It looks like that when I write motion in the command line, even if video0 has been commented it, its still tries to load it for some reason and because of it, it keeps saying unsuccessful;although the webcam can still be accessed through pi.
Another thing I've noticed is that when there's a motion in front of the camera, the system shuts and I can't access the ip cam through pi,unless I restart the service.
1. Looks like it is using another motion.conf or thread1 file. If you are only using one camera is is simpler to put all the settings in the .conf file and get rid of the thread file so there is one less thing to worry about.
How are you running motion? and where is the .conf file? stick them both into a directory, change the name of the .conf file a little to perhaps motionip.conf then run motion from that directory with
This should then ensure that Motion is using the correct .conf file
2. As a non coder I would suspect your power supply for the second problem, there are an awful lot of poor supplies around and they do not all supply the current printed on them, I use an RS one which works well.
I am currently running Motion on a Pi with MMAL camera and the dozencrows mods
http://www.raspberrypi.org/phpBB3/viewt ... 43&t=44966
and it works very well, much better quality than the IP camera, only problem is I don't have a waterproof housing for the pi + cam.
