lancer2k
GPT Partitions on Raspbian
Fri Apr 12, 2013 12:31 pm
Hi all,
I have a 2'5TB External HD with a NTFS partition on it.
I plug in the HD and the rasp recognizes it, but the partition isn't recognized:
In dev directory I have /dev/sda but I don't have /dev/sda1
Fdisk only shows 301.5GB
sudo fdisk -l
Disk /dev/sda: 301.5 GB, 301472702464 bytes
256 heads, 63 sectors/track, 36508 cylinders, total 588813872 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x92b53b6a
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1               1  4294967295  2147483647+  ee  GPT
Using parted I only get this error:
Error: Can't have a partition outside the disk!
Is there any way to access the HD whitout wipping the partition?
Thanks!
plugwash
Re: GPT Partitions on Raspbian
Fri Apr 12, 2013 12:56 pm
What kernel are you running?
What does "cat /proc/patitions" say?
What does "lsusb -t" say?
Have you tried this drive on any other linux system? if so did it work and what kernel version was it running?
My gut feeling is that this is a bug in the kernel driver for the USB-SATA bridge chip inside the external hard drive.
lancer2k
Fri Apr 12, 2013 1:02 pm
Thanks for the response:
cat /proc/partitions
major minor  #blocks  name
 179        0    7761920 mmcblk0
 179        1      57344 mmcblk0p1
 179        2    7700480 mmcblk0p2
   8        0  294406936 sda
   8       16  293057351 sdb
   8       17  293049666 sdb1
lsusb -t
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
cat /proc/version
Linux version 3.2.27+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #250 PREEMPT Thu Oct 18 19:03:02 BST 2012
This drive works great on W7...
Thanks!
plugwash
Fri Apr 12, 2013 1:12 pm
lancer2k wrote:Thanks for the response:
lsusb -t
lsusb -t should provide more output than that....
That is an older kernel now.
Can you try running "apt-get update && apt-get install raspberrypi-bootloader". This should update the kernel and firmware to the lastest supported versions.
lancer2k
Fri Apr 12, 2013 3:14 pm
Ok! Thank you so much!
I'll update with any news!
Regards
lancer2k
Fri Apr 12, 2013 3:54 pm
Now I get this:
lsusb -t
    |__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/3p, 480M
        |__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
        |__ Port 2: Dev 4, If 0, Class=stor., Driver=usb-storage, 480M
        |__ Port 3: Dev 5, If 0, Class=stor., Driver=usb-storage, 480M
lancer2k
Mon Apr 15, 2013 6:47 am
i'm not able to access the partition yet,
Any ideas?
Thanks!
danwar
Tue Apr 23, 2013 2:04 pm
I believe I have the same problem with a 3TB disk. The disk works fine on a W7 computer. It detects fine on raspbian, but I can't seem to mount it. It says that it can't mount GPT. Any ideas?
kwetiaw
Mon Jul 01, 2013 1:46 pm
same here.
here's what i got after running sudo fdisk -l
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 801.6 GB, 801569726464 bytes
256 heads, 63 sectors/track, 97071 cylinders, total 1565565872 sectors
Disk identifier: 0x512a421b
/dev/sdb1 1 4294967295 2147483647+ ee GPT
Help pleaseeeeee......
itimpi
Mon Jul 01, 2013 2:08 pm
The error message from fdisk is valid - you need to use a different disk editor for disks with GPT partitions. If I remember correctly cfdisk can handle disks using GPT. If not gparted definitely can but that needs installing via apt-get as it is not part of the standard distribution.
It is unlikely that the GPT partition is an issue with mounting the disk. The most likely thing is that the disk is in NTFS format, but you do not have the ntfs-3g package installed. You might want to run
sudo apt-get install ntfs-3g
and then see what happens.
zhuanyi
Tue Jul 23, 2013 1:05 am
You will need to use parted -l to check for the actual data partition and mount that partition, I wrote a short tutorial on how to do this:
http://www.zayblog.com/computer-and-it/ ... pberry-pi/
Worked for me and hopefully it will work for you as well :)
Return to “Raspbian”
