I'm experienced with networks and computing, apart from very limited Linux/Unix skills.
The new Raspberry has been plugged in today and everything seems fine except it won't pick up an IP address.
I have other devices that pick up IP addresses (connected into the same hub) fine and have swapped cables etc.
The 10MB link shows amber, and the TX/RX lights are green.
Ifconfig shows that the interface is up with no errors and is TX and RX ok.
The interfaces file is default, which is showing to configure eth0 with dhcp.
Forcing a manual IP address with ifconfig eth0 192.168.199 correctly applies the address to the interface and the default class C subnet mask.
I can ping the local adapter interface fine (and the loop back as well), but cannot ping anything on the local LAN.
Running a subnet ping 192.168.1.255 also doesn't have any replies.
I'm running a 1000 micro amp power supply and have also tried booting with the mouse disconnected.
Can someone please let me know how I troubleshoot the problem on the system locally. I'm 100% sure the problem is not with the network, as I'm very experienced in this area (10 year CCIE) , just unfortunately not with Unix and the Raspberry.
Thanks.
