smithnb42
Newbie
Fri Apr 12, 2013 12:20 pm
I am a raspberry pi newbie. My question is which USB hub should I buy? I would like to connect the keyboard, mouse and a wifi dongle to the Pi.
chris57100
Re: Newbie
Fri Apr 12, 2013 2:16 pm
You have to buy one with external power supply. That's the only requirement
Raspberry Pi Home Server : http://www.pihomeserver.fr
Software and electronic tutorials : Samba, Airplay, CUPS, Time machine, Nginx, Owncloud, rTorrent, Wordpress, etc.
Full Wi-Fi hotspot installation on a RPi 3 including a captive portal and freeradius management: https://github.com/pihomeserver/Kupiki-Hotspot-Script
FTrevorGowen
Re: Newbie
Fri Apr 12, 2013 3:32 pm
smithnb42 wrote:I am a raspberry pi newbie. My question is which USB hub should I buy? I would like to connect the keyboard, mouse and a wifi dongle to the Pi.
It's a good idea to check the verified peripherals list on the wiki: http://elinux.org/RPi_VerifiedPeripherals
chris57100 wrote:You have to buy one with external power supply. That's the only requirement
Probably better to buy one that can be powered, without a supply, and buy a second "Pi charger" - some PSU's supplied with hubs are of poor quality and may "just about" supply 500mA (instead of up to 500mA per port). It's also possible to use a wired keyboard and wired mouse via an unpowered hub, with the WiFi dongle plugged in to the other USB port of a (model B2) Pi. FWIW I've tried out a number of "low-cost" hubs and there are notes etc. about them (and PSU's) within my webpages (see link on the right).
Trev.
