drewibbo
Bash query regarding if statement...
Thu Apr 11, 2013 7:39 pm
Probably a really silly question, but I'll ask anyways as I cannot find the answer anywhere!
Why does the following script return an error of too many arguments???
read -p "Please enter your name : " name
if [ $name = "andy ibbitson" ]; then
  echo "Well done! You know my name."
else
  echo "Do you not know who Andy Ibbitson is?"
fi
I have also tried $name == "andy ibbitson" with no luck.
This is what is returned:
[email protected] ~/projects/kidpi $ ./tester.sh
Please enter your name : andy ibbitson
./tester.sh: line 3: [: too many arguments
I am ultimately designing a bash script that my young son can use to turn on/off LEDs by just typing "green on" or "Green off" etc...
I am used to using php and this is driving me crazy. :?
Thanks for any assistance anyone can give. :D
Pi Pi Pi...
jojopi
Re: Bash query regarding if statement...
Thu Apr 11, 2013 7:57 pm
In POSIX shells, word splitting and pathname expansion happen after variable substitution. This is practically never desirable, so you should practically always put double quotes around variable expansions.
if [ "$name" = "andy ibbitson" ]; then
Without the extra double quotes here, there is a syntax error if $name is either empty or expands to more than one word.
drewibbo
Thu Apr 11, 2013 8:05 pm
jojopi wrote:In POSIX shells, word splitting and pathname expansion happen after variable substitution. This is practically never desirable, so you should practically always put double quotes around variable expansions.
Thank you so much for explaining this to me. You have helped a great deal. :D
Pi Pi Pi...
TheQuestor
Fri Apr 12, 2013 3:21 am
I could be wrong but I thought if you are comparing 2 values then it needs to be ==
such as
Platform="Raspi"
if [ "$Platform" == "Raspi" ];
then
#do something for Raspi
elif [ "$Platform" == "OSX" ];
then
#do something for OSX
else
#if neither then do something else
fi
a single = is for declaring something and a double == is for comparing
now I have used things like this in the past and it works fine for numbers or single word vars
Var1=1
If [ $Var1 = 1 ] ;  #without quotes
then
#do something
else
#do something else
fi
and
Var1=1
if [ "$Var1" eq "1" ];
then
#do something
fi
bash is a strange beast, and borne is even stranger
Fri Apr 12, 2013 5:28 am
TheQuestor wrote:I could be wrong but I thought if you are comparing 2 values then it needs to be ==
In many languages (C, PHP, etc) that is true. But not in bash.
In fact = is used for string comparisons, even when you put a numeric value. Numeric comparisons can be done using -eq, -ne, -ge, -gt, -le and -lt as in
a=1
if [ $a -eq 1 ]
then
  echo "a is 1"
fi
if [ $a -lt 2 ]
then
  echo "a is less than 2"
fi
