That's what I would think too. See http://elinux.org/RPiconfig#Overclocking for more info.pluggy wrote:Hazarding a guess it will have the standard FAT boot partition, so edit config.txt ?
Are you sure? AFAIK it should still boot from the FAT partition on the SD card and the firmware (which you cannot do without, again AFAIK!) will read the config.txt on that partition...cyrano wrote:config.txt is missing in Kali. You need to install it manually form github. Instructions here:
http://rageweb.info/2013/03/21/raspi-config-in-kali/
