.pem)
cd /etc/stunnel/
sudo openssl genrsa -out server.key 4096
sudo openssl req -new -key server.key -out server.csr
sudo openssl x509 -req -days 365 -in server.csr -signkey server.key -out server.crt
sudo bash
cat server.key > server.pem && cat server.crt >> server.pem
chmod 400 /etc/stunnel/server.pem
exit
# enable stunnel
sudo nano /etc/default/stunnel4
     ENABLED=1
# Server stunnel.conf on Raspberry PI
sudo nano /etc/stunnel/stunnel.conf
     sslVersion = all
     options = NO_SSLv2
     cert = /etc/stunnel/server.pem
     pid = /var/run/stunnel.pid
     output = /var/log/stunnel
     [openvpn]
     client = no
     accept=993
     connect=34567
# Add Firewall setting on Raspberry PI
# Edit the same firewall file we used for openvpn
# and add a new line
sudo nano /usr/local/bin/firewall.sh
     iptables -A INPUT -p tcp –dport 993 -j ACCEPT
# Restart stunnel or reboot Raspberry PI and we are done
sudo /etc/init.d/stunnel4 restart
# check status
ps aux | grep ‘stunnel*’
# Installing & configuring stunnel on windows client:
# You can download stunnel installer from the official website
# http://mirrors.go-part.com/stunnel/stun ... taller.exe
# or check here http://www.stunnel.org/downloads.html
# Installation shouldn’t be a problem… it’s a few clicks
# On windows, you should see an stunnel icon on your desktop, run it as administrator.
# Now you should see the stunnel icon also on the taskbar.
# Do a right click on it, and choose “Edit stunnel.conf”
# Notepad will opened automatically, to edit the stunnel.conf file…
# add the following lines:
[openvpn]
client = yes
accept = 127.0.0.1:1194
connect = change_this_to_your_to_raspberry_PI_server_address_from_no-ip.com:993
# Save & exit
# right click on stunnel icon, and click reload stunnel.conf
# in Windows, create a new text file called
# C:\Program Files (x86)\OpenVPN\config\raspberry_via_stunnel.ovpn
# this is the OpenVPN client configuration
client
dev tun
proto tcp
remote  localhost 1194
resolv-retry infinite
nobind
persist-key
persist-tun
ca capi.crt
cert clientpi.crt
key clientpi.key
# tls-auth tapi.key 1
ns-cert-type server
cipher AES-256-CBC
comp-lzo
verb 3
lucdig
Re: [How to] using stunnel + openvpn from China or Syria
Tue Jul 28, 2015 9:16 pm
have you tried this solution with an Android device as OpenVPN Client?
I am able to connect to the Stunnel server with Android, where I installed a Stunnel-like client, OpenVPN is opened and configured but no traffic seems to be routed through the VPN.
My Android is not rooted.
Regards, thank you very much.
lucdig
Thu Jul 30, 2015 10:35 am
I have found this for Android, it works.
https://forums.openvpn.net/topic18110.html
The important part is routing for the ip address of the openvpn server:
"The key item here is the Custom Option above which tells OpenVPN not to route SSLDroid's SSL tunnel through the VPN. Without this option, the SSL tunnel will be broken when OpenVPN connects because SSLDroid can no longer reach the server"
McGirk
Mon Apr 22, 2019 7:12 pm
Is this still the best instructions for combining Stunnel and OpenVPN?
