neobusy
Compile your own XMMS
Sat Apr 06, 2013 6:25 pm
I haven't seen a xmms install package on Raspbian, so I compiled xmms myself. Thought I should share my steps here, in case anyone else wants to do the same!
I followed this guide http://tuxarena.blogspot.de/2009/04/how ... ms-in.html with some Raspberry specific changes.
Basically we need 3 things, the xmms source and 2 libs: libgtk1.2 and libglib1.2. Since neither is available in the repository there is some manual work involved. Be patient while building, the raspberry is on heavy duty during those tasks 8-)
libglib1.2
Head over to http://ftp.gnome.org/pub/GNOME/sources/glib/1.2/ and grab the source as .tar.gz file. I took http://ftp.gnome.org/pub/GNOME/sources/ ... 2.5.tar.gz
Extract it and run
./configure
make
sudo make install
sudo ldconfig
libgtk+1.2
Head over to http://ftp.gnome.org/pub/gnome/sources/gtk+/1.2/ and grab the source again as .tar.gz file. I chose http://ftp.gnome.org/pub/gnome/sources/ ... 2.5.tar.gz
You should check version numbers as libgtk needs a certain glib version. I just took the same and it worked.
Make sure you have Xorg developer packages installed otherwise you get an error about missing X header files. Test / install with:
sudo apt-get install xorg-dev
Now extract the .tar.gz archive and run
./configure
make
sudo make install
sudo ldconfig
XMMS
Last but not least head over to http://xmms.org/download.php and grab the XMMS 1.2.11 Source.
Extract and run
./configure
make
sudo make install
sudo ldconfig
That's it! Change your sound output in XMMS to ALSA on the first start and enjoy! You also might want to reduce the visualisation refresh rate or disable it completely. Made a difference of about 4% CPU on my 900MHz Pi. I love having XMMS again, I tried QMMP and Audacious, but XMMS is just so slim and sleek. Hell Yeah! :twisted:
Gary Stout
Re: Compile your own XMMS
Sun Mar 09, 2014 11:53 am
When I try these steps....I get down to apt-get install xorg-dev and get a 404 error saying the files are not available. Have they been moved elsewhere?
Thanks,
Gary
Michiel O.
Mon Dec 19, 2016 4:39 pm
Gary Stout wrote:I get down to apt-get install xorg-dev and get a 404 error saying the files are not available. Have they been moved elsewhere?
Do you get the 404 error on 'sudo apt-get install xorg-dev', or on the 'wget http://ftp.gnome.org/pub/GNOME/sources/ ... 2.5.tar.gz'?
"You can't actually make computers run faster, you can only make them do less." - RiderOfGiraffes
Mon Dec 19, 2016 4:48 pm
You are responding to an 30 month old out-of-date topic which was based on Debian Wheezy Operating System,I believe xmms was actually superseded by xmms2 !
xmms2 is in the Raspbian Jessie repositories
sudo apt-get update
sudo apt-get install xmms2
https://packages.debian.org/jessie/xmms2
xmms2 (0.8+dfsg-12)
Client/server based media player system
XMMS2 is a redesign of the XMMS music player. It features a client-server model, allowing multiple (even simultaneous!) user interfaces, both textual and graphical. All common audio formats are supported using plug-ins. On top of this, there is a flexible media library to organize your music.
RPi 4B 4GB (SSD Boot)..
