deadsource wrote:
The green led blinks only once when I plug in the power and that's all. With other OS the green led is blinking constantly. I'm using an analogue output if that helps by any chance.
Edit: there's no loader.bin file after each write. Is it invisible on windows or was it removed in newer builds?
loader.bin is no longer required/used.
For reference (esp. other readers of this thread) I've created a fresh SDHC card image of February's Raspbian Wheezy on a Kingston 4Gb card (actually a 4Gb micro-SDHC + adapter) via Ubuntu's "Image Writer" and an external Integral USB SDHC card reader/writer. (I'm not certain that my netbook's SD card slot is SDHC compatible ie. it's not marked as such) The first partition of said card is reported by Ubuntu as containing 12 items using 19.3Mb of a 59Mb filesystem, 39.2Mb freespace and capacity 58.7Mb. Windows XP shows 12 files, 19,415,040 bytes (18.5 Mb) used, 39,247,872 (37.4Mb) free, capacity 58,662,912 bytes (55.9Mb).
Ubuntu shows the twelve files thus:
trevor@BlueElf:/media/C522-EA52$ ls -laF
total 18980
drwx------ 2 trevor trevor 16384 Jan 1 1970 ./
drwxr-xr-x 4 root root 4096 Apr 4 19:59 ../
-rw-r--r-- 1 trevor trevor 17764 Feb 8 23:21 bootcode.bin
-rw-r--r-- 1 trevor trevor 142 Feb 9 00:27 cmdline.txt
-rw-r--r-- 1 trevor trevor 1180 Feb 9 00:27 config.txt
-rw-r--r-- 1 trevor trevor 2260 Feb 8 23:21 fixup_cd.dat
-rw-r--r-- 1 trevor trevor 5898 Feb 8 23:21 fixup.dat
-rw-r--r-- 1 trevor trevor 8687 Feb 8 23:21 fixup_x.dat
-rw-r--r-- 1 trevor trevor 137 Feb 9 02:42 issue.txt
-rw-r--r-- 1 trevor trevor 9609792 Feb 8 23:21 kernel_emergency.img
-rw-r--r-- 1 trevor trevor 2802568 Feb 8 23:21 kernel.img
-rw-r--r-- 1 trevor trevor 569240 Feb 8 23:21 start_cd.elf
-rw-r--r-- 1 trevor trevor 2694676 Feb 8 23:21 start.elf
-rw-r--r-- 1 trevor trevor 3631684 Feb 8 23:21 start_x.elf
A single blink of the green led is usually associated with power supply issues preventing proper boot up - dependent upon what USB devices are directly plugged into a Pi. This also appears to be happening more often for images written via Windows. You have not stated what model Pi you have - I tend to assume a model B2 (512Mb) since they're (probably) more common (I have a B1, two B2's and an A, all normally running Wheezy). Model A's have known USB issues that are, AFIK, different to B's, these are being looked into by the community developers. The sting in the tail (for me
) is that when I tried the pristine SD card from the above exercise in my model A it failed to boot (not even a "green flash") yet the same card worked straight away in one of the B2's. I also use standard Integral 4Gb or 8Gb SDHC cards and the model A was booting without issues from one of those. As they say "the plot thickens".
Trev.
