Sun Mar 31, 2013 9:25 pm
Wudz wrote:
I cannot display the correct screen on my screen: I got the setup blue screen on the monitor while VNC shows me the raspberry home page...
What is going on?
In addition, the blue screen is not displayed everytime. It is the best result I have: nothing or blue ...
The "VNC screen" layout will depend upon which VNC server you're using on the Pi - eg. "tightvncserver", "x11vncserver" (There are probably others). I've used tightvnc methods based upon the guide(s) in the wiki (
http://elinux.org/RPi_Guides).
Not sure what you mean by the "setup blue screen" - the only one I can think of is that for the "raspi-config" utility which runs (once) on "first boot" from a newly-installed SD card image. But that assumes you're running "Wheezy Raspbian" of course. That, unless you've modified boot preferences, boots into "fullscreen terminal/command-line mode" (text only) with a black background. the "startx" command is then used to invoke a GUI desktop usually with a large raspberry
So, what OS are you using?
Can you post any screenshots?
Trev.
