mad-hatter
Virgin Super Hub - Pi set up problems
Sat Apr 06, 2013 10:19 am
My old set up was a Virgin cable modem and a Belkin router, worked fine.
I've now been supplied with a "Super Hub" and I am having some problems.
I've set it up as a router with no wireless, just cable to the Pi.
I'm trying to do away with the Belkin router (one less thing to go wrong).
From Windows 7, I can connnect to the Pi with no problems.
From the Pi to Windows 7, I can't get a connection.
Ifconfig gives me the inet addr, bcast addr and the mask code.
I try to use Filezilla, and no matter what address or protocol I use,
I am getting Connection timed out, could not connect to server.
On the Pi, I can use a browser ok (midori, iceweasel are fine).
Can somebody please tell me what I need to set on the Pi (Raspbian wheezy).
Its so long ago that I set things up that I've forgotten how.
Regards
DeeJay
Re: Virgin Super Hub - Pi set up problems
Sat Apr 06, 2013 10:58 am
What server or service are you running on the Windows device to accept the connection? Is a Windows Firewall setting getting in the way?
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
mad-hatter
Sat Apr 06, 2013 12:15 pm
On Windows, putty, tightvnc.
On Pi, tightvnc, x11vnc.
I turned off the windows firewall and my AVG firewall, same problems.
Everything was working, both ways. The only change is from a Virgin modem
and router to a Virgin Super hub.
Regards
FTrevorGowen
Sun Apr 07, 2013 9:21 pm
mad-hatter wrote: Hello,
Can you "ping" both ways? This is the simplest test.
Do the Windows 7 and Pi "network settings" agree? (eg. Pi IP addr 192.168.x.y, Windows 192.168.x.z - ie. both are on the 192.168.x network)
Do you know if the "Super Hub" is running a DHCP server (which the Pi is probably using - that's the common method with router's). IIRC Windows boxes can use other methods to obtain their IP addr.
FWIW I'm also on "Virgin" via a "Scientific Atlanta 2100" cable modem which (I think) can be used via an ethernet port or as a USB modem (it has both sockets). However, given the number of m/c's (not counting mobile 'phones etc.), including upto four Pi's, I have two wireless routers and several switches that (eventually) connect to its ethernet port for WAN/Internet access. Given that you're no longer using a router I'm guessing it's something to do with the "Super Hub's" setup (unless the Windows box is connected via USB and the Pi via ethernet???)
Trev.
turbine2
Mon Apr 08, 2013 9:25 am
Okay, some questions for you.
Have you changed any of the configuration of the Super Hub?
What IP are your Win 7, Super Hub and PI on?
Can you ping from PC to PI? (Start, Run, CMD then enter PING x.x.x.x where x.x.x.x is the PI IP)
Does the Super Hub indicate that it can see the PI (Login, click on Device Connection Status, can you see the PI in Wired Devices?)
Does the Super Hub indicate that it has issues the PI and address (assuming the PI is not fixed address but uses DHCP)? (Login, click on Advanced button, accept the warning, click on DHCP reservation under DHCP, can you see your PI in IP lease table?)
Can you ping from Super Hub to PI? (Login, click on Advanced button, accept the warning, click on Ping under Tools, enter the PI IP address)
Can you ping from PI to Super Hub? (default Super Hub IP address is 192.168.0.1)
Can you ping from PI to internet (e.g. 8.8.8.8)?
For a short term get around, you can stick the Super Hub into 'Modem Mode' (Login, click on Super Hub Settings, Click on Enable Modem Mode and stick your old router into the port nearest the cable connection, note that when you do this the IP address of the Super Hub changes to 192.168.100.1)
David
MattHawkinsUK
Mon Apr 08, 2013 10:54 am
Port forwarding didn't work on my Superhub. I put it into modem mode and setup up my old Netgear router.
This also improved some wireless issues I had.
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
turbine2
Mon Apr 08, 2013 11:13 am
MattHawkinsUK wrote:Port forwarding didn't work on my Superhub. I put it into modem mode and setup up my old Netgear router.
Just, out of interest, what version of the firmware was this on? The current (R37 IIRC) fixed a number of wireless performance issues (among other things).
David
mad-hatter
Mon Apr 08, 2013 11:43 am
Hello FTrevorGowen,
Windows 7 - ipconfig - gives me 192.168.z.y
ping from widows - 192.168.z.x ok
- 192.168.z.x-1 ok
- 192.168.z.x-2 ok
Pi - ifconfig - gives me 192.168.z.x
ping from Pi - 192.168.z.y ok
- 192.168.z.y-1 ok
- 192.168.z.y+1 ok
DHCP is switched on.
The LAN IP address 192.168.z.x
DHCP address 192.168.z.y
I turned windows, the super hub and AVG firewalls off, no luck.
Helo turbine2,
Of course I've changed the super hub settings, tyring to get something to work.
I think I've also changed them all back to the original settings.
I know I can always reset the settings.
LAN IP address - 192.168.z.a
Win IP address - 192.168.z.x
Pi IP address - 192.168.z.y
Pinging - see above.
Ping - Super Hub to Pi - ok
Ping - 8.8.8.8 - ok
I tried in Modem Mode with a Belkin router.
Windows to Pi - OK
Pi to Windows - No luck
Hello MattHawkinsUK,
I've played with router and modem settings - no luck.
Hello again turbine2,
Firmware V2.37.01
Thanks to you all.
general settings.jpg (32.68 KiB) Viewed 4417 times
wired devices.jpg (17.98 KiB) Viewed 4417 times
attached devices.jpg (17.33 KiB) Viewed 4417 times
turbine2
Mon Apr 08, 2013 12:01 pm
Ok, so for ping PI to Internet works, PI to Super Hub works and PI to Windows 7 works.
What service on the Windows 7 PC are you trying to get? What's not working, you say you can't get a connection but a connection to what? Ping indicates that the network is there so I'm guessing a service?
David
mad-hatter
Mon Apr 08, 2013 12:37 pm
Hello turbine2,
From the Pi, I can't get filezilla or dolphin to connect to Windows 7
or cups to see my windows printer.
I had these setup and working with my old Virgin modem & Belkin router.
Regards
turbine2
Mon Apr 08, 2013 2:26 pm
Okay, filezilla for FTP, dolphin I'm not sure about (browser? gamecube / Wii emulator? something else?) and CUPS for printing.
I'm guessing (quite possibly incorrectly) that this has something to do with name resolution, can you ping the windows 7 machine by name from the PI? Can you use filezilla by using the IP address of the PC rather than the PC name?
Did you edit your hosts file on the PI originally with the IP address of the Windows 7 PC and now it's on a different address?
David
turbine2
Mon Apr 08, 2013 2:31 pm
mad-hatter wrote: I tried in Modem Mode with a Belkin router.
Windows to Pi - OK
Just noticed this too. If it worked before with the Belkin and no longer works with the Belkin attached to the Super Hub in Modem Mode then it's something else and not the Super Hub. When in Modem Mode the only thing the Super Hub does is take the DOCSIS Cable network and the Ethernet home network and passes traffic through, much like the old modem would have. All services other than that (firewall, DHCP, DNS, NAT, etc.) are disabled by modem mode.
David
mad-hatter
Wed Apr 10, 2013 12:04 pm
Hello turbine2,
Been playing:-
Installed wheezy RC1 on my PC - Logged in.
On the Pi with filezilla, I can access wheezy on my PC.
So I'm guessing, its some sort of configuration problem with my
Windows 7 setup and nothing to do with the Virgin super hub.
Regards
turbine2
Mon Apr 15, 2013 9:02 am
mad-hatter wrote: So I'm guessing, its some sort of configuration problem with my
Well, from my professional perspective that's good to hear, although does not solve your problem.
I think at this point I'd start looking at the usual suspects on the Windows 7 PC (firewall, application set up, anything that the service patches have installed since it was last working). Netstat should show you what is running / listening on the PC, and look out for the relevant ports (22, 25, etc.).
netstat -b will give the application name (or add -b -v for the full detail), so look out for the server service against the port, just in case something else has taken over that, although I've got to admit I'm going in to areas I'm not so sure about here and the firewall may kick in elsewhere.
Good luck with getting it working again,
David
David
