Q48VW wrote:
Hello all, I recently purchased a Model B Raspberry Pi and am having some troubles with the network.
OS: Raspbian "wheezy"
SD: 32gb micro with an adapter
To begin, I should mention that my Pi's ethernet cable is connected to the ethernet port on the motherboard of my PC.
Presumably you have a good reason (eg. no spare ethernet ports elsewhere) for trying to do things this way but you are making very difficult for yourself. The simplest way to achieve all the (inter-connected) networking you desire is to either:
1) Plug the Pi into a spare LAN port on your router (if you have one).
2) (Better still) invest in a cheep and cheerful 5-port network switch and connect the Pi, your PC and that to the router.
Assuming the Pi and the PC both then use DHCP to get their IP addresses from the (server on the) router then all are on the same local network and all can (gateway through) see the internet (WAN) via the router. There are 9 machines (not counting mobile 'phones via WiFi) that connect to each other (and the 'net) via this "hardware-based" approach in our household - four of them being Pi's, the others a mix of Linux, Windows and "dual-boot" machines. The nearest I've come to doing things "your way" was when I had a "Smoothwall Linux" PC as a hardware firewall between other machines and, what was then, a "single point" connection (ie. not a router) to my ISP in the early days of "broadband" (it having been a "dial-up" connection [2nd. 'phone line] previously).
Trev.
