The 5V on BCM seems to be marked as Bat 5V, this lets think that 5V may be not 'regulated'.
Then my question is on 'A' model (without 5V USB/Ethernet chip) what is the 5V voltage tolerance for the BCM ?
The pins on the schematic symbol are just labeled VDD_BAT.The 5V on BCM seems to be marked as Bat 5V, this lets think that 5V may be not 'regulated'.
The USB hub with ethernet chip runs off the 3.3V rail as do various IO voltages. I suspect that due to the lack of that chip and the consequent lower load on the 3.3V regulator that the A will be more tolerant of undervoltage than the B but how much more tolerant I don't know (and it will probablly vary between individual devices).Then my question is on 'A' model (without 5V USB/Ethernet chip) what is the 5V voltage tolerance for the BCM ?
You thought wrong. See page 1 of the schematic.I thought that 5v didn't get on the chips, only 1.8v or 3.3v after the regulator.
The CPU also need 5V. I think VDD_BAT is a internal voltage regulator.cyrano wrote:It's really not the processor you need to worry about. That's powered by a 3,3 V regulator. The USB ports need 5V. Devices connected to it function best between 4,85 and 5,15 V.
