Sat Mar 10, 2012 2:18 pm
This is what I have but entirely at your own risk if you try it.
I suggest checking all 0V are joined so you're sure of the pinout and getting it to power-up using a bench supply with current limiting for safety.
In the absence of a current means to provide images you'll have to make do with this description of the pinout, looking into the socket on the monitor, so it's skull shaped ( likely with LCD facing upwards ), from top to bottom, three pins, four pins, two pins, left to right …
Top row – 12V, Standby, <gap>, 0V
Middle Row – 0V, Audio in, Audio in, IR output
Bottom row – 0V, Video in
The 0V are all joined and also connects to the metal ring / shield around the socket.
+12V In
Power Supply Input
Nominally a 12V input but operation appears to be acceptable down to around 8V. Operation at 5V is not possible. Current drawn is around 550mA at 12V with the video input disconnected or displaying a black screen. In standby mode the current drawn falls to around 30mA at 12V. A typical 12V @ 1A power supply, as used by a router or hub, should be acceptable for powering the monitor.
0V
Power Supply 0V / Ground
Standby
Standby / Enable Signal
This is notionally an input signal to the LCD. When left floating the standby mode is entered; the LCD is powered down and the standby LED is illuminated. When connected to 0V the LCD is powered up and the standby LED is turned off.
Audio In
Left and Right Audio Input
IR Out
Signal from inbuilt IR Receiver
Signal is normally about 5V pulsing low when an IR signal is present. The IR receiver appears to carry the signal transparently so any IR remote control protocol should be receivable
Video In
Composite Video Input
