huxley
Raspbmc - External HDD
Wed Apr 10, 2013 9:44 am
First post on here and apologies now if this problem has been discussed/solved previously but I feel my particular circumstance is unique from what I have read using Google and various forums.
A bit about the kit and purpose.
I have a Model B RPi with latest version of Raspbmc installed, this is power by a 5v 3.5a powered USB hub and connected to my TV/Network. I want to use a 320GB 2.5" HDD with my movies on as an external drive to play movies from.
Problem.
When I connect the HDD direct to my powered USB hub the light on the HDD flashes and goes off but the disc is still running (feel it) but it does not show up in the Files option on XBMC.
I have used Putty to SSH into the RPi and I have used "df -h" and it doesn't show the drive.
I am a novice at best when it comes to linux I was wondering if anyone could help me troubleshoot this problem to find a solution.
DirkS
Re: Raspbmc - External HDD
Wed Apr 10, 2013 10:29 am
Did you plug in the drive before booting the Pi or while it is running?
You could try this:
* plug in the drive while the pi is running
* check for any error messages with
dmesg | tail
Gr.
Dirk.
huxley
Wed Apr 10, 2013 10:50 am
Thanks Dirk very quick reply, I tried hot and cold connections.
I will try the above dmsg tail later on and let you know how that goes.
huxley
Wed Apr 10, 2013 4:45 pm
root@raspbmc:~# dmesg | tail
bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
ip_tables: (C) 2000-2006 Netfilter Core Team
Console: switching to colour dummy device 80x30
nf_conntrack version 0.5.0 (6007 buckets, 24028 max)
NET: Registered protocol family 10
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
bcm2708 watchdog, heartbeat=10 sec (nowayout=0)
This is the code I got back after plugging in the device... nothing that I can see about USB.
huxley
Wed Apr 10, 2013 5:56 pm
Don't know if this is more useful
Booting Linux on physical CPU 0
Initializing cgroup subsys cpu
Linux version 3.6.11 (root@buildraspbmc) (gcc version 4.7.1 20120402 (prerelease        ) (crosstool-NG 1.15.2) ) #2 PREEMPT Wed Mar 13 17:12:47 UTC 2013
CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: BCM2708
Memory policy: ECC disabled, Data cache writeback
On node 0 totalpages: 98304
free_area_init_node: node 0, pgdat c04f6218, node_mem_map c0545000
  Normal zone: 768 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 97536 pages, LIFO batch:31
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 97536
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbhe        ight=1080 bcm2708.boardrev=0xd bcm2708.serial=0xed60d7e7 smsc95xx.macaddr=B8:27:        EB:60:D7:E7 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 v        c_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 root=/dev/mmcblk0p2 rootfstype=e        xt4 noatime quiet rootwait loglevel=1 zram.num_devices=2
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 384MB = 384MB total
Memory: 384296k/384296k available, 8920k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xd8800000 - 0xff000000   ( 616 MB)
    lowmem  : 0xc0000000 - 0xd8000000   ( 384 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc049c000   (4688 kB)
      .init : 0xc049c000 - 0xc04c7adc   ( 175 kB)
      .data : 0xc04c8000 - 0xc04f6940   ( 187 kB)
       .bss : 0xc04f6964 - 0xc0544469   ( 311 kB)
NR_IRQS:330
sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
Console: colour dummy device 80x30
console [tty0] enabled
Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x41d978 - 0x41d9d4
devtmpfs: initialized
NET: Registered protocol family 16
DMA: preallocated 4096 KiB pool for atomic coherent allocations
bcm2708.uart_clock = 0
mailbox: Broadcom VideoCore Mailbox driver
bcm2708_vcio: mailbox at f200b880
bcm_power: Broadcom power driver
bcm_power_open() -> 0
bcm_power_request(0, 8)
bcm_mailbox_read -> 00000080, 0
bcm_power_request -> 0
Serial: AMBA PL011 UART driver
dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource stc
FS-Cache: Loaded
CacheFiles: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
bcm2708_dma: DMA manager at f2007000
bcm2708_gpio: bcm2708_gpio_probe c04d41c8
vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
FS-Cache: Netfs 'nfs' registered for caching
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
msgmni has been set to 750
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered (default)
io scheduler deadline registered
io scheduler cfq registered
Console: switching to colour frame buffer device 240x67
brd: module loaded
loop: module loaded
vchiq: vchiq_init_state: slot_zero = 0xd8804000, is_master = 0
usbcore: registered new interface driver smsc95xx
usbcore: registered new interface driver cdc_ncm
dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Core Release: 2.80a
Setting default values for core params
Finished setting default values for core params
Using Buffer DMA mode
Periodic Transfer Interrupt Enhancement - disabled
Multiprocessor Interrupt Enhancement - disabled
OTG VER PARAM: 0, OTG VER FLAG: 0
Dedicated Tx FIFOs mode
dwc_otg: Microframe scheduler enabled
dwc_otg bcm2708_usb: DWC OTG Controller
dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
Init: Port Power? op_state=1
Init: Power Port (0)
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DWC OTG Controller
usb usb1: Manufacturer: Linux 3.6.11 dwc_otg_hcd
usb usb1: SerialNumber: bcm2708_usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
dwc_otg: FIQ enabled
dwc_otg: NAK holdoff enabled
Module dwc_common_port init
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver libusual
mousedev: PS/2 mouse device common for all mice
bcm2835-cpufreq: min=800000 max=800000 cur=800000
bcm2835-cpufreq: switching to governor ondemand
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci: Enable low-latency mode
Registered led device: mmc0::
mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
sdhci-pltfm: SDHCI platform and OF driver helper
Registered led device: led0
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
zram: Creating 2 devices ...
TCP: westwood registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Waiting for root device /dev/mmcblk0p2...
mmc0: read SD Status register (SSR) after 2 attempts
mmc0: new high speed SDHC card at address e624
mmcblk0: mmc0:e624 SU08G 7.40 GiB
 mmcblk0: p1 p2
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 172K
Indeed it is in host mode hprt0 = 00021501
usb 1-1: new high-speed USB device number 2 using dwc_otg
Indeed it is in host mode hprt0 = 00001101
usb 1-1: New USB device found, idVendor=0424, idProduct=9512
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 3 ports detected
usb 1-1.1: new high-speed USB device number 3 using dwc_otg
EXT4-fs (zram0): mounting ext2 file system using the ext4 subsystem
EXT4-fs (zram0): mounted filesystem without journal. Opts: (null)
usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
smsc95xx v1.0.4
smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx U        SB 2.0 Ethernet, b8:27:eb:60:d7:e7
usb 1-1.3: new low-speed USB device number 4 using dwc_otg
usb 1-1.3: New USB device found, idVendor=413c, idProduct=3012
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.3: Product: Dell USB Optical Mouse
usb 1-1.3: Manufacturer: Dell
input: Dell Dell USB Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1        .3/1-1.3:1.0/input/input0
hid-generic 0003:413C:3012.0001: input: USB HID v1.11 Mouse [Dell Dell USB Optic        al Mouse] on usb-bcm2708_usb-1.3/input0
udevd[89]: starting version 175
bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k        )
bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k        )
DirkS
Wed Apr 10, 2013 9:08 pm
No mention at all in the log, so apparently the drive is not detected...
I asssume you tested the drive in a different computer (?)
Maybe try a different port on your hub. Just today or yesterday I read somewhere here on the forum that there are hubs where some of the ports are only meant for powering / charging devices, so no data transfer.
Gr.
Dirk.
huxley
Thu Apr 11, 2013 2:30 pm
Apparently I am an idiot...
Simple fix in the end I basically didn't plug the RPi into the "master" USB slot on the hub which wasn't immediately obvious as the USB ports aren't labelled but there is a micro USB slot which I connected to one of the RPi's USB slots...reboot and viola.
Thanks for your guidance.
