tomtomclub
Raspbian “wheezy
Wed Apr 10, 2013 6:51 pm
Beste vandaag op een SD kaartje Raspbian wheezy er op gedaan
ssh aan gezet plus update config en klaar is kees, maar hoe weet ik nu of de installatie is gelukt of ik echt Raspbian wheezy er in zit ik kan het nergens terug zien :?:
obcd
Re: Raspbian “wheezy
Thu Apr 11, 2013 12:58 pm
uname -a
geeft je meer informatie over de kernel die draait op je Pi.
AutoStatic
Thu Apr 11, 2013 2:22 pm
cat /etc/debian_version
Zou 7.0 (wheezy) moeten zijn.
RPi and real-time, low-latency audio: http://wiki.linuxaudio.org/wiki/raspberrypi
RPi audio repository: http://rpi.autostatic.com/
RPi and audio blog: https://autostatic.com/tag/raspberrypi/
tomtomclub
Thu Apr 11, 2013 4:31 pm
login as: pi
pi@192.168.1.79's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
pi@raspbmc:~$
pi@raspbmc:~$
pi@raspbmc:~$ uname -a
Linux raspbmc 3.6.11 #2 PREEMPT Wed Mar 13 17:12:47 UTC 2013 armv6l GNU/Linux
pi@raspbmc:~$
volgens mijn is dit toch de wheezy
AutoStatic
Thu Apr 11, 2013 5:51 pm
DirkS
Thu Apr 11, 2013 9:07 pm
AutoStatic wrote:Nee, raspbmc: http://www.raspbmc.com/
Is dat zo? De hostname is raspbmc, maar dat wil niet zeggen dat het ook raspbmc is...
En raspbmc is natuurlijk (op dit moment) ook wheezy, maar niet kortademig ;)
Gr.
Dirk.
tomtomclub
Thu Apr 11, 2013 11:21 pm
login as: pi
pi@192.168.1.81's password:
Linux raspberrypi 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l
Last login: Thu Apr 11 18:42:29 2013
pi@raspberrypi ~ $ cat /etc/debian_version
7.0
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l GNU/Linux
7.0
pi@raspberrypi ~ $
nu toch wel?? verzie 7.0. ik hoop van wel?
AutoStatic
Fri Apr 12, 2013 10:47 am
DirkS wrote:Is dat zo? De hostname is raspbmc, maar dat wil niet zeggen dat het ook raspbmc is...
Klopt maar ik zie het aan het versienummer van de kernel. Die is #2 terwijl de kernel die in het Raspbian image zit versienummer #371 heeft.
AutoStatic
Fri Apr 12, 2013 10:48 am
tomtomclub wrote:login as: pi
Dit is Raspbian.
tomtomclub
Sat Apr 13, 2013 9:21 am
Beste AutoStatic is deze wel goed
pi@raspbmc:~$ cat /etc/debian_version
7.0
pi@raspbmc:~$
DirkS
Sun Apr 14, 2013 9:46 am
Da's de actuele versie van Raspbmc (op basis van wheezy).
Gr
Dirk
tomtomclub
Sun Apr 14, 2013 10:10 am
dank je ;)
Return to “Nederlands”
