DonVito186
Pisces + MATE: Use the whole SD Card
Thu Apr 11, 2013 8:08 pm
I recently installed Pisces + MATE on my raspi, and i noticed that its not using all of the 64gb SD card. Its instead using ~3gb. I was told from someone to use gparted to fix the issue, but he stopped helping when i asked how to do it. So how do i use the remaining 61gb?
1HzCoder
Re: Pisces + MATE: Use the whole SD Card
Sun Apr 14, 2013 2:23 am
DonVito,
Try ~$ sudo raspi-config, then select the option to "Expand root file system to use entire SD card".
TomJ
OOPs, wasn't reading very close, but gparted is pretty self explanitory.
Einstein once said you don't really understand anything until you can explain it to your Grandmother
tabsterleir
Mon Apr 15, 2013 3:46 am
I've used this method on multiple distros for the Pi and its worked every time. Of course, do this at your own risk, YMMV etc
Open a root terminal and type/press the following in sequence
fdisk /dev/mmcblk0
d
2
n
p
2
enter
enter
w
shutdown -r now
resize2fs /dev/mmcblk0p2
Return to “Beginners”
